`使用WIFIIOT套件,直观交互最多的就是OLED。
源码LED_example.c里去.把所有的io_9改成11:
- * Copyright (c) 2020 Huawei Device Co., Ltd.
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- * See the License for the specific language governing permissions and
- * limitations under the License.
- #include <stdio.h>
- #include <unistd.h>
- #include "ohos_init.h"
- #include "cmsis_os2.h"
- #include "wifiiot_gpio.h"
- #include "wifiiot_gpio_ex.h"
- #define LED_INTERVAL_TIME_US 300000
- #define LED_TASK_STACK_SIZE 512
- #define LED_TASK_PRIO 25
- enum LedState
- LED_ON = 0,
- LED_OFF,
- LED_SPARK,
- enum LedState g_ledState = LED_SPARK;
- static void *LedTask(const char *arg)
- (void)arg;
- while (1)
- switch (g_ledState)
- case LED_ON:
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 1);
- usleep(LED_INTERVAL_TIME_US);
- break;
- case LED_OFF:
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 0);
- break;
- case LED_SPARK:
- break;
- default:
- break;
- return NULL;
- static void LedExampleEntry(void)
- osThreadAttr_t attr;
- printf("LedExampleEntry
- GpioInit();
- IoSetFunc(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_IO_FUNC_GPIO_11_GPIO);
- GpioSetDir(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_DIR_OUT);
- attr.name = "LedTask";
- attr.attr_bits = 0U;
- attr.cb_mem = NULL;
- attr.cb_size = 0U;
- attr.stack_mem = NULL;
- attr.stack_size = LED_TASK_STACK_SIZE;
- attr.priority = LED_TASK_PRIO;
- if (osThreadNew((osThreadFunc_t)LedTask, NULL, &attr) == NULL)
- printf("[LedExample] Falied to create LedTask!
- SYS_RUN(LedExampleEntry);
复制代码
