002 使用鸿蒙WebView创建简单浏览器 step 2通过DataAbility给简易浏览器增加历史记录存储
学习鸿蒙的点滴记录在Gitee上面:https://gitee.com/javaaier/HarmonyOSNotes
添加数据库类
@Database(entities = {WebViewHistory.class, WebViewFavorite.class}, version = 1)
public abstract class WebViewStore extends OrmDatabase {
添加历史记录类
@Entity(tableName = "WebViewHistory",
indices = {@Index(value = {"historyId"}, name = "historyId_index", unique = true)})
public class WebViewHistory extends OrmObject{
@PrimaryKey(autoGenerate = true)
private Integer historyId;
private Long browseTime;
private String url;
private String title;
... 省略了 getters setters toString方法
添加Data Ability,并实现增加和查询的方法
public class WebViewHistoryAbility extends Ability {
private static final HiLogLabel LABEL_LOG = new HiLogLabel(3, 0xD001100, "Demo");
private OrmContext ormContext = null;
@Override
public void onStart(Intent intent) {
super.onStart(intent);
HiLog.info(LABEL_LOG, "WebViewHistoryAbility onStart");
DatabaseHelper databaseHelper = new DatabaseHelper(this);
ormContext = databaseHelper.getOrmContext("WebViewStore", "WebViewStore.db", WebViewStore.class, null);
@Override
public ResultSet query(Uri uri, String[] columns, DataAbilityPredicates predicates) {
HiLog.info(LABEL_LOG, "WebViewHistoryAbility query");
if (ormContext == null) {
return null;
System.out.println("----------------------------开始获取数据--------------------------");
//真正查询数据的语句
OrmPredicates ormPredicates = DataAbilityUtils.createOrmPredicates(predicates, WebViewHistory.class);
ResultSet rs = ormContext.query(ormPredicates, columns);
return rs;
@Override
public int insert(Uri uri, ValuesBucket value) {
HiLog.info(LABEL_LOG, "WebViewHistoryAbility insert");
return -1;
System.out.println("----------------------------开始写入数据--------------------------");
WebViewHistory history = new WebViewHistory();
history.setBrowseTime(value.getLong("browseTime"));
history.setTitle(value.getString("title"));
history.setUrl(value.getString("url"));
boolean insert = ormContext.insert(history);
if (!insert) {
return -1;
boolean flush = ormContext.flush();
if (!flush) {
return -1;
int id = Math.toIntExact(history.getRowId());
System.out.println("----------------------------写入数据完成--------------------------");
return id;
在config.json文件中添加权限
"reqPermissions": [
"name": "ohos.permission.INTERNET"
"name": "ohos.permission.GET_DISTRIBUTED_DEVICE_INFO"
"name": "ohos.permission.DISTRIBUTED_DATASYNC"
"name": "ohos.permission.READ_USER_STORAGE"
"name": "com.javaaier.family.huawei.DataAbilityShellProvider.PROVIDER"
"defPermissions": [
"name": "com.javaaier.family.huawei.DataAbilityShellProvider.PROVIDER",
"grantMode": "system_grant"
修改WebView界面,增加查看历史记录的按钮(本次笔记只记录输出历史记录到控制台)
//定义历史记录Data Ability的Uri
historyUri = Uri.parse("dataability:///com.javaaier.family.huawei.WebViewHistoryAbility");
//新增历史记录
ValuesBucket values = new ValuesBucket();
values.putLong("browseTime", System.currentTimeMillis());
values.putString("url", "url");
values.putString("title", webView.getTitle());
try {
int insertRowId = helper.insert(historyUri, values);
} catch (DataAbilityRemoteException e) {
e.printStackTrace();
// 查看历史记录
case ResourceTable.Id_button_webView_viewHistory: {
try {
DataAbilityPredicates dap = new DataAbilityPredicates();
dap.orderByDesc("browseTime");
ResultSet rs = helper.query(historyUri,
new String[]{"historyId", "browseTime", "url", "title"},
dap);
Utils.showTip(SimpleWebViewAbilitySlice.this, "已读取数据");
if (rs.getRowCount() > 0) {
rs.goToFirstRow();
for (int i = 0; i < rs.getRowCount(); i++) {
System.out.println("查询出来的数据:"
+ rs.getInt(rs.getColumnIndexForName("historyId")) + "," +
rs.getLong(rs.getColumnIndexForName("browseTime")) + "," +
rs.getString(rs.getColumnIndexForName("url")) + "," +
rs.getString(rs.getColumnIndexForName("title")));
rs.goToNextRow();
运行及验证是否正确
最终记录和读取的历史记录如下图所示:
