电子发烧友论坛|
我们在做机器人实验的时候,一般需要实时地观察机械臂的各个状态信息,所以动态绘图是不可避免的,下面我们将介绍如何对机械臂的关节速度进行动态绘图。
Codes 实现代码比较简单,我们以baxter机器人单个关节的关节角(“right_s0”)为例介绍如何对其速度信息进行实时绘图: #! /usr/bin/python import rospy from sensor_msgs.msg import JointState import numpy as np import matplotlib.pyplot as plt import matplotlib.animation as animation # global variable for vel. vel_info = np.zeros(100) vel_info_temp = vel_info vel_temp = 0 # global variables for plot. fig, ax = plt.subplots() line, = ax.plot(vel_info) ax.set_ylim(-6e-2, 6e-2) ax.set_ylabel("joint vel: rad/s") ax.set_xlabel("time") def stateMsgReceived(state_msg): global vel_temp vel_temp = state_msg.velocity[15] print vel_temp def update(frame): global vel_info global vel_info_temp global line vel_info[0:-1] = vel_info_temp[1:] vel_info[-1] = vel_temp vel_info_temp = vel_info line.set_ydata(vel_info) return line def main(): global vel_info global fig rospy.init_node("joint_vel_drawer") joint_sub = rospy.Subscriber("/robot/joint_states", JointState, stateMsgReceived) ani = animation.FuncAnimation(fig, update, frames=None, interval=50) plt.show() if __name__ == "__main__": main() 代码理解 首先是导入了ROS相关的包: import rospy from sensor_msgs.msg import JointState 然后是导入数据处理包numpy以及绘图包matplotlib: import numpy as np import matplotlib.pyplot as plt import matplotlib.animation as animation 设置用于绘制速度曲线的全局变量: # global variable for vel. vel_curve = np.zeros(100) vel_curve_temp = vel_curve vel_temp = 0 其中vel_curve表示用于绘图的点的向量,比如这里用100个点来绘图;vel_curve_temp用于暂时保存vel_curve的数据,并在后面用于对vel_curve中的数据进行更新;vel_temp保存最近时刻的速度数据。 接着我们对所需绘制的图像进行设置,比如y值范围是(-6e-2, 6e-2),x、y轴的label分别为time和joint vel: # global variables for plot. fig, ax = plt.subplots() line, = ax.plot(vel_info) ax.set_ylim(-6e-2, 6e-2) ax.set_ylabel("joint vel: rad/s") ax.set_xlabel("time") 然后我们定义了/robot/joint_states话题的回调函数: def stateMsgReceived(state_msg): global vel_temp vel_temp = state_msg.velocity[15] print vel_temp 主要也就是取出关节“right_s0”的数据放置到vel_temp中。 接下来定义最最最重要的动态绘图更新函数: def update(frame): global vel_info global vel_info_temp global line vel_info[0:-1] = vel_info_temp[1:] vel_info[-1] = vel_temp vel_info_temp = vel_info line.set_ydata(vel_info) return line 在这里,我们首先将vel_info中的数据往前移一个点,也即将最早的一个速度点扔掉,然后用vel_temp这一最新数据补充到vel_info中,最后将我们的fig要绘制的曲线line中的数据设置为vel_info即可。 理解了上面的内容之后,主函数的内容也就不难理解了: def main(): global vel_info global fig rospy.init_node("joint_vel_drawer") joint_sub = rospy.Subscriber("/robot/joint_states", JointState, stateMsgReceived) ani = animation.FuncAnimation(fig, update, frames=None, interval=50) plt.show() 首先是订阅/joint_states话题,因为是用的rospy,所以会自己开辟一个线程/进程去执行回调函数,如果是用C++写的话,使用ros::AsyncSpinner()即可。然后用animation.FuncAnimation来绘制曲线,其中fig表示我们要绘制的图像,update表示更新图像数据所调用的函数,interval=50表示的是每隔50ms调用一次update函数对数据进行更新,并在fig上显示出来。最后,我们使用plt.show()打开显示窗口即可~ 绘制得到的关节速度动态曲线如下(这里就不放动态图了……): |
只有小组成员才能发言,加入小组>>
3045 浏览 0 评论
10790 浏览 4 评论
39008 浏览 19 评论
5802 浏览 0 评论
27512 浏览 34 评论
1609浏览 0评论
/9
GMT+8, 2025-12-2 10:22 , Processed in 0.752532 second(s), Total 63, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4537
