现在我们继续研究鸿蒙HDF架构,上回书说到经由HdfDeviceAttach(),HdfDevice节点不但添加进了DevHostService的devices列表,而且还和一个DeviceNodeExt联系起来了,呈现的示意图大致如下:
接着,HdfDeviceAttach()最后会调用nodeIf->LaunchNode(),这一步实际上调用的是HdfDeviceLaunchNode(),代码截选如下:
【drivers/hdf/frameworks/core/host/src/Hdf_device_node.c】
- int HdfDeviceLaunchNode(struct HdfDeviceNode *devNode, struct IHdfDevice *devInst)
- struct HdfDevice *device = (struct HdfDevice *)devInst;
- struct HdfDriverEntry *driverEntry = devNode->driverEntry;
- const struct HdfDeviceInfo *deviceInfo = devNode->deviceInfo;
- struct IHdfDeviceToken *deviceToken = NULL;
- int ret = driverEntry->Init(&devNode->deviceObject);
- ret = HdfDeviceNodePublishService(devNode, deviceInfo, devInst);
- deviceToken = devNode->token;
- ret = DevmgrServiceClntAttachDevice(deviceInfo, deviceToken);
- return ret;
复制代码“Launch”本就是启动之意,在这里就是指启动与HdfDevice对应的驱动服务。所以此处会先调用一下driverEntry->Init(),并传入参数&devNode->deviceObject。这意味着要求驱动程序在初始化时,回填一下deviceObject里的service域。
接着,主要执行了两个动作:
1)发布驱动服务
2)挂接设备
我们会分两小节来阐述。
1.发布驱动服务
初始化完成后,就可以“发布”这个驱动服务了,HdfDeviceNodePublishService()的代码截选如下:
- static int HdfDeviceNodePublishService(struct HdfDeviceNode *devNode,
- const struct HdfDeviceInfo *deviceInfo,
- struct IHdfDevice *device)
- int status = HDF_SUCCESS;
- struct IDeviceNode *nodeIf = &devNode->super;
- if ((deviceInfo->policy == SERVICE_POLICY_PUBLIC) ||
- (deviceInfo->policy == SERVICE_POLICY_CAPACITY)) {
- if (nodeIf->PublishService != NULL) {
- // 其实调用的是 DeviceNodeExtPublishService()
- status = nodeIf->PublishService(devNode, deviceInfo->svcName);
- if (status == HDF_SUCCESS) {
- status = HdfDeviceNodePublishLocalService(devNode, deviceInfo);
- return status;
复制代码从字面上理解,如果一个设备是“公共型”或“功能型”的,则会调用nodeIf->PublishService()发布对应的驱动服务。而我们以前研究过,在HdfDeviceNode构造之时,我们可以看到为PublishService域设定了DeviceNodeExtPublishService()函数指针,因此上面代码中调用PublishService的地方,其实就是在调用这个函数。
【drivers/hdf/lite/manager/src/Hdf_device_node_ext.c】
- static int DeviceNodeExtPublishService(struct HdfDeviceNode *inst, const char *serviceName)
- const struct HdfDeviceInfo *deviceInfo = NULL;
- struct HdfDeviceObject *deviceObject = NULL;
- struct DeviceNodeExt *devNodeExt = (struct DeviceNodeExt *)inst;
- int ret = HdfDeviceNodePublishPublicService(inst, serviceName);
- deviceInfo = inst->deviceInfo;
- deviceObject = &devNodeExt->super.deviceObject;
- if (deviceInfo->policy == SERVICE_POLICY_CAPACITY) {
- devNodeExt->ioService = HdfIoServiceBind(serviceName, deviceInfo->permission);
- if (devNodeExt->ioService != NULL) {
- devNodeExt->ioService->target = (struct HdfObject*)(&inst->deviceObject);
- static struct HdfIoDispatcher dispatcher = {
- .Dispatch = DeviceNodeExtDispatch
- devNodeExt->ioService->dispatcher = &dispatcher;
- } else {
- return HDF_SUCCESS;
