1、修改文件,打开调试模式,得到 EDID 信息后,记得关闭
diff --git a/kernel/drivers/video/fbmon.c b/kernel/drivers/video/fbmon.c index 6103fa6..ce9b11e 100755 --- a/kernel/drivers/video/fbmon.c +++ b/kernel/drivers/video/fbmon.c @@ -43,7 +43,8 @@ * EDID parser */ -#undef DEBUG /* define this for verbose EDID parsing output */ +//#undef DEBUG /* define this for verbose EDID parsing output */ +#define DEBUG #ifdef DEBUG #define DPRINTK(fmt, args...) printk(fmt,## args) 2、打印出 EDID 信息 [ 0.805638] ======================================== [ 0.805652] Display Information (EDID) [ 0.805662] ======================================== [ 0.805672] EDID Version 1.3 [ 0.805682] Manufacturer: ROW [ 0.805691] Model: 0 [ 0.805699] Serial#: 0 [ 0.805708] Year: 2014 Week 12 [ 0.805719] Monitor Name: AAA [ 0.805728] Display Characteristics: [ 0.805738] Monitor Operating Limits: From EDID [ 0.805754] H: 30-80KHz V: 50-76Hz DCLK: 160MHz [ 0.805764] Digital Display Input Sync: [ 0.805780] Max H-size in cm: variable [ 0.805791] Max V-size in cm: variable [ 0.805801] Gamma: 1.0 [ 0.805813] DPMS: Active yes, Suspend no, Standby yes [ 0.805823] Unknown [ 0.805832] Chroma [ 0.805840] RedX: 0.636 RedY: 0.349 [ 0.805852] GreenX: 0.290 GreenY: 0.589 [ 0.805863] BlueX: 0.143 BlueY: 0.080 [ 0.805875] WhiteX: 0.313 WhiteY: 0.329 [ 0.805886] First DETAILED Timing is preferred [ 0.805899] Detailed Timings [ 0.805910] 40 MHz 800 840 968 1056 600 601 605 628 +HSync +VSync [ 0.805932] Supported VESA Modes [ 0.805945] 720x400@70Hz [ 0.805955] 640x480@60Hz [ 0.805964] 640x480@72Hz [ 0.805972] 640x480@75Hz [ 0.805980] 800x600@56Hz [ 0.805988] 800x600@60Hz [ 0.805997] 800x600@72Hz [ 0.806005] 800x600@75Hz [ 0.806014] Manufacturer's mask: 0 [ 0.806023] Standard Timings [ 0.806034] ======================================== Detailed Timings 是主要的 LCD 参数,Supported VESA Modes 是 LCD 支持的分辨率。 通过源码查看各参数的含义: 路径:kernel/drivers/video/fbmon.c DPRINTK(" %d MHz ", PIXEL_CLOCK/1000000); DPRINTK("%d %d %d %d ", H_ACTIVE, H_ACTIVE + H_SYNC_OFFSET, H_ACTIVE + H_SYNC_OFFSET + H_SYNC_WIDTH, H_ACTIVE + H_BLANKING); DPRINTK("%d %d %d %d ", V_ACTIVE, V_ACTIVE + V_SYNC_OFFSET, V_ACTIVE + V_SYNC_OFFSET + V_SYNC_WIDTH, V_ACTIVE + V_BLANKING); DPRINTK("%sHSync %sVSyncnn", (HSYNC_POSITIVE) ? "+" : "-", (VSYNC_POSITIVE) ? "+" : "-"); 由此可以得到 LCD 的各参数: 40M = PIXEL_CLOCK = pixclock 800 = H_ACTIVE = xres 840 = H_ACTIVE + H_SYNC_OFFSET = xres + h_fp = 800 + 40 968 = H_ACTIVE + H_SYNC_OFFSET + H_SYNC_WIDTH = xres + h_fp + h_pw = 800 + 40 + 128 1056 = H_ACTIVE + H_BLANKING = xres + h_bp + h_fp + h_pw = 800 + 88 + 40 + 128 600 = V_ACTIVE = yres 601 = V_ACTIVE + V_SYNC_OFFSET = yres + v_fp = 600 + 1 605 = V_ACTIVE + V_SYNC_OFFSET + V_SYNC_WIDTH = yres + v_fp + v_pw = 600 + 1 + 4 628 = V_ACTIVE + V_BLANKING = yres + v_bp + v_fp + v_pw = 600 + 23 + 1 + 4 +HSync = HSYNC_POSITIVE +VSync = VSYNC_POSITIVE 3、在枚举中增加此分辨率,枚举值为 108,并修改默认分辨率 diff --git a/kernel/drivers/video/rockchip/hdmi/rockchip-hdmi.h b/kernel/drivers/video/rockchip/hdmi/rockchip-hdmi.h index b5475e4..f31f5b9 100755 --- a/kernel/drivers/video/rockchip/hdmi/rockchip-hdmi.h +++ b/kernel/drivers/video/rockchip/hdmi/rockchip-hdmi.h @@ -129,6 +129,7 @@ enum hdmi_video_infomation_code { HDMI_3840X2160P_30HZ_4_3, /*105*/ HDMI_3840X2160P_50HZ_4_3, HDMI_3840X2160P_60HZ_4_3, + HDMI_800X600P_60HZ, /*108*/ }; /* HDMI Extended Resolution */ @@ -474,7 +475,7 @@ struct hdmi { #define HDMI_AUTO_CONFIG false /* HDMI default vide mode */ -#define HDMI_VIDEO_DEFAULT_MODE HDMI_1920X1080P_60HZ//HDMI_1280X720P_60HZ +#define HDMI_VIDEO_DEFAULT_MODE HDMI_800X600P_60HZ//HDMI_1920X1080P_60HZ//HDMI_1280X720P_60HZ /*HDMI_1920X1080P_60HZ*/ #define HDMI_VIDEO_DEFAULT_COLORMODE HDMI_COLOR_AUTO #define HDMI_VIDEO_DEFAULT_COLORDEPTH 8 4、将屏参数据添加到数组 static const struct hdmi_video_timing hdmi_mode[] 中 /* name refresh xres yres pixclock h_bp h_fp v_bp v_fp h_pw v_pw polariry PorI flag vic 2ndvic pixelrepeat interface */ /* 名称 刷新频率 行像素 列像素 像素时钟 水平后沿 水平前沿 垂直后沿 垂直前沿 行同步脉宽 列同步脉宽 极性 扫描方式 标志 枚举值 第二枚举值 像素重复 接口*/ diff --git a/kernel/drivers/video/rockchip/hdmi/rockchip-hdmi-lcdc.c b/kernel/drivers/video/rockchip/hdmi/rockchip-hdmi-lcdc.c index 63a5cfb..0f920c2 100755 --- a/kernel/drivers/video/rockchip/hdmi/rockchip-hdmi-lcdc.c +++ b/kernel/drivers/video/rockchip/hdmi/rockchip-hdmi-lcdc.c @@ -7,6 +7,7 @@ static const struct hdmi_video_timing hdmi_mode[] = { { { "720x576i@50Hz", 50, 720, 576, 27000000, 69, 12, 19, 2, 63, 3, 0, 1, 0 }, 21, HDMI_720X576I_50HZ_16_9, 2, OUT_P888}, { { "720x480p@60Hz", 60, 720, 480, 27000000, 60, 16, 30, 9, 62, 6, 0, 0, 0 }, 2, HDMI_720X480P_60HZ_16_9, 1, OUT_P888}, { { "720x576p@50Hz", 50, 720, 576, 27000000, 68, 12, 39, 5, 64, 5, 0, 0, 0 }, 17, HDMI_720X576P_50HZ_16_9, 1, OUT_P888}, + { { "800x600p@60Hz", 60, 800, 600, 40000000, 88, 40, 23, 1, 128, 4, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0}, 108, HDMI_800X600P_60HZ, 1, OUT_P888}, { { "1280x720p@24Hz", 24, 1280, 720, 59400000, 220, 1760, 20, 5, 40, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0}, 60, HDMI_1280X720P_24HZ_4_3, 1, OUT_P888}, { { "1280x720p@25Hz", 25, 1280, 720, 74250000, 220, 2420, 20, 5, 40, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0}, 61, HDMI_1280X720P_25HZ_4_3, 1, OUT_P888}, { { "1280x720p@30Hz", 30, 1280, 720, 74250000, 220, 1760, 20, 5, 40, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0}, 62, HDMI_1280X720P_30HZ_4_3, 1, OUT_P888}, polariry:水平同步高电平有效和垂直同步高电平有效 PorI:0 为不是隔行扫描。定义文件路径:/kernel/include/uapi/linux/fb.h flag:不知道什么意思 vic:在分辨率枚举中的编号,本次添加的为 108 5、此时 HDMI 可以正常输入 800x600 的分辨率,但是实际显示可能有问题。 根据显示器的 EDID 修改 dts 中加载的屏参文件,修改值与添加到 HDMI 数组中的相同。 diff --git a/kernel/arch/arm/boot/dts/lcd-800x600.dtsi b/kernel/arch/arm/boot/dts/lcd-800x600.dtsi index c0baf15..733a157 100755 --- a/kernel/arch/arm/boot/dts/lcd-800x600.dtsi +++ b/kernel/arch/arm/boot/dts/lcd-800x600.dtsi @@ -15,12 +15,12 @@ clock-frequency = <40000000>; - hactive = <1920>; - vactive = <1080>; - hback-porch = <126>; - hfront-porch = <120>; - vback-porch = <10>; - vfront-porch = <10>; - hsync-len = <10>; - vsync-len = <8>; + hactive = <800>; + vactive = <600>; + hback-porch = <88>; + hfront-porch = <40>; + vback-porch = <23>; + vfront-porch = <1>; + hsync-len = <128>; + vsync-len = <4>; hsync-active = <0>; vsync-active = <0>; de-active = <0>; 6、编译烧录,HDMI 显示正常,确认当前分辨率可以在设置 -> HDMI ->分辨率设置中查看,也可以通过指令查看。 $ cat /sys/class/display/HDMI/mode |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 11:58 , Processed in 0.661230 second(s), Total 73, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2080
