基于HiSpark_WiFi_IoT Hi3861板子项目实战2-彩屏LCD
这个例子是基于HiSpark Wi-Fi物联网套件Hi3861板子项目实战3-触摸彩屏LCD,从本例程中,在HarmonyOS中Hi3861学习到
1。和谐liteOS Hi3861 WIFI设置和操作
2。和谐LiteOS Hi3861 UDP长链接控制方式
3。通过UDP控制彩屏LCD输出和触摸输入操作
4。附上实战的原始码和个人开发的虚拟彩屏LCD带触摸,方便Hi3861,Hi3518EV300等没有彩屏驱动的MCU,也能通过彩屏LCD调试1。原始代码如下: #include“ ohos_init.h” #include“ cmsis_os2.h” #include“ hi_wifi_api.h” #include“ lwip / ip_addr.h” #include“ lwip / netifapi.h” #include“ lwip / sockets.h” “ #include” MQTTPacket.h“ #include” transport.h“ #include <stdio.h> #include <string.h> #include <unistd.h> #include”
#include“ wifiiot_gpio_ex.h”
#include“ lwip / api_shell.h”
#include“ net_common.h”
#include“ cJSON.h”
#define PARAM_HOTSPOT_SSID“ Honor” //您的AP SSID
#定义PARAM_HOTSPOT_PSK “12345678” //你的AP PSK
的#define PARAM_SERVER_ADDR “192.168.43.36”
的#define PARAM_SERVER_PORT 6201
#定义PARAM_HOTSPOT_TYPE WIFI_SEC_TYPE_PSK //定义在wifi_device_config.h
的#define R_LED WIFI_IOT_GPIO_IDX_10
的#define B_LED WIFI_IOT_GPIO_IDX_12
的#define G_LED WIFI_IOT_GPIO_IDX_11
的#define DOWN 0×01
#define UP 0x02
#define MOVE 0x03
静态字符响应[128] =“”;
static int sockfd = 0;
static int sockfd_isConect = 0;
static struct sockaddr_in toAddr = {0};
static int lcdTouch[3] ={0};
void UdpClient(const char* host, unsigned short port);
static void APPTask(void *arg);
static void PrintLinkedInfo(WifiLinkedInfo* info)
if (!info) return;
static char macAddress[32] = {0};
unsigned char* mac = info->bssid;
snprintf(macAddress, sizeof(macAddress), "%02X:%02X:%02X:%02X:%02X:%02X",
mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
printf("bssid: %s, rssi: %d, connState: %d, reason: %d, ssid: %s\r\n",
macAddress, info->rssi, info->connState, info->disconnectedReason, info->ssid);
static volatile int g_connected = 0;
static void OnWifiConnectionChanged(int state, WifiLinkedInfo* info)
if (!info) return;
printf("%s %d, state = %d, info = \r\n", __FUNCTION__, __LINE__, state);
PrintLinkedInfo(info);
if (state == WIFI_STATE_AVALIABLE) {
g_connected = 1;
} else {
g_connected = 0;
static void OnWifiScanStateChanged(int state, int size)
printf("%s %d, state = %X, size = %d\r\n", __FUNCTION__, __LINE__, state, size);
static WifiEvent g_defaultWifiEventListener = {
.OnWifiConnectionChanged = OnWifiConnectionChanged,
.OnWifiScanStateChanged = OnWifiScanStateChanged
static struct netif* g_iface = NULL;
int ConnectToHotspot(WifiDeviceConfig* apConfig)
WifiErrorCode errCode;
int netId = -1;
errCode = RegisterWifiEvent(&g_defaultWifiEventListener);
printf("RegisterWifiEvent: %d\r\n", errCode);
errCode = EnableWifi();
printf("EnableWifi: %d\r\n", errCode);
errCode = AddDeviceConfig(apConfig, &netId);
printf("AddDeviceConfig: %d\r\n", errCode);
g_connected = 0;
errCode = ConnectTo(netId);
printf("ConnectTo(%d): %d\r\n", netId, errCode);
while (!g_connected) { // wait until connect to AP
osDelay(10);
printf("g_connected: %d\r\n", g_connected);
g_iface = netifapi_netif_find("wlan0");
if (g_iface) {
err_t ret = netifapi_dhcp_start(g_iface);
printf("netifapi_dhcp_start: %d\r\n", ret);
osDelay(100); // wait DHCP server give me IP
ret = netifapi_netif_common(g_iface, dhcp_clients_info_show, NULL);
printf("netifapi_netif_common: %d\r\n", ret);
