2021-04-16 09:34:09
1. 首先将两台鸿蒙设备插入电脑的u***上
2. 查看两台鸿蒙设备的deviceid
``` bash
C:UsersAdministrator>adb devices
* daemon not running; starting now at tcp:5037
* daemon started successfully
List of devices attached
FRU6R2011500QWER unauthorized
MVT5T1970300ABCD unauthorized
3. 切换成wifi调试,将以下命令依次输入
``` bash
adb -s MVT5T1970300ABCD tcpip 55555
restarting in TCP mode port: 55555
adb -s FRU6R2011500QWER tcpip 55556
restarting in TCP mode port: 55556
4. 依次进入每台鸿蒙设备看一下上面的ip地址
5. 依次连接两台鸿蒙设备
``` bash
C:UsersAdministrator>adb connect 192.168.0.10:55555
connected to 192.168.0.10:55555
C:UsersAdministrator>adb connect 192.168.0.20:55556
connected to 192.168.0.20:55556
#试错,看看重复连会怎么样
already connected to 192.168.0.10:55555
6. 使用scrcpy 连接一台鸿蒙设备
``` bash
C:UsersAdministrator>scrcpy -s 192.168.0.10:55555
INFO: scrcpy 1.17 <https://github.com/Genymobile/scrcpy>
C:ProgramDatachocolateylibscrcpy oolsscrcpy-server: 1 file pushed, 0 skipped. 1.0 MB/s (34930 bytes in 0.034s)
[server] INFO: Device: HUAWEI TAS-AL00 (Android 10)
INFO: Renderer: direct3d
INFO: Initial texture: 1080x2336
7. 使用鸿蒙专用deveco开发工具连接:运行
8. 使用鸿蒙专用deveco开发工具连接:调试
9. 结论:鸿蒙系统兼容adb wifi调试,对于想不要约束的开发者,可以使用.
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。
侵权投诉
