2020-11-14 18:35:01
上午给大家介绍了OLED是怎样点亮的:试用第三弹,点亮你的OLED
但是博主并比就此满足,感觉没有输出到有用的东西给到大家
这里用一个简单的demo教大家玩转你的OLED屏幕
先上最终效果图:
要实现这个效果首先要确定两个事情:要输入的文字和准备图片
准备要输入的文字:
用汉字取模程序,在这里贴上地址,大家自行下载:http://www.pc0359.cn/downinfo/110811.html
然后就是用取模软件把想取模的数组复制下来,如下:
把数组复制过来,形成一个数组
- #define font_size 16
- #define font_height 16
- #define font_width 16
- unsigned char hope_arr[][32] = {
- //当前汉字是:祝
- {0x00, 0x00, 0x00, 0x00, 0x0C, 0x00, 0x06, 0x18, 0x01, 0xFC, 0x0D, 0x98, 0x7C, 0xB0, 0x2C, 0xF0,
- 0x1E, 0xF0, 0x1E, 0xE0, 0x3D, 0xA1, 0x6D, 0x23, 0x0E, 0x3F, 0x08, 0x1E, 0x08, 0x00, 0x00, 0x00},
- //鸿
- {0x00, 0x00, 0x00, 0x30, 0x00, 0x30, 0x18, 0x78, 0x08, 0xFC, 0x0F, 0xE8, 0x76, 0xF8, 0x32, 0xF8,
- 0x0B, 0xD8, 0x1E, 0xFE, 0x30, 0xC6, 0x71, 0xFE, 0x23, 0x86, 0x00, 0x0E, 0x00, 0x0C, 0x00, 0x00},
- //蒙
- {0x00, 0x00, 0x00, 0x60, 0x06, 0x78, 0x1F, 0xF8, 0x02, 0x78, 0x1F, 0xFE, 0x17, 0xDC, 0x33, 0xE0,
- 0x0F, 0xE0, 0x0E, 0xE0, 0x1F, 0x80, 0x0F, 0xF0, 0x37, 0xBF, 0x1D, 0x88, 0x33, 0x80, 0x01, 0x00},
- //社
- {0x00, 0x00, 0x00, 0x00, 0x06, 0x30, 0x02, 0x30, 0x00, 0x30, 0x06, 0x30, 0x7E, 0x30, 0x2C, 0x7C,
- 0x0E, 0xF0, 0x1F, 0x30, 0x3C, 0x30, 0x2C, 0x3F, 0x0F, 0xFE, 0x0C, 0x00, 0x0C, 0x00, 0x00, 0x00},
- //区
- {0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x1F, 0xF0, 0x18, 0x70, 0x18, 0x60, 0x1B, 0xE0, 0x19, 0xE0,
- 0x18, 0xE0, 0x19, 0xF0, 0x1B, 0x30, 0x1E, 0x10, 0x1B, 0xFE, 0x1F, 0xFC, 0x00, 0x00, 0x00, 0x00},
- //越
- {0x00, 0x00, 0x00, 0x20, 0x06, 0x30, 0x06, 0x3C, 0x07, 0x36, 0x0F, 0x18, 0x07, 0xFC, 0x7E, 0x56,
- 0x77, 0x5C, 0x1F, 0x78, 0x3E, 0xFE, 0x26, 0x27, 0x63, 0xC2, 0x00, 0xFC, 0x00, 0x3F, 0x00, 0x00},
- //办
- {0x00, 0x00, 0x01, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0xF0, 0x0F, 0xF0, 0x05, 0xB0, 0x09, 0x30,
- 0x1B, 0x3E, 0x33, 0x36, 0x36, 0x32, 0x06, 0x20, 0x0D, 0xE0, 0x18, 0xE0, 0x00, 0xC0, 0x00, 0x00},
- //越
- //好
- {0x00, 0x00, 0x00, 0x00, 0x0C, 0x08, 0x0C, 0xFC, 0x0C, 0x5C, 0x0F, 0x30, 0x0F, 0x32, 0x7B, 0xFF,
- 0x1B, 0xF0, 0x0E, 0x18, 0x0E, 0x18, 0x0F, 0x18, 0x3B, 0x30, 0x20, 0x70, 0x00, 0x30, 0x00, 0x00},
- {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x38, 0x00, 0x18, 0x00, 0x30, 0x00},
