添加脚本:
build/core/FotaInfo.sh #!/bin/bash #********Do not modify this file. If you want modify this file, pls contact our FAE******* echo "" echo "# begin fota properties" echo "ro.fota.platform=RK3229" #type info: phone, pad ,box, tv echo "ro.fota.type=hifi" #oem info echo "ro.fota.oem=CompanyName " #广升备案的公司名称 #model info, Settings->About phone->Model number #FotaDevice=$(grep "ro.product.model=" "$1"|awk -F "=" '{print $NF}' ) #echo "ro.fota.device=SK04$FotaDevice" | sed 's/[^0-9a-zA-Z= ._-]//g' echo "ro.fota.device=SK04" #version number, Settings->About phone->Build number #FotaVersion=$(grep "ro.build.display.id=" "$1"|awk -F "=" '{print $NF}' )`date +_%Y%m%d-%H%M` FotaVersion=$(grep "ro.build.display.id=" "$1"|awk -F "=" '{print $NF}' ) echo "ro.fota.version=$FotaVersion" echo "# end fota properties" #********Do not modify this file. If you want modify this file, pls contact our FAE******* build/core/getOtaPackage.sh #!/bin/bash # $1 - project name : e.g. ROOTPATH="target_files-package" mkdir -p $ROOTPATH #build mkdir -p $ROOTPATH/build/target/product/ cp -a build/target/product/security/ $ROOTPATH/build/target/product/ mkdir -p $ROOTPATH/build/tools/ cp -ur build/tools/releasetools/ $ROOTPATH/build/tools/ #device mkdir -p $ROOTPATH/device/rockchip/common/ cp -u device/rockchip/common/releasetools.py $ROOTPATH/device/rockchip/common/ #out mkdir -p $ROOTPATH/out/host/linux-x86/bin/ cp -u out/host/linux-x86/bin/minigzip out/host/linux-x86/bin/mkbootfs out/host/linux-x86/bin/mkbootimg out/host/linux-x86/bin/fs_config out/host/linux-x86/bin/mkyaffs2image out/host/linux-x86/bin/zipalign out/host/linux-x86/bin/bsdiff out/host/linux-x86/bin/imgdiff out/host/linux-x86/bin/remkloader out/host/linux-x86/bin/mkparameter out/host/linux-x86/bin/drmsigntool out/host/linux-x86/bin/mkuserimg.sh out/host/linux-x86/bin/make_ext4fs out/host/linux-x86/bin/aapt $ROOTPATH/out/host/linux-x86/bin/ cp -u out/host/linux-x86/bin/simg2img out/host/linux-x86/bin/e2fsck out/host/linux-x86/bin/build_verity_tree out/host/linux-x86/bin/verity_signer out/host/linux-x86/bin/append2simg out/host/linux-x86/bin/boot_signer $ROOTPATH/out/host/linux-x86/bin/ mkdir -p $ROOTPATH/out/host/linux-x86/framework cp -u out/host/linux-x86/framework/signapk.jar out/host/linux-x86/framework/dumpkey.jar $ROOTPATH/out/host/linux-x86/framework/ #libc++.so mkdir -p $ROOTPATH/out/host/linux-x86/lib64/ cp -u out/host/linux-x86/lib64/libc++.so $ROOTPATH/out/host/linux-x86/lib64/ #ota.zip #cp -u $1/*.zip $ROOTPATH/org.zip #org.zip echo `ls -lrt $1/obj/PACKAGING/target_files_intermediates/*target_files*.zip|tail -n 1|awk '{print $NF}'` cp -u `ls -lrt $1/obj/PACKAGING/target_files_intermediates/*target_files*.zip|tail -n 1|awk '{print $NF}'` $ROOTPATH/ota_target_files.zip mkdir -p IMAGES/ touch IMAGES/system.img touch IMAGES/userdata.img zip -q $ROOTPATH/ota_target_files.zip IMAGES/system.img IMAGES/userdata.img rm -rf IMAGES #build.prop cp -u $1/system/build.prop $ROOTPATH/build.prop #configure.xml echo "">$ROOTPATH/configure.xml echo " #buildnumber var=$(grep "ro.fota.version=" "$1/system/build.prop" ) buildnumber=${var##"ro.fota.version="} echo " #language var=$(grep "ro.product.locale=" "$1/system/build.prop" ) echo " #oem var=$(grep "ro.fota.oem=" "$1/system/build.prop" ) echo " #operator var=$(grep "ro.operator.optr=" "$1/system/build.prop") if [ "$var" = "" ] ; then var=other else var=$(echo $var|tr A-Z a-z) if [ ${var##"ro.operator.optr="} = op01 ] ; then var=CMCC elif [ ${var##"ro.operator.optr="} = op02 ] ; then var=CU else var=other fi fi echo " #model var=$(grep "ro.fota.device=" "$1/system/build.prop" ) product=${var##"ro.fota.device="} echo " #publishtime echo " #versionname echo " #key echo " echo " if [ -f $1/target_files-package.zip ]; then echo "delete exist file:$1/target_files-package" rm -f $1/target_files-package.zip fi #zip cd target_files-package zip -rq target_files-package.zip build device out configure.xml build.prop ota_target_files.zip cd .. mv target_files-package/target_files-package.zip $1/target_files-package.zip rm -rf target_files-package 2.修改Makefile build/core/Makefile ……//此处省略好多行 #abupdate fota start ifeq ($(strip $(ABUPDATE_FOTA_SUPPORT)), yes) FOTA_SH := build/core/FotaInfo.sh endif #abupdate fota end BUILDINFO_SH := build/tools/buildinfo.sh ……//此处省略好多行 #abupdate fota start ifeq ($(strip $(ABUPDATE_FOTA_SUPPORT)), yes) @echo "Target FotaInfo: $@" $(hide) chmod 777 $(FOTA_SH) bash $(FOTA_SH) $@ >> $@ endif #abupdate fota end build_desc := ifeq (,$(filter true, $(TARGET_NO_KERNEL) $(TARGET_NO_RECOVERY))) INSTALLED_RECOVERYIMAGE_TARGET := $(PRODUCT_OUT)/recovery.img else INSTALLED_RECOVERYIMAGE_TARGET := Endif ……//此处省略好多行 #abupdate fota start ifeq ($(strip $(ABUPDATE_FOTA_SUPPORT)), yes) @echo "Package FotaPackage" $(hide) chmod 777 build/core/getOtaPackage.sh bash build/core/getOtaPackage.sh $(PRODUCT_OUT) $(KEY_CERT_PAIR) $(TARGET_DEVICE) $(HOST_LIBRARY_PATH) $(HOST_SHLIB_SUFFIX) endif #abupdate fota end .PHONY: otapackage otapackage: $(INTERNAL_OTA_PACKAGE_TARGET) ……//此处省略好多行 3.修改BoardConfig.mk: device/rockchip/rk322x/BoardConfig.mk ……//此处省略好多行 #abupdatefota start ABUPDATE_FOTA_SUPPORT = yes #abupdatefota end 4.最后修改根目录下的总编译脚本build_all.sh: 在make -j16之后添加 # build otapackage echo "start build otapackage" cd build/tools/drmsigntool && mm -B && cd - make otapackage # mkimage.sh echo "make and copy android images" # Note:it is neccessary to add ota. ./mkimage.sh ota 5.以上都做完之后每次全编译代码会生成OTA整包文件:target_files-package.zip,两个版本之间的整包通过广升提供的工具(IOTdeltaTool2.0.0.5_2018.3.23.zip)就可以做差分包了,最后在服务器上配置差分升级即可。 注意: 1). IOTdeltaTool2.0.0.5_2018.3.23.zip需要解压,然后在JDK1.8上通过指令(java -jar IOTdeltaTool2.0.0.5.jar)来运行。 2). 运行中可能存在环境错误,这时需要再安装(adups-delta-5.0.24.deb) sudo dpkg -i adups-delta-5.0.24.deb |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 10:37 , Processed in 0.696339 second(s), Total 73, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1465
