发 帖
原厂入驻New
N5173B信号发生器库存出售
2020-9-8 11:55:33  19
分享
N5173B
N5173B EXG X-Series microwave analog Signal Generator, up to 40 GHz
主要特性与技术指标
Signal characteristics
9 kHz to 13, 20, 31.8 or 40 GHz
+20 dBm output power at 20 GHz
-101 dBc/Hz phase noise at 10 GHz and 20 kHz offset
High stability OCXO < ±5 x 10-10 per day
Modulation and sweep
AM, FM, ØM and narrow pulse
Pulse train generator
10 MHz multifunction generator and LF out
Digital step and list sweep modes with <600 µs switching speed
Automation and communication inteRFace
1000BaseT LAN, LXI, USB 2.0, and GPIB
SCPI, IVI-COM, matlab drivers
Backward compatible with all ESG, MXG, PSG and 8648x signal generators
Agilent USB power sensor compatible with embedded display and SCPI control
The cost-effective EXG
When you need to balance budget and performance the EXG is the best choice. It provides the essential signals that address parametric testing of components and receivers.
Maximize budget and performance with outstanding hardware
Confidently test components with excellent level accuracy and repeatability
Compensate for test system losses with best-in-class output power
Maximize throughput with fast switching speed
Shrink your test stand with two rack-unit height
Get the performance and capabilities you need today and easily upgrade later
Maximize resources with low cost of ownership
Increase uptime with high mean time between failures (MTBF) based on first-generation MXG track record
Minimize downtime and expenses with self-maintenance strategy and low-cost repairs
Standard 3-year calibration cycle and warranty
2020-9-8 11:55:33   评论 分享淘帖
高级模式
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
发表新帖
关闭
站长推荐 上一条 /7 下一条
快速回复 返回顶部 返回列表
