[文章]001 - 使用鸿蒙WebView创建简单浏览器 step 1
阅读量0
  • 打开官网,找到WebView的文档(模拟器不支持)
    鸿蒙webview的开发指南(原始链接,方便大家识别并点击):https://developer.harmonyos.com/cn/docs/documentation/doc-guides/ui-java-component-webview-0000001092715158
  • 创建一个Page Ability,把基本布局弄好
    下面是代码
    <?xml version="1.0" encoding="utf-8"?>
    <DirectionalLayout    xmlns:ohos="http://schemas.huawei.com/res/ohos"    ohos:height="match_parent"    ohos:width="match_parent"    ohos:orientation="vertical">    <DirectionalLayout        ohos:height="30vp"        ohos:width="match_parent"        ohos:orientation="horizontal">        <TextField            ohos:id="$+id:text_webView_Url"            ohos:height="match_content"            ohos:width="match_parent"            ohos:background_element="$graphic:background_ability_simple_web_view"            ohos:focus_border_enable="true"            ohos:hint="请输入网址"            ohos:max_text_lines="1"            ohos:multiple_lines="false"            ohos:scrollable="true"            ohos:text="www.harmonyos.com"            ohos:text_size="50"            ohos:weight="1"            />        <Button            ohos:id="$+id:button_webview_surf"            ohos:height="match_content"            ohos:width="60vp"            ohos:background_element="$graphic:button_element"            ohos:text="跳转"            ohos:text_size="50"/>    </DirectionalLayout>    <ProgressBar        ohos:id="$+id:other_webView_progressBar"        ohos:height="10vp"        ohos:width="match_parent"        ohos:visibility="hide">    </ProgressBar>    <ohos.agp.components.webengine.WebView        ohos:id="$+id:webview_webview_webview"        ohos:height="match_parent"        ohos:width="match_parent"        ohos:weight="1">    </ohos.agp.components.webengine.WebView>    <DirectionalLayout        ohos:height="30vp"        ohos:width="match_parent"        ohos:orientation="horizontal">        <DirectionalLayout            ohos:height="match_content"            ohos:width="match_parent"            ohos:orientation="horizontal"            ohos:weight="1">            <Button                ohos:id="$+id:button_webview_back"                ohos:height="match_content"                ohos:width="match_parent"                ohos:background_element="$graphic:button_element"                ohos:layout_alignment="horizontal_center"                ohos:text="向后"                ohos:text_size="50"                >            </Button>        </DirectionalLayout>        <DirectionalLayout            ohos:height="match_content"            ohos:width="match_parent"            ohos:orientation="horizontal"            ohos:weight="1">            <Button                ohos:id="$+id:button_webview_refresh"                ohos:height="match_content"                ohos:width="match_parent"                ohos:background_element="$graphic:button_element"                ohos:layout_alignment="horizontal_center"                ohos:text="刷新"                ohos:text_size="50">            </Button>        </DirectionalLayout>        <DirectionalLayout            ohos:height="match_content"            ohos:width="match_parent"            ohos:orientation="horizontal"            ohos:weight="1">            <Button                ohos:id="$+id:button_webview_forward"                ohos:height="match_content"                ohos:width="match_parent"                ohos:background_element="$graphic:button_element"                ohos:layout_alignment="horizontal_center"                ohos:text="向前"                ohos:text_size="50">            </Button>        </DirectionalLayout>    </DirectionalLayout></DirectionalLayout>
  • 把基本的按钮事件弄好
    序号按钮功能
    1跳转把文本框中的网址打开
    2后退在webview中点了新链接后,想回去看一看
    3刷新以前的人在网络不好,美女图片出不来的时候用,现在一般是发了一篇帖子后,作者会没事点一下,看看有没有人点赞
    4前进跟后退是关联用的,就是点了新链接,回去看了看后,还是觉得新链接更好看,就又要前进.代码
        Component.ClickedListener clickedListener = new Component.ClickedListener() {        @Override        public void onClick(Component component) {            int componentId = component.getId();            switch (componentId) {                case ResourceTable.Id_button_webview_surf: {                    urlAddress = textWebViewUrl.getText();                    if (urlAddress.isEmpty()) {                        return;                    }                    if (!urlAddress.startsWith(FinalValue.URL_HTTPS)) {                        urlAddress = FinalValue.URL_HTTPS + urlAddress;                    }                    webView.load(urlAddress);​                                   }                break;                case ResourceTable.Id_button_webview_back: {                    if (webView.getNavigator().canGoBack()) {                        webView.getNavigator().goBack();                    }                }                break;                case ResourceTable.Id_button_webview_refresh: {                    webView.reload();                }                break;                case ResourceTable.Id_button_webview_forward: {                    if (webView.getNavigator().canGoForward()) {                        webView.getNavigator().goForward();                    }                }                break;                default: {                    System.out.println("没有选择任何的页面");                }                break;            }        }    };​
  • 把WebView照文档上面的要求弄好
    没啥好说的,就是规定.我加在了调用load方法打开网址那行代码后面,我还弄了一个跟进度条关联的功能
      //允许javascript交互
