发 帖
原厂入驻New
34972A数据采集器库存出售
2020-9-23 10:07:04  29
分享
34972A
Agilent 34972A agilent 34972A agilent 34972A agilent 34972A agilent 34972A agilent 34972A
Key Features & Specifications
  • 3-slot LXI data acquisition unit with 6 ½-digit DMM (22-bit) and 8 plug-in modules to choose from
  • Measures 11 different input signals including temperature with thermocouples, RTDs and thermistors; DC/AC volts or current; 2- or 4-wire resistance; frequency and period
  • Ac c epts all 34970A switch and control plug-in modules, and is backward c o mpatible with the 34970A SCPI c o mmand set
  • 1Gbit LAN and USB 2.0 for easy connectivity to the PC
  • USB memory port for data storage or transfer
  • Graphical Web inteRFace for easy set up and control
  • Free BenchLink data logger soft w are to create tests without programming
Description
The keysight 34972A Data Acquisition / Data Logger Switch Unit consists of a 3-slot mainframe with a built-in 6 ½ digit DMM and 8 different switch & control modules. This product features built-in LAN and USB interfaces so you can easily connect to a PC or laptop without needing to purchase additional IO cards or converter interfaces. The intuitive graphical Web interface offers easy remote control over the n e t w ork with per channel measurement configuration, data logging and data monitoring. With the 34972A, there is no c o mputer required for field applications. Use a USB flash drive to upload data logging configurations from BenchLink Data Logger into the 34972A and to transfer large data sets back to the c o mputer. Simply connect the USB stick to your PC when you return and easily import into a spreadsheet or other applications for data analysis.
The 34972A can ac c ept any of the 34970A plug-in modules. With a simple address change the 34972A is easily integrated into an existing test with no wiring or hardware changes. The plug-in modules also feature0n-board screw terminals and relay closure count so you can create a c o mpact data logger, full-featured data acquisition system or low-cost switching unit that is easy to connect, configure and use0n the bench,0n a n e t w ork or in field applications.
2020-9-23 10:07:04   评论 分享淘帖
高级模式
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
发表新帖
关闭
站长推荐 上一条 /8 下一条
快速回复 返回顶部 返回列表
