发 帖
原厂入驻New
IQVIEWWIFI测试仪库存出售
2020-9-7 09:52:08  23
分享
IQVIEW
IQView|Litepoint|WIFI|无线网络综合测试仪|WIFI测试仪
The LitePoint IQview® 802.11a/b/g/n WLAN R&D Test Solution is a popular test instrument for RF testing of 802.11a/b/g WLAN products, including MIMO and optional Bluetooth + EDR. Network interface cards, access points and embedded components are typically tested using this product.
Features
-- Seamless analysis of DSSS (802.11b/g) and OFDM (802.11a/g) WLAN signals
-- Advanced VSA and VSG combined with the capabilities of a power meter and spectrum analyzer in a single instrument
-- Operation in both 2.4 GHz and 5 GHz bands
-- Baseband I/O facilitates product debugging with LitePoint IQdebug™ Monitor and Control Tool
-- High-performance VSA
* Wide bandwidth (±33 MHz)
* Capture-once-measure-all operation
* High phase linearity, low phase noise, low noise figure
* Graphical and numerical display of measurement results
-- High-performance VSG
* Low noise figure
* Pre-defined 802.11a/b/g transmit test signals
* Impairments can be introduced in real- time to the transmit test signal
* Generation of arbitrary 802.11a/b/g waveforms simplified by optional IQwave WLAN Waveform Generator Software
-- Simple control interfaces
* IQsignal Signal Analysis Software Suite facilitates signal analysis, signal generation, and debugging
* LitePoint API (IQapi™) supports Visual C/C++ test scripts for use in manufacturing
Benefits
-- Faster test time
* Test time reduced by from minutes per device to seconds compared to separate instruments for VSA, spectrum analyzer and power meter
* Independent simultaneous Rx and Tx measurements
* Support for dual-head test functionality
-- Faster time to production
* Intuitive user interface means no learning curve
* No complicated test set-up or calibration; tests are pre-configured
* Easy to re-configure manufacturing stations to test different chipsets
* Consistent test results across R&D and manufacturing for quick identification and fix of problems
-- Consistent quality and performance assured
* Direct measurement of transmitter performance using EVM and other signal quality metrics
* Efficient and repeatable measurements
* Ability to capture, analyze and debug raw signal data0n any PC
-- Capital investment protected
* One-box tester solution eliminates need for multiple test products
* No other equipment or software required
* Software upgrades ensure compliance with standards changes
System Requirements
-- PC: Intel® Pentium® Processor or compatible
-- Operating system: microsoft Windows 2000; Windows XP Professional; Windows XP Home Edition
-- Memory: 128MB of RAM
-- Disk space: 200MB of available hard disk space
-- Monitor: 1024 x 768 resolution
-- Connectivity: TCP/IP over 10/100BaseT Ethernet
2020-9-7 09:52:08   评论 分享淘帖
高级模式
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
发表新帖
关闭
站长推荐 上一条 /7 下一条
快速回复 返回顶部 返回列表