    ​                    WebConfig webConfig = webView.getWebConfig();                    webConfig.setDataAbilityPermit(true);                    webConfig.setJavaScriptPermit(true);                    webConfig.setLoadsImagesPermit(true);                    webConfig.setMediaAutoReplay(true);                    webConfig.setLocationPermit(true);                    webConfig.setSecurityMode(WebConfig.SECURITY_SELF_ADAPTIVE);​                    webView.setWebAgent(new WebAgent() {                        @Override                        public void onLoadingPage(WebView webView, String url, PixelMap favicon) {                            super.onLoadingPage(webView, url, favicon);                            // 这儿我加了一个更新网址文本框中新页面url的功能                            if (url != urlAddress) {                               textWebViewUrl.setText(url);                            }​                        }​                        @Override                        public void onPageLoaded(WebView webView, String url) {                            super.onPageLoaded(webView, url);                            // 页面加载结束后自定义处理                        }​                        @Override                        public void onLoadingContent(WebView webView, String url) {                            super.onLoadingContent(webView, url);                            // 加载资源时自定义处理                        }​                        @Override                        public void onError(WebView webView, ResourceRequest request, ResourceError error) {                            super.onError(webView, request, error);                            // 发生错误时自定义处理                        }                    });                    webView.setBrowserAgent(new BrowserAgent(SimpleWebViewAbilitySlice.this) {                        @Override                        public void onTitleUpdated(WebView webView, String title) {                            super.onTitleUpdated(webView, title);                            // 标题变更时自定义处理                        }​                        @Override                        public void onProgressUpdated(WebView webView, int newProgress) {                            super.onProgressUpdated(webView, newProgress);                            if (newProgress < FinalValue.PROGRESS_BAR_FINISHED) {                                otherWebViewProgressBar.setVisibility(Component.VISIBLE);                                otherWebViewProgressBar.setProgressValue(newProgress);                            } else if (newProgress == FinalValue.PROGRESS_BAR_FINISHED) {                                otherWebViewProgressBar.setVisibility(Component.HIDE);                            }                            // 加载进度变更时自定义处理                        }                    });
  • 完事?or完了还有事?
    从上面拷代码的话,估计完事了.但是,我是用的回忆,但是代码却没有回退,所以我还是有必要在这儿把步骤中的问题说一说,方便不拷代码的同学也能跑出一个界面.主要体现如下:
    • 权限配置,不多说
      "reqPermissions": [
            {        "name": "ohos.permission.INTERNET"      }    ]
    • xml中的WebView要带包名
      不按上面包名写的话:
      • 真机运行后没有WebView的界面.哪怕weight=1,也不行
      • 点击跳转按钮后,PageAbility会闪退,回到首屏(调用它的页面)
    完事效果:https://www.bilibili.com/video/BV1tK4y1o7Hz/
  • 完整代码
    • 布局
      序号为2的步骤中贴全了
    • 按钮背景
      <?xml version="1.0" encoding="UTF-8" ?>
      <shape xmlns:ohos="http://schemas.huawei.com/res/ohos"       ohos:shape="rectangle">    <corners        ohos:radius="20"/>    <solid        ohos:color="#70dbdb"/></shape>
    • java代码
      package com.javaaier.family.huawei.slice;
      ​import com.javaaier.family.huawei.ResourceTable;import com.javaaier.family.huawei.common.FinalValue;import ohos.aafwk.ability.AbilitySlice;import ohos.aafwk.content.Intent;import ohos.agp.components.*;import ohos.agp.components.webengine.*;import ohos.media.image.PixelMap;​/** * @author JavaAIer * @Description : webview控件例子1:用于简单的测试webview的用法 <br/> * 001 简单webview示例 * @Date: 2021/4/16 */public class SimpleWebViewAbilitySlice extends AbilitySlice {    String urlAddress;​​    ProgressBar otherWebViewProgressBar;    TextField textWebViewUrl;    Button buttonWebViewSurf, buttonWebViewBack, buttonWebViewRefresh, buttonWebViewForward;    WebView webView;​    Component.ClickedListener clickedListener = new Component.ClickedListener() {        @Override        public void onClick(Component component) {            int componentId = component.getId();            switch (componentId) {                case ResourceTable.Id_button_webview_surf: {                    urlAddress = textWebViewUrl.getText();                    if (urlAddress.isEmpty()) {                        return;                    }                    if (!urlAddress.startsWith(FinalValue.URL_HTTPS)) {                        urlAddress = FinalValue.URL_HTTPS + urlAddress;                    }                    webView.load(urlAddress);​                    //允许javascript交互​                    WebConfig webConfig = webView.getWebConfig();                    webConfig.setDataAbilityPermit(true);                    webConfig.setJavaScriptPermit(true);                    webConfig.setLoadsImagesPermit(true);                    webConfig.setMediaAutoReplay(true);                    webConfig.setLocationPermit(true);                    webConfig.setSecurityMode(WebConfig.SECURITY_SELF_ADAPTIVE);​                    webView.setWebAgent(new WebAgent() {                        @Override                        public void onLoadingPage(WebView webView, String url, PixelMap favicon) {                            super.onLoadingPage(webView, url, favicon);                            // 页面开始加载时自定义处理                            if (url != urlAddress) {                               textWebViewUrl.setText(url);                            }​                        }​                        @Override                        public void onPageLoaded(WebView webView, String url) {                            super.onPageLoaded(webView, url);                            // 页面加载结束后自定义处理                        }​                        @Override                        