使用USART最简单的情况是只使用3根线:Tx用于 数据发送,Rx用于数据接收,GND是信号地线,提供通信双方的参考电平。
实现的功能: 1、通过串口发送数据; 2、中断方式接收数据,并将接收到的数据回送。 首先,第一步:配置引脚,将串口映射到PA9(Tx),PA10(Rx)。 void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; /* Connect GPIOs to USART1 RX&TX */ GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_1); //Tx GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_1); //Rx GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10; //USART1_TX | USART1_RX GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_Level_1; GPIO_Init(GPIOA, &GPIO_InitStructure); } 第二步:配置串口。 void USART_Configuration(void) { USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx; USART_Init(USART1,&USART_InitStructure); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1,ENABLE); } 第三步:配置中断。 void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; /*****USART1 interrupt Config****/ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } 第四步:添加串口中断函数,函数名是固定的:void USART1_IRQHandler(void)。中断进入时候,先判断接收寄存器是否有数据,有数据时候就接收,然后使用USART_SendData()将数据发回PC终端。 void USART1_IRQHandler (void) { uint16_t temp; if(USART_GetITStatus(USART1,USART_IT_RXNE)!= RESET) //Receive Data register not empty interrupt. { USART_ClearITPendingBit(USART1,USART_IT_RXNE); temp = USART_ReceiveData(USART1); USART_SendData(USART1,temp); } } 接下来就是主函数main了,具体如下: int main(void) { RCC_Configuration(); GPIO_Configuration(); USART_Configuration(); NVIC_Configuration(); TIM_Confguration(); GPIO_SetBits(GPIOC,GPIO_Pin_8); Uart_Put_String(“wangxiaoxurn”); while(1) {;} } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1369 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1363 浏览 1 评论
786 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
565 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1405 浏览 2 评论
1761浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
484浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
421浏览 3评论
414浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
389浏览 3评论
GMT+8, 2024-9-29 18:45 , Processed in 0.771852 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
