1. API使用
1.1 创建数据库
import dataRdb from ‘@ohos.data.rdb’
const STORE_CONFIG = {name: “RdbTest.db” }
const SQL_CREATE_TABLE = “CREATE TABLE IF NOT EXISTS EMPLOYEE (ID INTEGER PRIMARY KEY AUTOINCREMENT, NAME TEXT NOT NULL, AGE INTEGER, SALARY REAL, CODES BLOB)”
let promise = dataRdb.getRdbStore(STORE_CONFIG, 1);
promise.then(async (rdbStore) =》 {
rdbStore.executeSql(SQL_CREATE_TABLE, null)
}).catch((err) =》 {
expect(null).assertFail();
1.2 插件数据
const valueBucket = {
“NAME”: “Lisa”,
“AGE”: 18,
“SALARY”: 100.5,
“CODES”: new Uint8Array([1, 2, 3, 4, 5]),
rdbStore.insert(“EMPLOYEE”, valueBucket, function (err, ret) {
expect(1).assertEqual(ret)
console.log(TAG + “insert first done: ” + ret)})复制
1.3 删除数据
let predicates = new dataRdb.RdbPredicates(“EMPLOYEE”)
predicates.equalTo(“NAME”, “Lisa”)
rdbStore.delete(predicates, function (err, rows) {
console.log(TAG + “delete rows: ” + rows)})复制
1.4 修改数据
“NAME”: “Rose”,
“AGE”: 22,
“SALARY”: 200.5,
rdbStore.update(valueBucket, predicates, function (err, ret) {
console.log(TAG + “updated row count: ” + ret)})
1.5 查询数据
predicates.equalTo(“NAME”, “Rose”)
rdbStore.query(predicates, [“ID”, “NAME”, “AGE”, “SALARY”, “CODES”], function (err, resultSet) {
console.log(TAG + “resultSet column names:” + resultSet.columnNames)
console.log(TAG + “resultSet column count:” + resultSet.columnCount)})
1.6 结果集处理
resultSet.goToFirstRow()
const id = resultSet.getLong(resultSet.getColumnIndex(“ID”))
const name = resultSet.getString(resultSet.getColumnIndex(“NAME”))
const age = resultSet.getLong(resultSet.getColumnIndex(“AGE”))
const salary = resultSet.getDouble(resultSet.getColumnIndex(“SALARY”))
复制
2. 演示实现
我们分别写文字,创建数据库,“插入数据”,“查询数据”,“删除数据”,跟随代码“同步全部”的点击事件
@Entry
@Component
struct MyRdb {
rdb: dataRdb.RdbStore;
@State name: string= “Lisa”
private CreateRdbStore() {
var that=this;
dataRdb.getRdbStore({ name: “XiLeiRgb.db” }, 1, function (err, rdbStore) {
if (err) {
console.log(‘获取失败’ + err)
} else {
console.log(‘创建成功’)
that.rdb=rdbStore;
private insertData() {
“NAME”: “Lisa”,
“AGE”: 18,
“SALARY”: 100.5,
let promise = this.rdb.insert(“EMPLOYEE”, valueBucket)
promise.then(async (ret) =》 {
console.log( “插入成功==》》insert first done: ” + ret)
this.name=“Lisa”;
}).catch((err) =》 {
private SelectData() {
predicates.equalTo(“NAME”, this.name)
console.log(“查询条件====》”+this.name)
this.rdb.query(predicates, [“ID”, “NAME”, “AGE”, “SALARY”, “CODES”], function (err, resultSet) {
console.log(“查询成功==》》resultSet column names:” + resultSet.columnNames)
console.log(“查询成功==》》resultSet column count:” + resultSet.columnCount)
if(resultSet.rowCount》0){
console.log( “id===》” + id+“===name==》”+name+“==age==》”+age+“==salary==》”+JSON.toString(salary))
}else{
console.log(“暂无数据”)
private updateData() {
var that=this;
let valueBucket = {
“NAME”: “Rose”,
“AGE”: 22,
“SALARY”: 200.5,
that.rdb.update(valueBucket, predicates, function (err, ret) {
console.log(“修改成功==》》updated row count: ” + ret)
that.name = “Rose”;
private deleteData() {
let that=this
that.rdb.delete(predicates, function (err, rows) {
console.log(“删除成功===》》delete rows: ” + rows)
build() {
Flex({ direction: FlexDirection.Column, alignItems: ItemAlign.Center, justifyContent: FlexAlign.Center }) {
Text(‘创建数据库’)
.fontSize(50)
.onClick(this.CreateRdbStore.bind(this))
.fontWeight(FontWeight.Bold)
Text(‘插入数据’)
.fontSize(50)
.onClick(this.insertData.bind(this))
.backgroundColor(Color.Red)
Text(‘查询数据’)
.fontSize(50)
.onClick(this.SelectData.bind(this))
.backgroundColor(Color.White)
Text(‘修改数据’)
.fontSize(50)
.onClick(this.updateData.bind(this))
Text(‘删除数据’)
.fontSize(50)
.onClick(this.deleteData.bind(this))
.width(‘100%’)
.height(‘100%’)
显示效果如下所示
3.运行效果
“创建数据库”、“删除数据”、“查询数据”、“查询数据”、“查询数据”、“数据”、“查询数据”的查询结果