复制代码这样说来,发布服务时其实分了两个部分,一个是发布public部分,一个是发布local部分。分别对应HdfDeviceNodePublishPublicService()和HdfDeviceNodePublishLocalService()。
1.1 发布Public Service部分【drivers/hdf/frameworks/core/host/src/Hdf_device_node.c】
- int HdfDeviceNodePublishPublicService(struct HdfDeviceNode *devNode, const char *svcName)
- if ((devNode == NULL) || (devNode->deviceObject.service == NULL)) {
- HDF_LOGE("device method is null");
- return HDF_FAILURE;
- return DevSvcManagerClntAddService(svcName, &devNode->deviceObject);
- 【drivers/hdf/frameworks/core/host/src/Devsvc_manager_clnt.c】
- int DevSvcManagerClntAddService(const char *svcName, struct HdfDeviceObject *service)
- struct DevSvcManagerClnt *devSvcMgrClnt = DevSvcManagerClntGetInstance();
- struct IDevSvcManager *serviceManager = devSvcMgrClnt->devSvcMgrIf;
- // 其实调用的是 DevSvcManagerAddService()
- return serviceManager->AddService(serviceManager, svcName, service);
- struct DevSvcManagerClnt *DevSvcManagerClntGetInstance()
- static struct DevSvcManagerClnt *instance = NULL;
- if (instance == NULL) {
- static struct DevSvcManagerClnt singletonInstance;
- DevSvcManagerClntConstruct(&singletonInstance);
- instance = &singletonInstance;
- return instance;
复制代码从代码看,系统中有一个“设备服务管理器”(DevSvcManager),那些功能型设备都会把自己注册进它。这个倒有点儿像Android里的SMS(Service Manager Service),所有系统核心服务都会向SMS里注册自己,以便其他应用可以从SMS查询并获取服务代理。实际上,鸿蒙系统在不少方面倒的确和Android有一定类比性,这个以后我们再对比看看,目前先放下不谈。
注册设备服务的那句serviceManager->AddService()实际上调用的是DevSvcManagerAddService(),该函数会尝试向“设备服务管理器”里添加一个管理节点(DevSvcRecord):
【drivers/hdf/frameworks/core/manager/src/Devsvc_manager.c】
- int DevSvcManagerAddService(struct IDevSvcManager *inst, const char *svcName, struct HdfDeviceObject *service)
- struct DevSvcManager *devSvcManager = (struct DevSvcManager *)inst;
- struct DevSvcRecord *record = DevSvcRecordNewInstance();
- record->key = HdfStringMakeHashKey(svcName, 0);
- record->value = service;
- OsalMutexLock(&devSvcManager->mutex);
- HdfSListAdd(&devSvcManager->services, &record->entry);
- OsalMutexUnlock(&devSvcManager->mutex);
- return HdfServiceObserverPublishService(&devSvcManager->observer, svcName, 0, SERVICE_POLICY_PUBLIC, (struct HdfObject *)service->service);
复制代码
【drivers/hdf/frameworks/core/host/src/Hdf_service_observer.c】
- int HdfServiceObserverPublishService(struct HdfServiceObserver *observer,
- const char *svcName, uint32_t matchId, uint16_t policy, struct HdfObject *service)
- struct HdfServiceObserverRecord *serviceRecord = NULL;
- uint32_t serviceKey = HdfStringMakeHashKey(svcName, 0);
- serviceRecord = (struct HdfServiceObserverRecord *)HdfSListSearch(&observer->services, serviceKey, HdfServiceObserverRecordCompare);
- if (serviceRecord == NULL) {
- serviceRecord = HdfServiceObserverRecordObtain(serviceKey);
- HDF_LOGE("PublishService failed, serviceRecord is null");
