设置页面框架:
部分代码如下:
<DependentLayoutxmlns:ohos="http://schemas.huawei.com/res/ohos"ohos:height="$float:singleCardViewHeight"ohos:width="match_parent">
<Textohos:id="$+id:item_content_text"ohos:height="$float:singleCardViewTextHeight"ohos:width="match_content"ohos:align_parent_left="true"ohos:center_in_parent="true"ohos:left_margin="$float:singleCardViewLeftMargin"ohos:text_color="$color:textColorPrimary"ohos:text_size="$float:textSizeBody1"/>
<Imageohos:id="$+id:item_right_icon"ohos:height="match_content"ohos:width="match_content"ohos:align_parent_right="true"ohos:center_in_parent="true"ohos:image_src="$graphic:icon_right_grey"ohos:right_margin="$float:singleCardViewRightMargin"/>
<Textohos:id="$+id:item_right_content_text"ohos:height="$float:singleCardViewRightTextHeight"ohos:width="match_content"ohos:center_in_parent="true"ohos:left_of="$id:item_right_icon"ohos:right_margin="$float:singleCardViewRightTextRightMargin"ohos:text_color="$color:textColorSecondary"ohos:text_size="$float:textSizeBody2"/>
</DependentLayout>
部分代码如下:
<DirectionalLayoutxmlns:ohos="http://schemas.huawei.com/res/ohos"ohos:height="match_content"ohos:width="match_parent"ohos:bottom_margin="$float:margin_common"ohos:left_margin="$float:breadth_common"ohos:orientation="horizontal"ohos:right_margin="$float:breadth_common"ohos:top_margin="$float:margin_common">
<DirectionalLayoutohos:height="match_parent"ohos:width="match_content"ohos:left_padding="$float:breadth_common"ohos:orientation="horizontal"ohos:weight="1">
<Imageohos:id="$+id:item_icon"ohos:height="$float:breadth_checkbox_image"ohos:width="$float:breadth_checkbox_image"ohos:layout_alignment="vertical_center"ohos:left_margin="$float:margin_checkbox_image"ohos:right_margin="$float:breadth_checkbox_image_margin"/>
<DirectionalLayoutohos:id="$+id:text_layout"ohos:height="match_content"ohos:width="match_content"ohos:orientation="vertical">
<Textohos:id="$+id:item_content_text"ohos:height="match_content"ohos:width="match_content"ohos:layout_alignment="left"ohos:text_size="$float:checkbox_main_text_size"/>
<Textohos:id="$+id:item_status_text"ohos:height="match_content"ohos:width="match_content"ohos:layout_alignment="left"ohos:multiple_lines="true"ohos:text_size="$float:checkbox_minor_text_size"ohos:top_margin="$float:margin_between_texts"/>
</DirectionalLayout>
<DirectionalLayoutxmlns:ohos="http://schemas.huawei.com/res/ohos"ohos:id="$+id:checkbox_layout"ohos:height="$float:height_checkbox_1"ohos:width="match_content"ohos:bottom_margin="$float:margin_common"ohos:layout_alignment="right"ohos:orientation="horizontal"ohos:right_margin="$float:breadth_checkbox"ohos:top_margin="$float:margin_common">
<Imageohos:id="$+id:item_right_checkbox"ohos:height="$float:height_checkbox_image"ohos:width="$float:width_checkbox_image"ohos:bottom_margin="$float:margin_common2"ohos:image_src="$media:Enabled"ohos:layout_alignment="vertical_center"ohos:top_margin="$float:margin_common2"/>
商品框架:
部分代码:
完整代码地址:
