首先,要先获得技术支持
步骤一,先在USB模块上完成4G 步骤二,移植到PCIE座子上 磨刀不费砍材功,请先拿到技术文档支持,我的参考是:Quectel_Android_RIL_Driver_V3.3.62_master_beta(支持EC200A).tgz 主要文件:Quectel_Android_RIL_Driver_V3.3.62_master_beta(支持EC200A)libquectel-rilarm64-v8alibreference-ril.so 主要文档:Quectel_Android_RIL_Driver_User_Guide_V2.0.pdf //##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//## PCIE原理图部分 调通USB转接小板之后,直接接在PCIE座子上就有信号出现了 //设备打印信息 [ 7.643000] u*** 1-1.7: new high-speed USB device number 3 using ehci-platform [ 7.749890] u*** 1-1.7: New USB device found, idVendor=2c7c, idProduct=0125, bcdDevice= 3.18 [ 7.749955] u*** 1-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 7.749981] u*** 1-1.7: Product: Android [ 7.750003] u*** 1-1.7: Manufacturer: Android [ 7.752548] option 1-1.7:1.0: GSM modem (1-port) converter detected [ 7.753213] u*** 1-1.7: GSM modem (1-port) converter now attached to ttyUSB0 [ 7.753814] option 1-1.7:1.1: GSM modem (1-port) converter detected [ 7.754974] u*** 1-1.7: GSM modem (1-port) converter now attached to ttyUSB1 [ 7.755636] option 1-1.7:1.2: GSM modem (1-port) converter detected [ 7.756855] u*** 1-1.7: GSM modem (1-port) converter now attached to ttyUSB2 [ 7.757686] option 1-1.7:1.3: GSM modem (1-port) converter detected [ 7.758823] u*** 1-1.7: GSM modem (1-port) converter now attached to ttyUSB3 [ 7.761038] qmi_wwan_q 1-1.7:1.4: cdc-wdm0: USB WDM device [ 7.761079] qmi_wwan_q 1-1.7:1.4: Quectel EC25&EC21&EG91&EG95&EG06&EP06&EM06&EG12&EP12&EM12&EG16&EG18&BG96&AG35 work on RawIP mode [ 7.761710] qmi_wwan_q 1-1.7:1.4: rx_urb_size = 1520 [ 7.762558] qmi_wwan_q 1-1.7:1.4 wwan0: register 'qmi_wwan_q' at u***-fd800000.u***-1.7, WWAN/QMI device, da:6a:4f:b4:a4:63 //DTS配置 kernelarcharm64bootdtsrockchiprk3568-evb1-ddr4-v10.dtsi + rk_modem: rk-modem { + ; + 4G,power-gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_LOW>; //4G/5G_EN-MODEM_ON-GPIO4_D2 + 4G,reset-gpio = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>;//4G/5G_RST-MODEM_RST-GPIO0_D5 + status = "okay"; + }; //用的驱动是kerneldriversnetltelte_rm310.c; kernelarcharm64configsrockchip_defconfig; CONFIG_LTE=y CONFIG_LTE_RM310=y //##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//## 调试部分: 1.使用lsu*** console:/ # su console:/ # console:/ # lsu*** Bus 005 Device 001: ID 1d6b:0002 Bus 001 Device 004: ID 2c7c:0125 Bus 003 Device 001: ID 1d6b:0001 Bus 002 Device 002: ID 0bda:c820 Bus 001 Device 001: ID 1d6b:0002 Bus 006 Device 001: ID 1d6b:0003 Bus 001 Device 002: ID 1a40:0201 Bus 004 Device 001: ID 1d6b:0001 Bus 002 Device 001: ID 1d6b:0002 Bus 001 Device 003: ID 25a7:fa61 其中,ID 2c7c:0125就是我们的无线网卡EC20,如果没有,请检查硬件电路。 2.使用 ls -l dev/ttyUSB* 查看是否有节点和是否有权限(没有节点查驱动添加) 2|console:/ # ls -l dev/ttyUSB* crw-rw-rw- 1 radio radio 188, 0 2022-01-25 15:43 dev/ttyUSB0 crw-rw-rw- 1 radio radio 188, 1 2022-01-25 15:43 dev/ttyUSB1 crw-rw-rw- 1 radio radio 188, 2 2022-01-25 17:26 dev/ttyUSB2 crw-rw-rw- 1 radio radio 188, 3 2022-01-25 15:43 dev/ttyUSB3 3.