return netId;
void DisconnectWithHotspot(int netId)
if (g_iface) {
err_t ret = netifapi_dhcp_stop(g_iface);
printf("netifapi_dhcp_stop: %d\r\n", ret);
WifiErrorCode errCode = Disconnect(); // disconnect with your AP
printf("Disconnect: %d\r\n", errCode);
errCode = UnRegisterWifiEvent(&g_defaultWifiEventListener);
printf("UnRegisterWifiEvent: %d\r\n", errCode);
RemoveDevice(netId); // remove AP config
printf("RemoveDevice: %d\r\n", errCode);
errCode = DisableWifi();
printf("DisableWifi: %d\r\n", errCode);
static void NetTask(void *arg)
(void)arg;
WifiDeviceConfig config = {0};
// 准备AP的配置参数
strcpy(config.ssid, PARAM_HOTSPOT_SSID);
strcpy(config.preSharedKey, PARAM_HOTSPOT_PSK);
config.securityType = PARAM_HOTSPOT_TYPE;
for(;;){
osDelay(10);
int netId = ConnectToHotspot(&config);
int timeout = 2;
while (timeout--) {
printf("After %d seconds, I will start\r\n", timeout);
osDelay(100);
UdpClient(PARAM_SERVER_ADDR, PARAM_SERVER_PORT);
// mqtt_connect();
printf("disconnect to AP ...\r\n");
DisconnectWithHotspot(netId);
printf("disconnect to AP done!\r\n");
int udpsend(char *msg,int len){
if(sockfd_isConect==0)return -1;
ssize_t retval = sendto(sockfd, msg, len, 0, (struct sockaddr *)&toAddr, sizeof(toAddr));
if (retval < 0) {
printf("sendto failed!\r\n");
return -1;
return 1;
int counts=0;
ssize_t retval = 0;
char* con = "connect;pc";
while (g_connected){
sockfd = socket(AF_INET, SOCK_DGRAM, 0); // UDP socket
printf("ip%s:%d\r\n",host,port);
toAddr.sin_family = AF_INET;
toAddr.sin_port = htons(port);
if (inet_pton(AF_INET, host, &toAddr.sin_addr) <= 0) {
printf("inet_pton failed!\r\n");
goto do_cleanup;
retval = sendto(sockfd, con, sizeof(con), 0, (struct sockaddr *)&toAddr, sizeof(toAddr));
if (retval < 0) {
goto do_cleanup;
GpioSetOutputVal(B_LED, 1);
printf("request connect\r\n");
sockfd_isConect =1;
struct sockaddr_in fromAddr = {0};
socklen_t fromLen = sizeof(fromAddr);
struct timeval timeOut;
timeOut.tv_sec = 5; //设置2s超时
timeOut.tv_usec = 0;
if (setsockopt(sockfd, SOL_SOCKET, SO_RCVTIMEO, &timeOut, sizeof(timeOut)) < 0)
printf("time out setting failed\n");
for(;;){
retval = recvfrom(sockfd, &response, sizeof(response), 0, (struct sockaddr *)&fromAddr, &fromLen);
if (retval == -1 && errno == EAGAIN) //阻塞接收超时
printf("timeout..\n");
if(++counts>=5){
// goto do_cleanup;
break;
else{
int x=0 ,y=0;
counts=0;
response[retval] = '\0';
cJSON *json = cJSON_Parse((char *)response);
char *mouse = cJSON_GetObjectItem((cJSON *)json,"mouse")->valuestring;
if(strncmp(mouse, (char *)"mouseMove", 9) == 0){
x = cJSON_GetObjectItem((cJSON *)json,"x")->valueint;
y = cJSON_GetObjectItem((cJSON *)json,"y")->valueint;
lcdTouch[0]=MOVE;
lcdTouch[1]=x;
lcdTouch[2]=y;
else if(strncmp(mouse, (char *)"mouseDown", 9) == 0){
lcdTouch[0]=DOWN;
lcdTouch[1]=x;
lcdTouch[2]=y;
else if(strncmp(mouse, (char *)"mouseUp", 7) == 0){
lcdTouch[0]=UP;
lcdTouch[1]=x;
lcdTouch[2]=y;
cJSON_Delete(json);
sockfd_isConect=0;
GpioSetOutputVal(B_LED, 0);
do_cleanup:
printf("do_cleanup...\r\n");
close(sockfd);
static void MainEntry(void) //主程入口
GpioInit();
//设置红色,蓝 色,绿色 LED IO为输出状态
IoSetFunc(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_IO_FUNC_GPIO_10_GPIO);
