[文章] 鸿蒙OS 注册UART驱动入口
前天 15:54  49 鸿蒙系统 UART
分享
注册UART驱动入口。
基于HDF框架注册UART驱动的入口HdfDriverEntry,代码如下:
// 绑定UART驱动接口到HDF框架
static int32_t HdfUartSampleBind(structHdfDeviceObject *device)
   IF (device == NULL) {
       return HDF_ERR_INVALID_OBJECT;
   HDF_LOGI("Enter %s:", __func__);
   return (UartHostCreate(device) == NULL) ? HDF_FAILURE : HDF_SUCCESS;
// 从UART驱动的HCS中获取配置信息
static uint32_t UartDeviceGetResource(
   struct UartDevice *device, const struct DeviceResourceNode*resourceNode)
    struct UartResource *resource =&device->resource;
   struct DeviceResourceIface *dri = NULL;
   dri = DeviceResourceGetIfaceInstance(HDF_CONFIG_SOURCE);
   if (dri == NULL || dri->GetUint32 == NULL) {
       HDF_LOGE("DeviceResourceIface is invalid");
       return HDF_FAILURE;
   if (dri->GetUint32(resourceNode, "num",&resource->num, 0) != HDF_SUCCESS) {
       HDF_LOGE("uart config  readnum fail");
       return HDF_FAILURE;
   if (dri->GetUint32(resourceNode, "base", &resource->base,0) != HDF_SUCCESS) {
       HDF_LOGE("uart config  readbase fail");
       return HDF_FAILURE;
   resource->physBase = (unsigned long) OsalIoRemap(resource->base,0x48);
   if (resource->physBase == 0) {
       HDF_LOGE("uart config fail to remap physBase");
       return HDF_FAILURE;
   if (dri->GetUint32(resourceNode, "irqNum",&resource->irqNum, 0) != HDF_SUCCESS) {
       HDF_LOGE("uart config read irqNum fail");
       return HDF_FAILURE;
   if (dri->GetUint32(resourceNode, "baudrate",&resource->baudrate, 0) != HDF_SUCCESS) {
       HDF_LOGE("uart config  readbaudrate fail");
       return HDF_FAILURE;
   if (dri->GetUint32(resourceNode, "wlen",&resource->wlen, 0) != HDF_SUCCESS) {
       HDF_LOGE("uart config  readwlen fail");
       return HDF_FAILURE;
   if (dri->GetUint32(resourceNode, "parity",&resource->parity, 0) != HDF_SUCCESS) {
       HDF_LOGE("uart config  readparity fail");
       return HDF_FAILURE;
   if (dri->GetUint32(resourceNode, "stopBit",&resource->stopBit, 0) != HDF_SUCCESS) {
       HDF_LOGE("uart config  readstopBit fail");
       return HDF_FAILURE;
   if (dri->GetUint32(resourceNode, "uartClk",&resource->uartClk, 0) != HDF_SUCCESS) {
       HDF_LOGE("uart config  readuartClk fail");
       return HDF_FAILURE;
   return HDF_SUCCESS;
// 将UART驱动的配置和接口附加到HDF驱动框架
static int32_t SampleAttach(struct UartHost*host, struct HdfDeviceObject *device)
   int32_t ret;
   struct UartDevice *uartDevice = NULL;
   if (device->property == NULL) {
       HDF_LOGE("%s: property is NULL", __func__);
       return HDF_FAILURE;
   uartDevice = (struct UartDevice *) OsalMemCalloc(sizeof(struct UartDevice));
   if (uartDevice == NULL) {
       HDF_LOGE("%s: OsalMemCalloc uartDevice error", __func__);
       return HDF_ERR_MALLOC_FAIL;
   ret = UartDeviceGetResource(uartDevice, device->property);
   if (ret != HDF_SUCCESS) {
       (void) OsalMemFree(uartDevice);
       return HDF_FAILURE;
   host->num = uartDevice->resource.num;
   host->priv = uartDevice;
   UartSampleAddDev(host); // 添加用户态UART设备节点,具体实现见源码uart_dev_sample
   return UartDeviceInit(uartDevice); // 初始化UART PL011,具体实现见源码uart_pl011_sample
// 初始化UART驱动
static int32_t HdfUartSampleInit(structHdfDeviceObject *device)
   int32_t ret;
   struct UartHost *host = NULL;
   if (device == NULL) {
       HDF_LOGE("%s: device is NULL", __func__);
   host = UartHostFromDevice(device);
   if (host == NULL) {
       HDF_LOGE("%s: host is NULL", __func__);
       return HDF_FAILURE;
   ret = SampleAttach(host, device);
       HDF_LOGE("%s: attach error", __func__);
       return HDF_FAILURE;
   host->method = &g_uartSampleHostMethod;
   return ret;
static void UartDeviceDeinit(structUartDevice *device)
   struct UartRegisterMap *regMap = (struct UartRegisterMap *)device->resource.physBase;
   /* wait for uart enter idle. */
   while (UartPl011IsBusy(regMap));
   UartPl011ResetRegisters(regMap);
   uart_clk_cfg(0, false);
   OsalIoUnmap((void *) device->resource.physBase);
   device->state = UART_DEVICE_UNINITIALIZED;
// 解绑并释放UART驱动
static void SampLEDetach(struct UartHost*host)
   if (host->priv == NULL) {
       HDF_LOGE("%s: invalid parameter", __func__);
       return;
   uartDevice = host->priv;
   UartDeviceDeinit(uartDevice);
   host->priv = NULL;
// 释放UART驱动
static void HdfUartSampleRelease(structHdfDeviceObject *device)
       HDF_LOGE("%s: device is null", __func__);
       return;
   if (host == NULL) {
       HDF_LOGE("%s: host is null", __func__);
       return;
   if (host->priv != NULL) {
       SampleDetach(host);
   UartHostDestroy(host);
struct HdfDriverEntry g_hdfUartSample = {
   .moduleVersion = 1,
   .moduleName = "UART_SAMPLE",
   .Bind = HdfUartSampleBind,
   .Init = HdfUartSampleInit,
   .Release = HdfUartSampleRelease,
HDF_INIT(g_hdfUartSample);
作者:疯壳
注:文档和视频中所有的图片及代码截图皆为示意图,具体以HarmonyOS官网发布内容为准。
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