使用ls -l dev/cdc-wdm0 检查节点是否注册(查系统有无添加这一段节点代码) 130|console:/ # ls -l dev/cdc-wdm0 crw-rw---- 1 radio radio 180, 176 2022-01-25 15:43 dev/cdc-wdm0 4.getprop | grep ril 查看加载库是否正确 130|console:/ # getprop | grep ril [gsm.version.ril-impl]: [Quectel_Android_RIL_Driver_V3.3.62_dirty] [init.svc.vendor.ril-daemon]: [running] [init.svc_debug_pid.vendor.ril-daemon]: [391] [ril.function.dataonly]: [1] [ro.boot.noril]: [false] [ro.boottime.vendor.ril-daemon]: [7157814141] [ro.ril.ecclist]: [112,911] [vendor.rild.libpath]: [/vendor/lib64/librk-ril.so] 130|console:/ # getprop | grep rild [vendor.rild.libpath]: [/vendor/lib64/librk-ril.so] 5.logcat -b radio 打印log信息 130|console:/ # logcat -b radio --------- beginning of radio 01-25 15:43:17.805 248 248 D TelephonyManager: No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline: open failed: EACCES (Permission denied) 01-25 15:43:17.805 248 248 D TelephonyManager: /proc/cmdline= 01-25 15:43:22.633 249 249 D TelephonyManager: No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline: open failed: EACCES (Permission denied) 01-25 15:43:22.633 249 249 D TelephonyManager: /proc/cmdline= 01-25 15:43:24.111 447 447 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:24.232 447 528 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:24.321 447 461 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:24.543 447 447 D TelephonyRegistry: systemRunning register for intents 01-25 15:43:24.828 447 472 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:25.768 828 828 I chatty : uid=1001(radio) com.android.phone expire 110 lines 01-25 15:43:25.829 391 391 I chatty : uid=1001(radio) /vendor/bin/hw/rild expire 6 lines 01-25 15:43:25.832 828 1002 I chatty : uid=1001(radio) HwBinder:828_1 expire 16 lines 01-25 15:43:25.890 447 447 D TelephonyRegistry: notifyCellLocationForSubscriber: subId=0 cellLocation=null 01-25 15:43:25.895 828 851 I chatty : uid=1001(radio) Binder:828_3 expire 1 line 01-25 15:43:25.973 828 1021 I chatty : uid=1001(radio) GsmInboundSmsHa expire 5 lines 01-25 15:43:25.985 828 1023 I chatty : uid=1001(radio) CdmaInboundSmsH expire 5 lines 01-25 15:43:26.023 447 504 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.044 447 504 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.049 596 596 W CarrierConfigManager: Error getting config for subId 1 ICarrierConfigLoader is null 01-25 15:43:26.074 447 772 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.082 447 825 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.143 828 1030 I chatty : uid=1001(radio) DcHandlerThread expire 1 line 01-25 15:43:26.202 447 825 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.217 447 825 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.243 447 504 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.260 447 504 D TelephonyRegistry: listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.429 828 828 I chatty : uid=1001(radio) com.android.phone expire 129 lines 01-25 15:43:26.434 828 1002 I chatty : uid=1001(radio) HwBinder:828_1 expire 25 lines 01-25 15:43:26.449 447 772 D TelephonyRegistry: notifySubscriptionInfoChanged: first invocation mRecords.size=22 01-25 15:43:26.509 391 391 I chatty : uid=1001(radio) /vendor/bin/hw/rild expire 3 lines 01-25 15:43:26.653 828 828 I chatty : uid=1001(radio) com.android.phone expire 135 lines 01-25 15:43:26.715 828 1002 I chatty : uid=1001(radio) HwBinder:828_1 expire 4 lines 01-25 15:43:26.830 447 461 D TelephonyRegistry: notifyServiceStateForSubscriber: INVALID phoneId=0 or subId=-1 01-25 15:43:26.848 447 461 E PHONE : ServiceState.getRadioTechnology() DEPRECATED will be removed ******* 01-25 15:43:26.891 828 828 D PhoneSwitcher: Added DcRequest, size: 4 01-25 15:43:26.893 828 828 D DcRequest: Cellular request confirmed: NetworkRequest [ TRACK_DEFAULT