- serviceRecord->publisher = service;
- serviceRecord->matchId = matchId;
- serviceRecord->policy = policy;
- HdfSListAdd(&observer->services, &serviceRecord->entry);
- } else {
- HdfServiceObserverRecordNotifySubscribers(serviceRecord, matchId, policy);
复制代码
对于“设备服务管理器”而言,当它要管理一个设备服务时,主要需要两个Record:
1)DevSvcRecord:每个服务对应一个DevSvcRecord,这个节点会插入DevSvcManager内部的services链表。如果发布服务时,发现对应的DevSvcRecord已经存在了,则会向所有订阅者发出通知。
2)HdfServiceObserverRecord:每个服务对应一个HdfServiceObserverRecord,这个节点会插入DevSvcManager内的observer部分(内部的services链表)里。每个HdfServiceObserverRecord负责维护一个“订阅者”链表,记录所有对该服务感兴趣的订阅者。
DevSvcRecord的value域是个HdfDeviceObject *指针,其实指向的就是和设备对应的DeviceNodeExt节点的deviceObject部分,根据我们以前储备的知识,我们知道这个deviceObject部分的service域指向的就是设备驱动实现的IDeviceIoService接口。
另外,从前面代码的serviceRecord->publisher = service一句,可以看到HdfServiceObserverRecord的publisher域,其实也是指向设备驱动实现的IDeviceIoService接口的。这样我们可以绘制如下的示意图:
当然,一开始HdfServiceObserverRecord里是“订阅者”链表为空啦,不过日后如果有其他服务注册为订阅者了,HdfServiceObserverRecordNotifySubscribers()就可以向它们发送通知了。发通知函数的代码如下:
【drivers/hdf/frameworks/core/host/src/Hdf_observer_record.c】
- void HdfServiceObserverRecordNotifySubscribers(struct HdfServiceObserverRecord *record, uint32_t matchId, uint16_t policy)
- struct HdfSListIterator it;
- OsalMutexLock(&record->obsRecMutex);
- HdfSListIteratorInit(&it, &record->subscribers);
- while (HdfSListIteratorHasNext(&it)) {
- struct HdfServiceSubscriber *subscriber = (struct HdfServiceSubscriber *)HdfSListIteratorNext(&it);
- if ((matchId == subscriber->matchId) || (policy != SERVICE_POLICY_PRIVATE)) {
- subscriber->state = HDF_SUBSCRIBER_STATE_READY;
- if (subscriber->callback.OnServiceConnected != NULL) {
- subscriber->callback.OnServiceConnected(subscriber->callback.deviceObject, record->publisher);
- OsalMutexUnlock(&record->obsRecMutex);
复制代码
其实就是在遍历订阅者链表,回调其callback部分的OnServiceConnected()函数。
订阅者链表里的每个节点是一个HdfServiceSubscriber,示意图如下:
以上这些其实都体现了鸿蒙系统里的一个观念,那就是“设备”其实可以被理解为“服务”。在单机系统里,一个设备的驱动程序可以被理解为一种特殊的库,上层软件通过类似函数调用的方式来调用库,从而操作这个设备。但如果要跨机器地操作设备,那么就不能直接调用函数了。一种较好地方式是将目标设备包装成一个逻辑上的服务,然后供大家使用。所以就必须把“驱动层次”和“服务层次”关联起来,这才有了前文所说的那么多数据机构。现在我们画一张大一点的示意图,把以上概念串一下:
图中画出了体现“设备(驱动)层次”和“服务层次”的两大管理者——DevmgrService和DevSvcManager,可供大家参考。
1.2 发布Local Service部分
看完了发布Public Service的部分,我们接着看HdfDeviceNodePublishService()里发布Local Service的部分。此时调用的是HdfDeviceNodePublishLocalService()。
- static int HdfDeviceNodePublishLocalService(
- struct HdfDeviceNode *devNode, const struct HdfDeviceInfo *deviceInfo)
- uint32_t matchId;
- struct DevHostService *hostService = devNode->hostService;
- matchId = HdfMakeHardwareId(deviceInfo->hostId, deviceInfo->deviceId);
- return HdfServiceObserverPublishService(&hostService->observer, deviceInfo->svcName,
- matchId, deviceInfo->policy, (struct HdfObject *)devNode->deviceObject.service);