- //蒸
- {0x00, 0x00, 0x04, 0x60, 0x06, 0x78, 0x3F, 0xFC, 0x12, 0xC0, 0x07, 0xF0, 0x02, 0xD8, 0x1F, 0xB0,
- 0x0D, 0xE0, 0x09, 0xB8, 0x1B, 0x9E, 0x2F, 0xE6, 0x04, 0xD8, 0x36, 0xCC, 0x32, 0x04, 0x00, 0x00},
- //蒸
- //日
- {0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x0F, 0xF0, 0x0E, 0x30, 0x04, 0x30, 0x04, 0x30, 0x07, 0xF0,
- 0x07, 0x30, 0x04, 0x30, 0x04, 0x30, 0x0F, 0xF0, 0x0E, 0x30, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00},
- //上
- {0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0xF8, 0x01, 0xE0,
- 0x01, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0x84, 0x3F, 0xFF, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00},
- 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x3C, 0x00, 0x36, 0x00, 0x3C, 0x00, 0x08, 0x00, 0x00, 0x00},
- //芝
- {0x00, 0x00, 0x00, 0x60, 0x06, 0x60, 0x07, 0xFC, 0x3F, 0xC0, 0x02, 0x40, 0x03, 0x80, 0x01, 0xF0,
- 0x0F, 0x60, 0x00, 0xC0, 0x03, 0x00, 0x0E, 0x00, 0x3F, 0x00, 0x01, 0xFF, 0x00, 0x3C, 0x00, 0x00},
- //麻
- {0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0xF0, 0x1F, 0xF0, 0x1A, 0x60, 0x1A, 0x38, 0x1B, 0xF8,
- 0x1F, 0x60, 0x17, 0x78, 0x37, 0xEC, 0x3B, 0xAF, 0x62, 0x20, 0x42, 0x60, 0x02, 0x20, 0x00, 0x00},
- //开
- {0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x0F, 0xF8, 0x0F, 0x60, 0x02, 0x60, 0x02, 0x7E, 0x7F, 0xFE,
- 0x32, 0x60, 0x06, 0x60, 0x06, 0x60, 0x04, 0x60, 0x0C, 0x60, 0x18, 0x60, 0x00, 0x60, 0x00, 0x00},
- //花
- {0x00, 0x00, 0x00, 0x60, 0x06, 0x60, 0x03, 0xFC, 0x3F, 0xE0, 0x02, 0x40, 0x06, 0xD8, 0x06, 0xD8,
- 0x0C, 0xF0, 0x0C, 0xE0, 0x1D, 0x80, 0x3E, 0x82, 0x4C, 0xC2, 0x0C, 0xFF, 0x0C, 0x7E, 0x00, 0x0},
- {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x00,
- 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
- //节
- {0x00, 0x00, 0x00, 0x30, 0x06, 0x24, 0x0F, 0xFE, 0x3E, 0x60, 0x02, 0x10, 0x03, 0xF8, 0x1F, 0x98,
- 0x01, 0x98, 0x01, 0x98, 0x01, 0x98, 0x01, 0xF8, 0x01, 0xB0, 0x01, 0x80, 0x01, 0x00, 0x01, 0x00},
- //节
- //高
- {0x00, 0x00, 0x01, 0x80, 0x00, 0xB8, 0x1F, 0xFC, 0x08, 0xE0, 0x07, 0xE0, 0x07, 0xC0, 0x03, 0x98,