id=13, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Uid: 10114 AdministratorUids: [] RequestorUid: 10114 RequestorPackageName: com.android.systemui] ] 01-25 15:43:26.893 828 828 D PhoneSwitcher: evaluating due to netRequest 01-25 15:43:26.894 828 828 D PhoneSwitcher: notifyPreferredDataSubIdChanged to -1 01-25 15:43:26.895 828 828 D PhoneSwitcher: Added DcRequest, size: 5 01-25 15:43:26.896 828 828 D DcRequest: Cellular request confirmed: NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN AdministratorUids: [] RequestorUid: 1000 RequestorPackageName: android] ] 01-25 15:43:26.897 828 828 D PhoneSwitcher: evaluating due to netRequest 01-25 15:43:26.897 828 828 D PhoneSwitcher: notifyPreferredDataSubIdChanged to -1 01-25 15:43:26.898 828 828 D PhoneSwitcher: Added DcRequest, size: 6 01-25 15:43:26.900 828 828 D DcRequest: Cellular request confirmed: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Uid: 1000 AdministratorUids: [] RequestorUid: 1000 RequestorPackageName: android] ] 01-25 15:43:26.900 828 828 D PhoneSwitcher: evaluating due to netRequest 01-25 15:43:26.901 828 828 D PhoneSwitcher: notifyPreferredDataSubIdChanged to -1 6.logcat -b radio -v time 打印log信息 127|console:/ # logcat -b radio -v time --------- beginning of radio 01-25 15:43:17.805 D/TelephonyManager( 248): No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline: open failed: EACCES (Permission denied) 01-25 15:43:17.805 D/TelephonyManager( 248): /proc/cmdline= 01-25 15:43:22.633 D/TelephonyManager( 249): No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline: open failed: EACCES (Permission denied) 01-25 15:43:22.633 D/TelephonyManager( 249): /proc/cmdline= 01-25 15:43:24.111 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:24.232 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:24.321 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:24.543 D/TelephonyRegistry( 447): systemRunning register for intents 01-25 15:43:24.828 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:25.768 I/chatty ( 828): uid=1001(radio) com.android.phone expire 110 lines 01-25 15:43:25.829 I/chatty ( 391): uid=1001(radio) /vendor/bin/hw/rild expire 6 lines 01-25 15:43:25.832 I/chatty ( 828): uid=1001(radio) HwBinder:828_1 expire 16 lines 01-25 15:43:25.890 D/TelephonyRegistry( 447): notifyCellLocationForSubscriber: subId=0 cellLocation=null 01-25 15:43:25.895 I/chatty ( 828): uid=1001(radio) Binder:828_3 expire 1 line 01-25 15:43:25.973 I/chatty ( 828): uid=1001(radio) GsmInboundSmsHa expire 5 lines 01-25 15:43:25.985 I/chatty ( 828): uid=1001(radio) CdmaInboundSmsH expire 5 lines 01-25 15:43:26.023 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.044 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.049 W/CarrierConfigManager( 596): Error getting config for subId 1 ICarrierConfigLoader is null 01-25 15:43:26.074 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.082 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.143 I/chatty ( 828): uid=1001(radio) DcHandlerThread expire 1 line 01-25 15:43:26.202 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.217 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.243 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.260 D/TelephonyRegistry( 447): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback 01-25 15:43:26.429 I/chatty ( 828): uid=1001(radio) com.android.phone expire 129 lines 01-25 