粘贴版是一个常用的功能,用户通过系统剪贴板服务,可实现应用之间的简单数据传递。例如:在应用A中复制的数据,可以在应用B中粘贴,反之亦可。
效果如图:
关键代码如下:
- public class PasteboardUtils {
- private static final HiLogLabel TAG = new HiLogLabel(HiLog.LOG_APP,0x0,"蛟龙腾飞--粘贴版");
- private SystemPasteboard pasteboard;
- public PasteboardUtils(Context context) {
- initPasteboard(context);
- // 复制到粘贴板
- public void copyText(String text) {
- pasteboard.setPasteData(PasteData.creatPlainTextData(text));
- // 粘贴
- public String pasteText() {
- String result = "";
- PasteData pasteData = pasteboard.getPasteData();
- if (pasteData == null) {
- return result;
- PasteData.DataProperty dataProperty = pasteData.getProperty();
- boolean hasHtml = dataProperty.hasMimeType(PasteData.MIMETYPE_TEXT_HTML);
- boolean hasText = dataProperty.hasMimeType(PasteData.MIMETYPE_TEXT_PLAIN);
- if (hasHtml || hasText) {
- for (int i = 0; i < pasteData.getRecordCount(); i++) {
- PasteData.Record record = pasteData.getRecordAt(i);
- String mimeType = record.getMimeType();
- if (mimeType.equals(PasteData.MIMETYPE_TEXT_HTML)) {
- result = record.getHtmlText();
- } else if (mimeType.equals(PasteData.MIMETYPE_TEXT_PLAIN)) {
- result = record.getPlainText().toString();
- } else {
- HiLog.info(TAG, "%{public}s", "getPasteData mimeType :" + mimeType);
- return result;
- // 监听粘贴版内容
- private final IPasteDataChangedListener listener = new IPasteDataChangedListener() {
- @Override
- public void onChanged() {
- if (pasteData != null) {
- HiLog.info(TAG,"粘贴版内容改变:"+pasteData);
- // 清空粘贴板
- public void clearPasteboard(Component component) {
- if (pasteboard != null) {
- pasteboard.clear();
- //初始化
- private void initPasteboard(Context context) {
- pasteboard = SystemPasteboard.getSystemPasteboard(context);
- pasteboard.addPasteDataChangedListener(listener);
复制代码完整代码地址:
