发 帖
原厂入驻New
85131F网络分析仪电缆库存出售
2020-11-4 09:54:43  24
分享
85131F
Agilent Flexible Cable Set, 3.5 mm (Test Port) to 3.5 mm
The Agilent 85131F is a 62.2 cm (24.5 in) long1 flexible cable set composed of a 3.5 mm female2 to PSC-3.5 mm female connector and a 3.5 mm
female2 to a 3.5 mm male connector. Cable frequency range is dc to 26.5 GHz with a return loss greater than or equal to 16 dB. Insertion loss is 0.25 * sqrt(f) + 0.2 dB, where f is frequency in GHz, for the test port connector and 1.5 dB at maximum frequency for the device connector. Phase stability of semi-rigid/flexible cables is specified with a 90 degree bend using a 4 to 3 inch radius. Stability1 of the Agilent 85131F is less than 0.12 dB and phase is 0.13 * f + 0.5, where f is frequency in GHz.
1 Cable length and stability are supplemental characteristics.
2 Special rugged female connector is designed specifically for connecting to the network analyzer test port, but does not mate with a standard male connector.
2020-11-4 09:54:43   评论 分享淘帖
高级模式
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
发表新帖
关闭
站长推荐 上一条 /9 下一条
快速回复 返回顶部 返回列表