- 0x3F, 0xFE, 0x38, 0xCC, 0x17, 0xEC, 0x17, 0xCC, 0x37, 0x8C, 0x30, 0x3C, 0x10, 0x1C, 0x00, 0x18},
复制代码
,到这里文字就做好了
准备要显示的图片:
先找一个图片(我这里用的微信的头像,主要是四四方方的感觉看着很爽)
然后把图片最好存成OLED屏幕分辨率以下的尺寸(win10自带的画图就能做到,具体方法不述)
,再到这个网址去转换:http://tools.clz.me/image-to-bitmap-array
把转换完的图片数组拷贝过来,如下图:
,最后形成一个数组,如下:
- // width: 64, height: 64
- const unsigned char picture_arr[] = {0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x30, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x30, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x30, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x30, 0xff, 0xff, 0xff, 0x80, 0x7f, 0xfc, 0x00, 0x30, 0xff, 0xff, 0xfe, 0x00, 0x1f, 0xfc, 0x00, 0x30, 0xff, 0xff, 0xfc, 0x00, 0x07, 0xff, 0x00, 0x30, 0xff, 0xff, 0xf8, 0x00, 0x07, 0xff, 0x00, 0x10, 0xff, 0xff, 0xf0, 0x00, 0x03, 0xff, 0x00, 0x30, 0xff, 0xff, 0xe0, 0x00, 0x01, 0xfd, 0x00, 0x30, 0xff, 0xff, 0xe0, 0x00, 0x01, 0xf8, 0x0c, 0x10, 0xff, 0xff, 0xc0, 0x00, 0x01, 0xf8, 0x01, 0xd0, 0xff, 0xff, 0xc0, 0x07, 0x00, 0xf8, 0x01, 0xc1, 0xff, 0xff, 0xc7, 0xff, 0x80, 0xf8, 0x01, 0x91, 0xff, 0xff, 0xcf, 0xff, 0x80, 0xf8, 0x03, 0xb9, 0xff, 0xff, 0xef, 0xff, 0xe0, 0xf8, 0x1f, 0x3b, 0xff, 0xff, 0xff, 0xfc, 0xf9, 0xf8, 0x00, 0x31, 0xff, 0xff, 0xff, 0xe0, 0xf9, 0x00, 0x08, 0x3a, 0xff, 0xff, 0xfc, 0x60, 0x7e, 0x00, 0x0c, 0x3b, 0xff, 0xff, 0xfc, 0x00, 0x7c, 0xc0, 0x0c, 0x79, 0xff, 0xff, 0xfc, 0x31, 0xff, 0xc1, 0x0e, 0xf8, 0xff, 0xff, 0xfc, 0x7f, 0xff, 0xf8, 0x0e, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0xfc, 0xe2, 0xff, 0xff, 0xff, 0xff, 0xff, 0xec, 0xbe, 0xf0, 0xff, 0xff, 0xff, 0xfd, 0xff, 0xe7, 0xee, 0x62, 0xff, 0xff, 0xff, 0x22, 0x3f, 0xff, 0xce, 0xf8, 0xff, 0xff, 0xff, 0xfe, 0x7e, 0xff, 0x0e, 0x98, 0xff, 0xff, 0xff, 0xf8, 0xfc, 0xff, 0x2d, 0x80, 0xff, 0xff, 0xff, 0x83, 0xfc, 0xff, 0xfd, 0xc0, 0xff, 0xff, 0xff, 0xe3, 0xb0, 0x1f, 0xf8, 0x80, 0xff, 0xff, 0xff, 0xff, 0x80, 0x3f, 0x00, 0x9f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x5e, 0x00, 0x9f, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x3a, 0x03, 0x81, 0xff, 0xff, 0xfb, 0xf0, 0x00, 0x1c, 0x01, 0x00, 0xff, 0xff, 0xf3, 0xf0, 0x00, 0x0c, 0x00, 0x07, 0xff, 0xff, 0xc7, 0xf8, 