IT6263简介
这颗芯片功能是LVDS转HDMI General Description The IT6263 is a high-performance single-chip De-SSC LVDS to HDMI converter. Combined with LVDS receiver and HDMI 1.4a Transmitter, the IT6263 supports LVDS input and HDMI1.4 output by conversion function. The build-in LVDS receiver can support single-link and dual-link LVDS inputs, and the build-in HDMI transmitter is fully compliant with HDMI 1.4a/3D, HDCP 1.2 and backward compatible with DVI 1.0 specification. With high speed LVDS RX, the IT6263 can support resolution up to 1080P and UXGA and 10-bit deep colors. The IT6263 also supports all the HDMI 1.4a 3D mandatory formats which are compliant with HDMI1.4a 3D Specification In order to reduce the EMI noise on legacy system application, the traditional LVDS source will transmit differential signals with spread spectrum, but this spread spectrum does not be allowed for HDMI protocol. The IT6263 also build-in unique De-SSC ( De-Spread Spectrum ) function , it can help customers easily to adopt the IT6263 on the EMI-concerned platform, with SSC has been generated from LVDS source processors. The IT6263 also encodes and transmits up to 8 channels of I2S digital audio, with sampling rate up to 192kHz and sample size up to 24 bits. In addition, an S/PDIF input port takes in compressed audio of up to 192kHz frame rate. The newly supported High-Bit Rate (HBR) audio by HDMI Specifications v1.3 is provided by the IT6263 in two interfaces: with the four I2S input ports or the S/PDIF input port. With both interfaces the highest possible HBR frame rate is supported at up to 768kHz. Each IT6263 chip comes preprogrammed with an unique HDCP key, in compliance with the HDCP 1.2 standard so as to provide secure transmission of high-definition content. Users of the IT6263 need not purchase any HDCP keys or ROMs. The single chip IT6263 provides high performance, cost effective, LVDS2HDMI conversion function, and it can be applied to IP TV STBs and Scaler Boxs which need small size video outputs. [img]blob:https://bbs.elecfans.com/6e47bd78-051a-47a6-ab53-a73198387425[/img] |
楼主多多分享!
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
1488 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
402 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
967 浏览 0 评论
2474 浏览 3 评论
1053 浏览 1 评论
GMT+8, 2024-4-24 07:27 , Processed in 0.420215 second(s), Total 39, Slave 29 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