public void onLoadingContent(WebView webView, String url) {                            super.onLoadingContent(webView, url);                            // 加载资源时自定义处理                        }​                        @Override                        public void onError(WebView webView, ResourceRequest request, ResourceError error) {                            super.onError(webView, request, error);                            // 发生错误时自定义处理                        }                    });                    webView.setBrowserAgent(new BrowserAgent(SimpleWebViewAbilitySlice.this) {                        @Override                        public void onTitleUpdated(WebView webView, String title) {                            super.onTitleUpdated(webView, title);                            // 标题变更时自定义处理                        }​                        @Override                        public void onProgressUpdated(WebView webView, int newProgress) {                            super.onProgressUpdated(webView, newProgress);                            if (newProgress < FinalValue.PROGRESS_BAR_FINISHED) {                                otherWebViewProgressBar.setVisibility(Component.VISIBLE);                                otherWebViewProgressBar.setProgressValue(newProgress);                            } else if (newProgress == FinalValue.PROGRESS_BAR_FINISHED) {                                otherWebViewProgressBar.setVisibility(Component.HIDE);                            }                            // 加载进度变更时自定义处理                        }                    });                }                break;                case ResourceTable.Id_button_webview_back: {                    if (webView.getNavigator().canGoBack()) {                        webView.getNavigator().goBack();                    }                }                break;                case ResourceTable.Id_button_webview_refresh: {                    webView.reload();                }                break;                case ResourceTable.Id_button_webview_forward: {                    if (webView.getNavigator().canGoForward()) {                        webView.getNavigator().goForward();                    }                }                break;                default: {                    System.out.println("没有选择任何的页面");                }                break;            }        }    };​    /**     * @Author JavaAIer     * @Description :     * @Date: 2021/4/16 14:46     * * @param intent     */    @Override​    public void onStart(Intent intent) {        super.onStart(intent);        super.setUIContent(ResourceTable.Layout_ability_simple_web_view);        otherWebViewProgressBar = (ProgressBar) findComponentById(ResourceTable.Id_other_webView_progressBar);        textWebViewUrl = (TextField) findComponentById(ResourceTable.Id_text_webView_Url);        buttonWebViewSurf = (Button) findComponentById(ResourceTable.Id_button_webview_surf);        buttonWebViewSurf.setClickedListener(clickedListener);        buttonWebViewBack = (Button) findComponentById(ResourceTable.Id_button_webview_back);        buttonWebViewBack.setClickedListener(clickedListener);        buttonWebViewRefresh = (Button) findComponentById(ResourceTable.Id_button_webview_refresh);        buttonWebViewRefresh.setClickedListener(clickedListener);        buttonWebViewForward = (Button) findComponentById(ResourceTable.Id_button_webview_forward);        buttonWebViewForward.setClickedListener(clickedListener);        webView = (WebView) findComponentById(ResourceTable.Id_webview_webview_webview);​​    }​    @Override    public void onActive() {        super.onActive();    }​    @Override    public void onForeground(Intent intent) {        super.onForeground(intent);    }}/** 这一截卡哇伊大喵在config.json用了,我发现用不用没啥区别啊
      * https://blog.csdn.net/qq_33259323/article/details/115596296
      *  "default": {      "network": {        "cleartextTraffic": true,        "securityConfig": {          "domainSettings": {
                  "cleartextPermitted": true,            "domains": [              {                "subdomains": true,                "name": "www.harmonyos.com"              }            ]          }        }      }    }** */
    • config.json
        "app": {    "bundleName": "com.javaaier.family.huawei",    "vendor": "javaaier",    "version": {      "code": 1,      "name": "1.0"    },    "apiVersion": {      "compatible": 5,      "target": 5,      "releaseType": "Beta1"    }  },  "deviceConfig": {​  },  "module": {    "package": "com.javaaier.family.huawei",    "name": ".MyApplication",    "deviceType": [      "phone"    ],    "distro": {      "deliveryWithInstall": true,      "moduleName": "entry",      "moduleType": "entry"    },    "abilities": [      {        "skills": [          {            "entities": [              "entity.system.home"            ],            "actions": [              "action.system.home"            ]          }        ],        "orientation": "unspecified",        "name": "com.javaaier.family.huawei.MainAbility",        "icon": "$media:icon",        "description": "$string:mainability_description",        "label": "$string:app_name",        "type": "page",        "launchType": "standard"      },      {        "orientation": "unspecified",        "name": "com.javaaier.family.huawei.SimpleWebViewAbility",        "icon": "$media:icon",        "description": "$string:simplewebviewability_description",        "label": "$string:app_name",        "type": "page",        "launchType": "standard"      }    ],    "reqPermissions": [      {        "name": "ohos.permission.INTERNET"      }    ]  }}
回帖
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
链接复制成功,分享给好友
