<?xml version="1.0" encoding="utf-8"?> <DependentLayout xmlns:ohos="http://schemas.huawei.com/res/ohos" ohos:id="$+id:ability_main" ohos:height="match_parent" ohos:width="match_parent" ohos:orientation="vertical"> <!-- 头部返回按钮 --> <DirectionalLayout ohos:id="$+id:appBar" ohos:height="$float:height_appBar" ohos:width="match_parent" ohos:orientation="horizontal"> <DirectionalLayout ohos:id="$+id:appBar_backButton_touchTarget" ohos:height="$float:height_appBar_backButton_touchTarget" ohos:width="$float:width_appBar_backButton_touchTarget" ohos:alignment="center" ohos:left_margin="$float:leftMargin_appBar_backButton_touchTarget"> <Image ohos:id="$+id:appBar_backButton" ohos:height="$float:size_appBar_backButton" ohos:width="$float:size_appBar_backButton" ohos:image_src="$graphic:back"/> </DirectionalLayout> <Text ohos:id="$+id:appBar_title" ohos:height="match_parent" ohos:width="match_content" ohos:left_margin="$float:leftMargin_appBar_title" ohos:text="$string:title" ohos:text_size="$float:textSize_title"/> </DirectionalLayout> <!-- 图标部分 --> <ScrollView ohos:id="$+id:aboutPageScrollView" ohos:height="match_parent" ohos:width="match_parent" ohos:below="$id:appBar"> <DependentLayout ohos:id="$+id:aboutPageMain" ohos:height="match_content" ohos:width="match_parent" ohos:min_height="$float:aboutPage_minHeight" ohos:orientation="vertical"> <DirectionalLayout ohos:id="$+id:aboutPageUpperPart" ohos:height="$float:height_aboutPage_upperPart" ohos:width="match_parent" ohos:align_parent_top="true" ohos:alignment="horizontal_center" ohos:orientation="vertical"> <!-- TODO: Set the app icon here--> <Image ohos:id="$+id:aboutPageIcon" ohos:height="$float:size_aboutPage_iconBackground" ohos:width="$float:size_aboutPage_iconBackground" ohos:alignment="center" ohos:image_src="$media:jltf" ohos:top_margin="$float:topMargin_aboutPage_iconBackground"/> <Text ohos:id="$+id:aboutPageTitlePrimary" ohos:height="match_content" ohos:width="match_content" ohos:text="$string:aboutPage_title_primary" ohos:text_color="$color:color_aboutPage_title_primary" ohos:text_size="$float:size_aboutPage_title_primary" ohos:top_margin="$float:topMargin_aboutPage_title_primary"/> <Text ohos:id="$+id:aboutPageTitleSecondary" ohos:height="match_content" ohos:width="match_content" ohos:text="$string:aboutPage_title_secondary" ohos:text_color="$color:color_aboutPage_title_secondary" ohos:text_size="$float:size_aboutPage_title_secondary"/> </DirectionalLayout> <DirectionalLayout ohos:id="$+id:aboutPageLowerPart" ohos:height="match_content" ohos:width="match_parent" ohos:background_element="$graphic:stacklayout_background" ohos:below="$id:aboutPageUpperPart" ohos:left_margin="$float:card_margin_start" ohos:orientation="vertical" ohos:right_margin="$float:card_margin_end"/> <!--底部--> <DirectionalLayout ohos:id="$+id:aboutPageBottomPart" ohos:height="match_content" ohos:width="match_parent" ohos:align_parent_bottom="true" ohos:alignment="horizontal_center" ohos:below="$+id:aboutPageLowerPart" ohos:bottom_padding="$float:default_padding_bottom_fixed" ohos:left_padding="$float:maxPadding_start" ohos:orientation="vertical" ohos:right_padding="$float:maxPadding_end" ohos:top_padding="$float:default_padding_top_fixed"> <Text ohos:id="$+id:openSourceNoticeText" ohos:height="match_content" ohos:width="match_parent" ohos:layout_direction="locale" ohos:text_alignment="center" ohos:text_size="$float:textSize_body3"/> <Text ohos:id="$+id:protocolPrivacyText" ohos:height="match_content" ohos:width="match_parent" ohos:layout_direction="locale" ohos:multiple_lines="true" ohos:text_alignment="center" ohos:text_size="$float:textSize_body3"/> <Text ohos:id="$+id:copyrightText" ohos:height="match_content" ohos:width="match_parent" ohos:layout_direction="locale" ohos:text="$string:copyright_text" ohos:text_alignment="center" ohos:text_color="$color:textColor_secondary" ohos:text_size="$float:textSize_body3"/> <Text ohos:id="$+id:technicalSupportText" ohos:height="match_content" ohos:width="match_parent" ohos:layout_direction="locale" ohos:text="$string:technicalSupport_text" ohos:text_alignment="center" ohos:text_color="$color:textColor_secondary" ohos:text_size="$float:textSize_body3"/> </DirectionalLayout> </DependentLayout> </ScrollView> </DependentLayout> |
