发 帖
原厂入驻New
FSEA30频谱分析仪操作说明
2020-9-4 16:36:47  14
分享
FSEA30
二手仪器FSEA30,二手频谱仪FSEA30,FSEA30|Rohde&Schwarz|3G|频谱分析仪|罗德与施瓦茨|20Hz至3.5GHz
厂商名称:德国罗德与施瓦茨Rohde&Schwarz R&S
频率范围:
FSEA20 9kHz to 3.5GHz
FSEA30 20Hz to3.5GHz
特性
频率精度0.01Hz;
分辨率带宽1Hz 10Hz to 10MHz
显示噪底-153dB
3阶截距点>+15dBm
射频输入的1dB压缩点>+10dBm
20kHz的载波相位噪声降至-123dBc
互解调动态范围110dB
测量不确定度达到1GHz:1dB
内置射频触发器(ID-935993192199174)
动态范围:-90 dBm;
相位噪声:at 10kHz offset -96dBc; at 100kHz offset-119dBc;
接头:N(f)
阻抗:50 ohm
技术指标
The Rohde & Schwarz, Inc. FSEA30 spectrum analyzer is a wide band, very sensitive receiver. It works0n the principle of 'super-heterodyne receiver' to convert higher frequencies (normally ranging up to several 10s of GHz) to measurable quantities. The received frequency spectrum is slowly swept through a range of pre-selected frequencies, converting the selected frequency to a measurable DC level (usually logarithmic scale), and displaying the same0n the CRT of the Rohde & Schwarz, Inc. FSEA30. The CRT displays received signal strength (y-axis) against frequency ( x-axis).
2020-9-4 16:36:47   评论 分享淘帖
高级模式
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
发表新帖
关闭
站长推荐 上一条 /7 下一条
快速回复 返回顶部 返回列表