复制代码
请注意,虽然也是在调用HdfServiceObserverPublishService(),但传入的第一个参数是&hostService->observer。也就是说,Public Service对应的监听部分,记录在DevSvcManager里,而Local Service对应的监听部分,则记录在其所属的DevHostService里。
现在我们可以画一张发布驱动的调用关系图:
2 挂接设备我们回过头继续说前文的HdfDeviceLaunchNode()部分。该函数在调用完HdfDeviceNodePublishService()之后,接着就会调用DevmgrServiceClntAttachDevice()。
【drivers/hdf/frameworks/core/host/src/Devmgr_service_clnt.c】
- int DevmgrServiceClntAttachDevice(const struct HdfDeviceInfo *deviceInfo, struct IHdfDeviceToken *deviceToken)
- struct IDevmgrService *devMgrSvcIf = NULL;
- struct DevmgrServiceClnt *inst = DevmgrServiceClntGetInstance();
- devMgrSvcIf = inst->devMgrSvcIf;
- // 实际调用的是 DevmgrServiceAttachDevice()
- return devMgrSvcIf->AttachDevice(devMgrSvcIf, deviceInfo, deviceToken);
复制代码
此处调用了DevmgrServiceAttachDevice():
【drivers/hdf/frameworks/core/manager/src/Devmgr_service.c】
- static int DevmgrServiceAttachDevice(struct IDevmgrService *inst,
- const struct HdfDeviceInfo *deviceInfo, struct IHdfDeviceToken *token)
- struct DevHostServiceClnt *hostClnt = DevmgrServiceFindDeviceHost(inst, deviceInfo->hostId);
- struct IDevHostService *hostService = hostClnt->hostService;
- struct DeviceTokenClnt *tokenClnt = DeviceTokenClntNewInstance(token);
- tokenClnt->deviceInfo = deviceInfo;
- HdfSListAdd(&hostClnt->devices, &tokenClnt->node);
复制代码
主要就是向对应的DevHostServiceClnt的devices链表里,添加一个DeviceTokenClnt节点。简单地说就是,一个DevHostServiceClnt和一个DevHostService对应,每当向DevHostService里添加一个HdfDevice节点,相应地就需要在DevHostServiceClnt里添加一个DeviceTokenClnt节点。该节点的tokenIf域记录的IHdfDeviceToken指针,来自于DeviceNodeExt的token域。
说起来,DeviceNodeExt的token其实在DeviceNodeExt构造之时就创建了:
- void HdfDeviceNodeConstruct(struct HdfDeviceNode *devNode)
- if (devNode != NULL) {
- HdfDeviceObjectConstruct(&devNode->deviceObject);
- devNode->token = HdfDeviceTokenNewInstance();
- nodeIf->LaunchNode = HdfDeviceLaunchNode;
- nodeIf->PublishService = HdfDeviceNodePublishPublicService;
复制代码
其中创建token时,调用的是HdfDeviceTokenNewInstance()。
【drivers/hdf/frameworks/core/host/src/Hdf_device_token.c】
- struct IHdfDeviceToken *HdfDeviceTokenNewInstance()
- return (struct IHdfDeviceToken *)HdfObjectManagerGetObject(HDF_OBJECT_ID_DEVICE_TOKEN);
复制代码
- struct HdfObject *HdfDeviceTokenCreate()
- struct HdfDeviceToken *token = (struct HdfDeviceToken *)OsalMemCalloc(sizeof(struct HdfDeviceToken));
- if (token != NULL) {
- HdfDeviceTokenConstruct(token);
- return (struct HdfObject *)token;
复制代码
其中HdfDeviceToken的定义如下:
- struct HdfDeviceToken {
- struct HdfSListNode node;
- struct IHdfDeviceToken super;
复制代码
咦,怎么又有bug的味道,HdfDeviceToken里应该把super放到第一个吧,否则怎么强制转化成struct HdfObject*呢?好在这个bug的危害不太大,后续版本可以调整一下。
现在我们可以再画一张图看看:
3 小结
经过以上分析,我们头脑中已经可以形成一套比较清楚的HDF逻辑结构了。总之就是将“设备(驱动)层次”和“服务层次”联系起来,该加的observer机制加上。好了,这次就先写到这儿,以后我们再补充其他内容。
文章转自:侯亮(悠然红茶)