GpioSetDir(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_GPIO_DIR_OUT);
IoSetFunc(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_IO_FUNC_GPIO_11_GPIO);
GpioSetDir(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_DIR_OUT);
IoSetFunc(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_IO_FUNC_GPIO_12_GPIO);
GpioSetDir(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_GPIO_DIR_OUT);
osThreadAttr_t attr;
attr.name = "NetTask";
attr.attr_bits = 0U;
attr.cb_mem = NULL;
attr.cb_size = 0U;
attr.stack_mem = NULL;
attr.stack_size = 30960;
attr.priority = osPriorityNormal;
if (osThreadNew(NetTask, NULL, &attr) == NULL) { //Wifi udp task
printf("[NetEntry] Falied to create NetTask!\n");
attr.name = "APPTask";
//attr.priority = osPriorityBelowNormal7;
if (osThreadNew(APPTask, NULL, &attr) == NULL) { //app
printf("[NetEntry] Falied to create APPTask!\n");
SYS_RUN(MainEntry);
//RBG LCD绘图API接口 , LCD Color = RRBBGG(0XFFFFFF)
static char str[250] ={0};
void drawPixel(int x,int y, unsigned int color ){
int len = sprintf((char *)str,"drawPixel;%d;%d;#%06x",x,y,color);
udpsend((char *)str,len);
void drawLine(int x0,int y0,int x1,int y1, unsigned int color ){
int len = sprintf((char *)str,"drawLine;%d;%d;%d;%d;#%06x",x0,y0,x1,y1,color);
void drawArc(int x, int y, int radius, int startAngle, int endAngle,unsigned int color){
int len = sprintf((char *)str,"drawArc;%d;%d;%d;%d;%d;#%06x",x,y,radius,startAngle,endAngle,color);
void drawCircle(int x,int y, int radius,unsigned int color,int fill ){
int len = sprintf((char *)str,"drawCircle;%d;%d;%d;#%06x;%d",x,y,radius,color,fill);
void drawRect(int x,int y, int width,int hight,unsigned int color,int fill ){
int len = sprintf((char *)str,"drawRect;%d;%d;%d;%d;#%06x;%d",x,y,width,hight,color,fill);
void drawText(int x,int y, unsigned int color,const char* text,int size ){
int len = sprintf((char *)str,"drawText;%d;%d;#%06x;%s;%d",x,y,color,text,size);
void drawImage(int x,int y, const char* fileName ){
int len = sprintf((char *)str,"drawImage;%d;%d;%s",x,y,fileName);
void drawClean(unsigned int color ){
int len = sprintf((char *)str,"drawClean;#%06x",color);
//===========================这个任务是写自已应用===============================
(void)arg;
int x=0,y=0;
while(!sockfd_isConect){
osDelay(100);
drawClean(0xff0000); //red
osDelay(100);
drawClean(0x00ff00); //green
osDelay(100);
drawClean(0x0000ff);//blue
osDelay(100);
//drawImage(50,50, "test" );
drawImage(0,0,"back");
osDelay(100);
drawText(60,100, 0x00ff00,"hello word!",20);
osDelay(100);
drawText(60,60, 0x00ff00,"中文测试",30);
drawText(200,60, 0x0000ff,"中文测试",14);
osDelay(100);
drawCircle(300,70, 80,0xffffff,1);
drawRect(200,100,100,150,0x0000ff,1);
for(;;){
osDelay(10);
if(lcdTouch[0]){
if(lcdTouch[0]==DOWN) {
x=lcdTouch[1];
y=lcdTouch[2];
else if(lcdTouch[0]==UP) {
else if(lcdTouch[0]==MOVE) {
if((x==0)&&(y==0)){
x=lcdTouch[1];
y=lcdTouch[2];
drawLine(x,y,lcdTouch[1],lcdTouch[2],0xff0000);
x=lcdTouch[1];
y=lcdTouch[2];
lcdTouch [0] = 0;
2.
二进制附件[attach] 980057 [/ attach]
3.虚拟UDP彩屏LCD
[附件] 980055 [/ attach]
[附件] 980056 [/ attach]
3
评分
查看全部评分
2020-11-29 13:46:46
淘帖0
2 个讨论
