[文章]
【HarmonyOS HiSpark Wi-Fi IoT 套件试用连载】OLED屏驱动
2020-12-21 19:28:25  217 HarmonyOS OLED
分享
既然有了gpio,那就先看看基于gpio实现的iic通信吧。别的不多说先弄清楚板子上的oLED引脚号
OLED
VCC
GND
SCL GPIO14
SDA GPIO13
把支持I2C的宏定义打开,该宏定义所在位置为:
vendor\hisi\hi3861\hi3861\build\config\usr_config.mk
找到后修改如下:CONFIG_I2C_SUPPORT=y
示例一个写字节函数
void OLED_WR_Byte(uint8_t dat,uint8_t cmd){
    hi_u8 m_send_data[2] = { 0 };
    hi_u32 status;
    hi_i2c_data hi3861_i2c_data = { 0 };
    if(cmd)    {
        m_send_data[0] = 0x40;
    else     {
       m_send_data[0] = 0x00;
    m_send_data[1] = dat;
    hi3861_i2c_data.send_buf = m_send_data;
    hi3861_i2c_data.send_len = 2;
    status = hi_i2c_write(HI_I2C_IDX_0, 0x78, &hi3861_i2c_data);
    if (status != HI_ERR_SUCCESS) {
        printf(" Error: I2C write status = 0x%x! \r\n", status);
return;
初始化oled还是跟以前一样
void OLED_Init(void){
OLED_WR_Byte(0xAE,OLED_CMD);        //--turn off oled panel        OLED_WR_Byte(0x00,OLED_CMD);        //---set low column address        OLED_WR_Byte(0x10,OLED_CMD);        //---set high column address        OLED_WR_Byte(0x40,OLED_CMD);        //--set start line address  Set Mapping RAM display Start Line (0x00~0x3F)
OLED_WR_Byte(0x81,OLED_CMD);        //--set contrast control register        OLED_WR_Byte(0xCF,OLED_CMD);         // Set SEG Output Current Brightness        OLED_WR_Byte(0xA1,OLED_CMD);        //--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
OLED_WR_Byte(0xC8,OLED_CMD);        //Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
OLED_WR_Byte(0xA6,OLED_CMD);        //--set normal display        OLED_WR_Byte(0xA8,OLED_CMD);        //--set multiplex ratio(1 to 64)        OLED_WR_Byte(0x3f,OLED_CMD);        //--1/64 duty        OLED_WR_Byte(0xD3,OLED_CMD);        //-set display offset        Shift Mapping RAM Counter (0x00~0x3F)
OLED_WR_Byte(0x00,OLED_CMD);        //-not offset        OLED_WR_Byte(0xd5,OLED_CMD);        //--set display clock divide ratio/oscillator frequency
OLED_WR_Byte(0x80,OLED_CMD);        //--set divide ratio, Set Clock as 100 Frames/Sec
OLED_WR_Byte(0xD9,OLED_CMD);        //--set pre-charge period        OLED_WR_Byte(0xF1,OLED_CMD);        //Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
OLED_WR_Byte(0xDA,OLED_CMD);        //--set com pins hardware configuration        OLED_WR_Byte(0x12,OLED_CMD);
OLED_WR_Byte(0xDB,OLED_CMD);        //--set vcomh        OLED_WR_Byte(0x40,OLED_CMD);        //Set VCOM Deselect Level        OLED_WR_Byte(0x20,OLED_CMD);        //-Set Page Addressing Mode (0x00/0x01/0x02)
OLED_WR_Byte(0x02,OLED_CMD);        //
OLED_WR_Byte(0x8D,OLED_CMD);        //--set Charge Pump enable/disable        OLED_WR_Byte(0x14,OLED_CMD);        //--set(0x10) disable        OLED_WR_Byte(0xA4,OLED_CMD);        // Disable Entire Display On (0xa4/0xa5)        OLED_WR_Byte(0xA6,OLED_CMD);        // Disable Inverse Display On (0xa6/a7)         OLED_WR_Byte(0xAF,OLED_CMD);        //--turn on oled panel                OLED_WR_Byte(0xAF,OLED_CMD);         /*display ON*/         OLED_Clear();        OLED_Set_Pos(0,0);         }
void OLED_Demo(void){
OLED_Init();
OLED_Clear();
for(i=0;i<8;i++)    {
OLED_ShowCHinese(i*16,0,i+0);
for(i=0;i<7;i++)    {
OLED_ShowCHinese(i*16,2,i+8);
for(i=0;i<4;i++)    {
OLED_ShowCHinese(i*16,4,i+15);
for(i=0;i<4;i++)    {
OLED_ShowCHinese(i*16,6,i+19);
SYS_RUN(OLED_Demo);
编译烧录即可
相关文章
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