0x00, 0x5c, 0x00, 0x07, 0xff, 0xff, 0x87, 0xd8, 0x00, 0xfc, 0x00, 0x04, 0xff, 0xff, 0x87, 0xd0, 0x02, 0xfc, 0x00, 0x1c, 0xff, 0xff, 0x86, 0xc0, 0x03, 0xf8, 0x00, 0x18, 0xff, 0xff, 0x87, 0xc0, 0x03, 0xf8, 0x00, 0x38, 0xff, 0xff, 0x87, 0xc0, 0x03, 0xf0, 0x00, 0x18, 0xff, 0xff, 0x87, 0xc0, 0x07, 0xf0, 0x00, 0x00, 0xff, 0xff, 0x07, 0xc0, 0x07, 0xf0, 0x00, 0x00, 0xff, 0xff, 0x07, 0xc0, 0x07, 0xd0, 0x00, 0x00, 0xff, 0xff, 0x07, 0xc0, 0x07, 0xc0, 0x00, 0x00, 0xff, 0xff, 0x07, 0x80, 0x07, 0xc0, 0x00, 0x00, 0xff, 0xff, 0x03, 0x80, 0x07, 0xc0, 0x00, 0x0c, 0xff, 0xff, 0x03, 0x80, 0x05, 0xc0, 0x00, 0x00, 0xff, 0xff, 0x01, 0x80, 0x06, 0x00, 0x00, 0x10, 0xff, 0xff, 0x00, 0x80, 0x04, 0x00, 0x00, 0x10, 0xff, 0xff, 0x00, 0xc0, 0x07, 0x80, 0x00, 0x10, 0xff, 0xff, 0x00, 0x40, 0x00, 0x00, 0x00, 0x10, 0xff, 0xff, 0x00, 0x40, 0x00, 0x00, 0x00, 0x10, 0xff, 0xfc, 0x00, 0x40, 0x00, 0x00, 0x00, 0x08, 0xff, 0xfc, 0x00, 0x60, 0x00, 0x00, 0x00, 0x08, 0xff, 0xfc, 0x00, 0xf0, 0x00, 0x00, 0x00, 0x08, 0xff, 0xfc, 0x00, 0x7c, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xfc, 0x00, 0x7c, 0x00, 0x00, 0x00, 0x04, 0xff, 0xf8, 0x00, 0xff, 0x00, 0x00, 0x00, 0x04, 0xff, 0xf8, 0x00, 0xff, 0x80, 0x00, 0x00, 0x02, 0xff, 0xf0, 0x01, 0xff, 0x80, 0x00, 0x00, 0x02, 0xff, 0xf0, 0x03, 0xff, 0x80, 0x00, 0x00, 0x02, 0xff, 0xf0, 0x03, 0xff, 0xf8, 0x00, 0x00, 0x00, 0xff, 0xec, 0x03, 0xff, 0xf0, 0x00, 0x00, 0x00};
复制代码 到这里准备工作就完成了.
在代码里把文字区域填充文字和图片(利用官方的驱动):
- ssd1306_Fill(Black);
- ssd1306_SetCursor(0, 0);
- int x = 0;
- int y = 0;
- printf("hope_num =%d
- ", hope_num);
- // int start_num = text_alredy_show * text_per_line_num;
- int showed_num = 0;
- for (int i = text_alredy_show; i < hope_num; i++)
- ssd1306_DrawRegion(x, y, font_height, font_width, hope_arr[i], sizeof(hope_arr[0]), 0);
- x += font_width;
- if (x >= text_area_width)
- y += font_height;
- x = 0;
- showed_num++;
- if (y >= text_area_height)
- break;
- ssd1306_DrawRegion(64, 0, 64, 64, picture_arr, sizeof(picture_arr), 0);
- ssd1306_UpdateScreen();
复制代码 然后把程序下载进去就可以看到效果了
当然如果想玩的更爽一点那就是动态文字了:进阶版视频如下:
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。
侵权投诉
