[文章]鸿蒙Hi3861小视频参赛:自家开发版上光敏电阻功能实现
阅读量0
这里使用的是hi3861上面的三色灯板块中的光敏电阻,可以通过遮挡光线控制灯光的亮和暗。
代码如下:
#include<stdio.h>
#include<unistd.h>
#include "ohos_init.h"
#include "cmsis_os2.h"
#include "wifiiot_gpio.h"
#include "wifiiot_gpio_ex.h"
#include "wifiiot_pwm.h"
#include "wifiiot_adc.h"
#include "wifiiot_errno.h"
#define HUMAN_SENSOR_CHAN_NAME WIFI_IOT_ADC_CHANNEL_3
#define RED_LED_PIN_NAME WIFI_IOT_IO_NAME_GPIO_10
#define RED_LED_PIN_FUNCTION WIFI_IOT_IO_FUNC_GPIO_10_GPIO
#define GREEN_LED_PIN_NAME WIFI_IOT_IO_NAME_GPIO_11
#define GREEN_LED_PIN_FUNCTION WIFI_IOT_IO_FUNC_GPIO_11_GPIO
#define BLUE_LED_PIN_NAME WIFI_IOT_IO_NAME_GPIO_12
#define BLUE_LED_PIN_FUNCTION WIFI_IOT_IO_FUNC_GPIO_12_GPIO
#define LED_DELAY_TIME_US 300000
#define LED_BRIGHT WIFI_IOT_GPIO_VALUE1
#define LED_DARK WIFI_IOT_GPIO_VALUE0
#define NUM_BLINKS 2
#define PWM_FREQ_DIVITION 64000
#define ADC_RESOLUTION 4996
//光敏电阻demo
static void jltfcloudcom(void *arg)
    (void)arg;
    IoSetFunc(RED_LED_PIN_NAME,WIFI_IOT_IO_FUNC_GPIO_10_PWM1_OUT);
    IoSetFunc(GREEN_LED_PIN_NAME,WIFI_IOT_IO_FUNC_GPIO_11_PWM2_OUT);
    IoSetFunc(BLUE_LED_PIN_NAME,WIFI_IOT_IO_FUNC_GPIO_12_PWM3_OUT);
    PwmInit(WIFI_IOT_PWM_PORT_PWM1);
    PwmInit(WIFI_IOT_PWM_PORT_PWM2);
    PwmInit(WIFI_IOT_PWM_PORT_PWM3);
   while(1){
       unsigned short data = 0;
       unsigned short duty = 0;
       if(AdcRead(WIFI_IOT_ADC_CHANNEL_4,&data,WIFI_IOT_ADC_EQU_MODEL_4,WIFI_IOT_ADC_CUR_BAIS_DEFAULT,0)==WIFI_IOT_SUCCESS)
           printf("data:%d",data);
           //128 1820
           duty = PWM_FREQ_DIVITION * (1948-(unsigned int)data) / ADC_RESOLUTION;
       PwmStart(WIFI_IOT_PWM_PORT_PWM2,duty,PWM_FREQ_DIVITION);
       usleep(10000);
       PwmStop(WIFI_IOT_PWM_PORT_PWM2);
static void jltfcloudcn(void)
    osThreadAttr_t attr;
    GpioInit();
    attr.name="jltfcloudcom";
    attr.attr_bits=0U;
    attr.cb_mem=NULL;
    attr.cb_size=0U;
    attr.stack_mem=NULL;
    attr.stack_size=4096;
    attr.priority=osPriorityNormal;
    if(osThreadNew(jltfcloudcom,NULL,&attr) == NULL){
        printf("[jltfcloudcn] Failed to create jltfcloudcom!n");
APP_FEATURE_INIT(jltfcloudcn);
本实现部分,参考了网络上部分的公开代码。
回帖
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
链接复制成功,分享给好友