15:43:26.434 I/chatty ( 828): uid=1001(radio) HwBinder:828_1 expire 25 lines 01-25 15:43:26.449 D/TelephonyRegistry( 447): notifySubscriptionInfoChanged: first invocation mRecords.size=22 01-25 15:43:26.509 I/chatty ( 391): uid=1001(radio) /vendor/bin/hw/rild expire 3 lines 01-25 15:43:26.653 I/chatty ( 828): uid=1001(radio) com.android.phone expire 135 lines 01-25 15:43:26.715 I/chatty ( 828): uid=1001(radio) HwBinder:828_1 expire 4 lines 01-25 15:43:26.830 D/TelephonyRegistry( 447): notifyServiceStateForSubscriber: INVALID phoneId=0 or subId=-1 01-25 15:43:26.848 E/PHONE ( 447): ServiceState.getRadioTechnology() DEPRECATED will be removed ******* 01-25 15:43:26.891 D/PhoneSwitcher( 828): Added DcRequest, size: 4 01-25 15:43:26.893 D/DcRequest( 828): Cellular request confirmed: NetworkRequest [ TRACK_DEFAULT id=13, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Uid: 10114 AdministratorUids: [] RequestorUid: 10114 RequestorPackageName: com.android.systemui] ] 01-25 15:43:26.893 D/PhoneSwitcher( 828): evaluating due to netRequest 01-25 15:43:26.894 D/PhoneSwitcher( 828): notifyPreferredDataSubIdChanged to -1 01-25 15:43:26.895 D/PhoneSwitcher( 828): Added DcRequest, size: 5 7.添加quectel_debug_log C:UsersXXX>adb root restarting adbd as root C:UsersXXX>adb shell mkdir /data/quectel_debug_log C:UsersXXX>adb shell chmod 777 /data/quectel_debug_log C:UsersXXX>adb reboot C:UsersXXX>adb root restarting adbd as root C:UsersXXX>adb remount remount succeeded C:UsersXXX>adb pull /data/quectel_debug_log C:UsersXXXDesktop pull: building file list... pull: /data/quectel_debug_log/0125_141525_radio.txt -> C:UsersXXXDesktop/0125_141525_radio.txt pull: /data/quectel_debug_log/0125_141525_logcat.txt -> C:UsersXXXDesktop/0125_141525_logcat.txt 2 files pulled. 0 files skipped. 7929 KB/s (1497541 bytes in 0.184s) 桌面上找到就是打印LOG了 8.ifconfig 查看网口IP 130|console:/ # ifconfig eth1 Link encap:Ethernet HWaddr 82:4e:8f:f2:e9:d9 Driver rk_gmac-dwmac UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 Interrupt:42 eth0 Link encap:Ethernet HWaddr 86:4e:8f:f2:e9:d9 Driver rk_gmac-dwmac UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 Interrupt:37 wwan0 Link encap:Ethernet HWaddr 06:c5:32:08:f9:76 Driver qmi_wwan_q inet addr:10.216.51.125 Bcast:10.216.51.127 Mask:255.255.255.252 inet6 addr: fe80::4c5:32ff:fe08:f976/64 Scope: Link UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope: Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:36 errors:0 dropped:0 overruns:0 frame:0 TX packets:36 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:1800 TX bytes:1800 dummy0 Link encap:Ethernet HWaddr 66:f0:fc:7f:c6:61 inet6 addr: fe80::64f0:fcff:fe7f:c661/64 Scope: Link UP BROADCAST RUNNING NOARP MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:11 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:770 console:/ # ifconfig -a ip_vti0 Link encap:UNSPEC NOARP MTU:1480 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 eth1 Link encap:Ethernet HWaddr 82:4e:8f:f2:e9:d9 Driver rk_gmac-dwmac UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 Interrupt:42 ip6_vti0 Link encap:UNSPEC NOARP MTU:1364 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 p2p0 Link encap:Ethernet HWaddr 32:7b:c9:24:a1:7e Driver rtl8821cu BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 eth0 Link encap:Ethernet HWaddr 86:4e:8f:f2:e9:d9 Driver rk_gmac-dwmac UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 Interrupt:37 wwan0 Link encap:Ethernet HWaddr 06:c5:32:08:f9:76 Driver qmi_wwan_q inet addr:10.216.51.125 Bcast:10.216.51.127 Mask:255.255.255.252 inet6 addr: fe80::4c5:32ff:fe08:f976/64 Scope: Link UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 wlan0 Link encap:Ethernet HWaddr 30:7b:c9:24:a1:7e Driver rtl8821cu BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 ip6tnl0 Link encap:UNSPEC NOARP MTU:1452 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 sit0 Link encap:IPv6-in-IPv4 NOARP MTU:1480 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope: Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:36 errors:0 dropped:0 overruns:0 frame:0 TX packets:36 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:1800 TX bytes:1800 dummy0 Link encap:Ethernet HWaddr 66:f0:fc:7f:c6:61 inet6 addr: fe80::64f0:fcff:fe7f:c661/64 Scope: Link UP BROADCAST RUNNING NOARP MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:11 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:770 console:/ # 9.adb push C:UsersXXXDesktoplibrk-ril.so /vendor/lib64/ C:UsersXXX>adb root adb server is out of date. killing... * daemon started successfully * restarting adbd as root C:UsersXXX>adb remount Using overlayfs for /system Using overlayfs for /vendor Using overlayfs for /odm Using overlayfs for /product Using overlayfs for /system_ext Now reboot your device for settings to take effect remount succeeded C:UsersXXX>adb push C:UsersXXXDesktoplibrk-ril.so /vendor/lib64/ 6499 KB/s (388568 bytes in 0.058s) push 库进去测试 //##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//## 然后看到图标就可以上网了, 一般分为驱动问题(查节点生成) 二般就是库(查看是否更新到,查看logcat和push,检查加载的路径的库是否是这个库) //##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//## 问题处理:没接4G模块直接打印到卡死 重复打印'android.hardware.radio@1.1::IRadio/slot1' [ 44.972959] init: Control message: Processed ctl.interface_start for 'android.hardware.radio@1.1::IRadio/slot1' from pid: 149 (/system/bin/hwservicemanager) [ 45.975241] init: Control message: Processed ctl.interface_start for 'android.hardware.radio@1.1::IRadio/slot1' from pid: 149 (/system/bin/hwservicemanager) [ 46.977512] init: Control message: Processed ctl.interface_start for 'android.hardware.radio@1.1::IRadio/slot1' from pid: 149 (/system/bin/hwservicemanager) RK3568systemcoreinitinit.cpp + if(strcmp(name.c_str(),"android.hardware.radio@1.1::IRadio/slot1") != 0) { LOG(INFO) << "Control message: Processed ctl." << message << " for '" << name << "' from pid: " << from_pid << " (" << process_cmdline << ")"; + } RK3568systemlibhidltransportServiceManagement.cpp + if(strcmp(descriptor.c_str(),"android.hardware.radio@1.1::IRadio") != 0) { ALOGI("getService: Trying again for %s/%s...", descriptor.c_str(),instance.c_str()); + } + if(strcmp(mInterfaceName.c_str(),"android.hardware.radio@1.1::IRadio") != 0) { LOG(WARNING) << "Waited one second for " << mInterfaceName << "/" << mInstanceName; + } //##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//##//## |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1483 浏览 1 评论
2767 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
3504 浏览 1 评论
RK3588 GStreamer调试四路鱼眼摄像头四宫格显示报错
6302 浏览 1 评论
【飞凌嵌入式OK3576-C开发板体验】RKNN神经网络-YOLO图像识别
254 浏览 0 评论
GMT+8, 2024-12-13 21:37 , Processed in 0.669002 second(s), Total 72, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
