N9030B 是德N9030B PXA 信号分析仪,多点触控,3 Hz 至 50 GHz Keysight Technologies N9030B PXA X-Series Signal Analyzer, Multi-touch 主要特性和功能 搭配从优秀到卓越的测量选件,可以加速要求苛刻的应用领域中的创新。 通过是德科技智能混频器可将频率扩展到 110 GHz 使用实时频谱分析功能捕获瞬态信号或间歇信号 X 系列应用软件可以简化特定应用的测试 89600 VSA 软件可实现更深层次的故障诊断 选件 Frequency options N9030B-503 Frequency Range, 3 Hz to 3.6 GHz N9030B-508 Frequency Range, 3 Hz to 8.4 GHz N9030B-513 Frequency Range, 3 Hz to 13.6 GHz N9030B-526 Frequency Range, 3 Hz to 26.5 GHz N9030B-544 Frequency Range, 3 Hz to 44 GHz N9030B-550 Frequency Range, 3 Hz to 50 GHz Preamplifier options N9030B-P03 Preamplifier, 3.6 GHz N9030B-P08 Preamplifier, 8.4 GHz N9030B-P13 Preamplifier, 13.6 GHz N9030B-P26 Preamplifier, 26.5 GHz N9030B-P44 Preamplifier, 44 GHz N9030B-P50 Preamplifier, 50 GHz Bandwidth options N9030B-B2X 分析带宽,255 MHz N9030B-B40 Analysis Bandwidth, 40 MHz N9030B-B1X Analysis Bandwidth, 160 MHz N9030B-B85 Analysis Bandwidth, 85 MHz N9030B-B5X 分析带宽,510 MHz Performance Options N9030B-EA3 Electronic Attenuator, 3.6 GHz, Upgrade N9030B-EDP Enhanced Display Package License N9030B-EMC Basic EMC Functionality License N9030B-FP2 Fast Power, up to 40 MHz Bandwidth N9030B-FT1 Frequency Mask Trigger, Basic Detection License N9030B-FT2 Frequency Mask Trigger, Optimum Detection License N9030B-LNP Low Noise Path N9030B-MPB Microwave Preselector Bypass N9030B-RTS Real-Time Wideband I/Q Data Streaming N9030B-TDS Time Domain Scan N9030B-EP0 增强的相位噪声 DDS LO N9030B-DUA Duplex IF RTSA N9030B-RBE Resolution Bandwidth Extended Baseband Inputs N9030B-BBA I/Q Baseband Inputs, Analog Calibration Options N9030B-A6J ANSI Z540-1-1994 Calibration N9030B-AMG Calibration + Uncertainties + Guardbanding (Accredited) N9030B-UK6 Commercial Calibration Certificate with Test Data Connector Options N9030B-ALV Auxiliary Log Video Output N9030B-C35 APC 3.5 mm Connector N9030B-CR3 Connector, Wideband IF Output Upgrade N9030B-CRP Connector Rear, Programmable IF Output N9030B-YAV Y-Axis Video Output External Mixing N9030B-EXM External Mixing Real time signal analysis N9030B-RT1 Real-time analysis up to maximum available BW, basic detection license N9030B-RT2 Real-time analysis up to maximum available BW, optimum detection, license Security - PC Features N9030B-SF1 Security Features, Exclude Launching Programs N9030B-SF2 Security Features, Prohibit Saving Results N9030B-SSD Additional Removable Solid State Drive Source Connectivity N9030B-ESC External Source Control Application Software 89601B - 89600 VSA 软件 N6171A matlab 软件 N9063C 模拟解调测量应用软件,多点触控用户界面 N9068C Phase Noise Measurement Application, Multi-touch UI N9069C 噪声系数测量应用软件,多点触控用户界面 N9071C GSM / EDGE / Evo Measurement Application, Multi-Touch UI N9073C W-CDMA/HSPA/HSPA+ Measurement Application, Multi-touch UI N9077C WLAN 802.11a/b/g/j/p/n/ac/af/ah/ax Measurement Application, Multi-Touch UI N9080C LTE/LTE-Advanced FDD 测量应用软件,多点触控用户界面 N9082C LTE / LTE-Advanced TDD Measurement Application, Multi-touch UI N9081C Bluetooth Measurement Application, Multi-Touch UI N9084C Short Range Communications Measurement Application, Multi-Touch UI N9067C Pulse Measurement Application, Multi-touch UI N6141C EMI Measurement Application, Multi-Touch UI N9054C VMA 矢量调制分析应用软件,多点触控用户界面 N9061C Remote Language Compatibility Application, Multi-Touch UI Real Time Recorder N9030B-RTR Real-Time Spectrum Recorder and Analyzer Application Example, License Accessories 1CM113A Rack mount flange kit 177.0mm H (4U) - two flange brackets, 2015 color 1CN103A Handle kit 177.0mm H (4U) - two front handles, 2015 color 1CP105A Rack mount flange and handle kit 177.0mm H (4U) - two brackets and front handles 1DVR001A ROM/CD-R/RW drive 1KBD001A USB keyboard-smaller keyboard 1MSE001A Mouse MLP001A Minimum loss pad, 50 to 75 ohm 1CR014A Rack Slide Kit for 17-inch and 20-inch Mounting Holes Additional Documentation N9030B-AB2 Chinese localization, user interface and getting started guide N9030B-ABE Spanish localization, user interface and getting started guide N9030B-ABF French localization, user interface and getting started guide N9030B-ABJ Japanese localization, user interface and getting started guide N9030B-AKT Russian localization, user interface and getting started guide N9030B-AB1 Korean localization, user interface and getting started guide |
相关推荐 |
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
1488 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
402 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
967 浏览 0 评论
2474 浏览 3 评论
1052 浏览 1 评论
GMT+8, 2024-4-23 18:01 , Processed in 0.598940 second(s), Total 65, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
