2021-07-16 17:30:38
Microsoft Windows [版本 10.0.19041.928]
(c) Microsoft Corporation。保留所有权利。
C:UsersAdministrator>npm install -g @ohos/hpm-cli
npm ERR! code ENOTFOUND
npm ERR! errno ENOTFOUND
npm ERR! network request to https://repo.huaweicloud.com/repository/npm/@ohos%2fhpm-cli failed, reason: getaddrinfo ENOTFOUND proxyserver
npm ERR! network This is a problem related to network connectivity.
npm ERR! network In most cases you are behind a proxy or have bad network settings.
npm ERR! network
npm ERR! network If you are behind a proxy, please make sure that the
npm ERR! network 'proxy' config is set properly. See: 'npm help config'
npm ERR! A complete log of this run can be found in:
npm ERR! C:UsersAdministratorAppDataRoamingnpm-cache_logs2021-07-16T12_46_51_170Z-debug.log
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。
侵权投诉
