1、移植的准备
Timer主要用于定时触发事件使用。移植相对容易。需要#include "hi_timer.h"中的相关函数。
2、machine_timer_obj_t定义
typedef struct _machine_timer_obj_t {
mp_obj_base_t base;
mp_obj_t timeout_cb;
uint32_t mode;
uint32_t period;
hi_u32 g_timer_handle;
struct _machine_timer_obj_t *next;
} machine_timer_obj_t;
定义hi_u32 g_timer_handle用于存储定时器handle
3、创建Timer定时器
STATIC mp_obj_t machine_timer_make_new(const mp_obj_type_t *type, size_t n_args, size_t n_kw, const mp_obj_t *args) {
machine_timer_obj_t *self = m_new_obj(machine_timer_obj_t);
self->base.type = &machine_timer_type;
hi_u32 ret;
ret = hi_timer_create(&self->g_timer_handle);
if (ret != HI_ERR_SUCCESS) {
mp_raise_ValueError("timer create fail");
// Add the timer to the linked-list of timers
self->next = MP_STATE_PORT(machine_timer_obj_head);
MP_STATE_PORT(machine_timer_obj_head) = self;
return MP_OBJ_FROM_PTR(self);
4、开启定时器
STATIC mp_obj_t machine_timer_start(mp_uint_t n_args, const mp_obj_t *args, mp_map_t *kw_args) {
machine_timer_obj_t *self = (machine_timer_obj_t *)args[0];
int mode = 0;
enum {
ARG_mode,
ARG_period,
ARG_callback,
static const mp_arg_t allowed_args[] = {
{ MP_QSTR_mode, MP_ARG_INT, {.u_int = 0} },
{ MP_QSTR_period, MP_ARG_INT, {.u_int = 0xffffffff} },
{ MP_QSTR_callback, MP_ARG_OBJ, {.u_obj = mp_const_none} },
mp_arg_val_t dargs[MP_ARRAY_SIZE(allowed_args)];
mp_arg_parse_all(n_args - 1, args + 1, kw_args, MP_ARRAY_SIZE(allowed_args), allowed_args, dargs);
if (4 == n_args) {
self->mode = dargs[ARG_mode].u_int;
self->period = dargs[ARG_period].u_int;
self->timeout_cb = dargs[ARG_callback].u_obj;
} else {
mp_raise_ValueError("invalid format");
error_check(self->period > 0, "Set timeout value error");
int res = hi_timer_start(self->g_timer_handle,self->mode,self->period,timer_event_handler,(void*)self);
if (res != HI_ERR_SUCCESS) {
mp_raise_ValueError("timer start fail");
return mp_const_none;
STATIC MP_DEFINE_CONST_FUN_OBJ_KW(machine_timer_start_obj, 1, machine_timer_start);
5、关闭定时器
STATIC mp_obj_t machine_timer_stop(mp_uint_t n_args, const mp_obj_t *args, mp_map_t *kw_args) {
int ret = hi_timer_stop(self->g_timer_handle);
mp_raise_ValueError("timer stop fail");
STATIC MP_DEFINE_CONST_FUN_OBJ_KW(machine_timer_stop_obj, 1, machine_timer_stop);
6、定时器的回调
STATIC void timer_event_handler(void *arg) {
machine_timer_obj_t *self = arg;
//printf("machine_pin_isr_handler = %drn",self->pin);
mp_sched_schedule(self->timeout_cb, MP_OBJ_FROM_PTR(self));
回调的使用和Pin的类似。
7、python的使用
from machine import Timer
import time
def callback_periodic(obj): # defined preiodic mode timeout callback
print("Timer callback periodic test")
def callback_oneshot(obj): # defined ont shot mode timeout callback
print("Timer callback oneshot test")
print("start")
timer = Timer() # Create Timer object, driver support timer1/timer2/timer3
timer.start(timer.PERIODIC, 1000, callback_periodic) # Initialize the Timer device object
# Set Timer mode to preiodic mode, set timeout to 1 seconds and set callback fucntion
time.sleep(5)# Execute 5 times timeout callback in the delay time
timer.start(timer.ONE_SHOT, 1000, callback_oneshot) # Reset initialize the Timer device object
# Set Timer mode to one shot mode, set timeout to 1 seconds and set callback fucntion
time.sleep(5) # Execute 1 times timeout callback in the delay time
timer.deinit() # Stop and close Timer device object
