发 帖
原厂入驻New
[供应] 5962-9201301MEA
2020-9-4 10:29:41  100 单片机 数模转换器 模数转换器 FPGA 放大器
分享
  5962-88670043A(cypress)
                SPLD PAL Family 800 Gates 10 Macro Cells 41.6MHz 5V 28-Pin CLLCC品牌e2v详细资料SPLD"
                    5962-8984102LA(CYPRESS)
                SPLD 800 Gates 10 Macro Cells 83.3MHz 5V 24-Pin CDIP品牌e2v详细资料SPLD"
                    5962-8867003LA(CYPRESS)
                SPLD AT22V10 Family 10 Macro Cells 5V 24-Pin CDIP品牌e2v详细资料SPLD"
                    5962-89839022A(lattice)
                SPLD GAL Family 8 Macro Cells 41.6MHz 5V 20-Pin CLLCC品牌e2v详细资料SPLD"
                    5962-8768407MUA()
                MCU 8-bit 80C51 CISC 4KB EPROM 5V 44-Pin CLLCC品牌e2v详细资料microcontroller"
                    5962-8751505LA(ST)
                EPROM UV 64K-bit 8K x 8 45ns 24-Pin Windowed CDIP品牌e2v详细资料EPROM"
                    5962-8766105XA()
                EPROM UV 128K-bit 16K x 8 200ns 28-Pin CDIP品牌e2v详细资料EPROM"
                    5962-8776001B2A(NSC)
                Buffer/Line Driver 8-CH Non-Inverting 3-ST CMOS 20-Pin CLLCC品牌e2v详细资料Buffers and Line Drivers"
                    5962-8751512LA(CYPRESS)
                EPROM UV 64K-bit 8K x 8 25ns 24-Pin Windowed CDIP品牌e2v详细资料EPROM"
                    5962-8948403MXA(CYPRESS)
                EPROM UV 64K-bit 8K x 8 15ns 28-Pin CDIP品牌e2v详细资料EPROM"
                    5962-8981701XA(CYPRESS)
                EPROM UV 256K-bit 32K x 8 55ns 28-Pin Windowed CDIP品牌e2v详细资料EPROM"
                    5962-8968801EA()
                Multiplexer 1-Element CMOS 8-IN 16-Pin CDIP品牌e2v详细资料Multiplexers"
                    5962-9218901MSA(NSC)
                Flip Flop D-Type Bus InteRFace Pos-Edge 3-ST 1-Element 20-Pin CFPAK品牌e2v详细资料Flip Flops"
                    5962-8959901EA(NSC)
                Multiplexer 1-Element CMOS 3-ST 8-IN 16-Pin CDIP品牌e2v详细资料Multiplexers"
                    5962-8976601RA(IDT)
                Buffer/Line Driver 8-CH Non-Inverting 3-ST CMOS 20-Pin CDIP品牌e2v详细资料Buffers and Line Drivers"
                    59629453202MYA
                MPU 80860 RISC 64bit 33MHz 196-Pin CQFP品牌Intel详细资料Microprocessor"
                    59629094601MYA
                MPU MQ80960MC RISC 32bit 16MHz 164-Pin LCC品牌Intel详细资料Microprocessor"
                    5962-8687201DA(NSC)
                NAND Gate 4-Element 2-IN Bipolar 14-Pin CFPAK品牌e2v详细资料Gates"
                    5962-8606301XA()
                EPROM UV 256K-bit 32K x 8 200ns 28-Pin CDIP品牌e2v详细资料EPROM"
                    5962-1722001VXC
                Current Limit SW 4-IN 4-OUT 1.5V to 7V 6A 16-Pin CFP Tube品牌TI详细资料Current Limit Switches"
                    5962R1422801VXC
                DDR Termination Regulator 2.375V to 3.5V 16-Pin CFPAK Tube品牌TI详细资料Special Purpose Voltage Regulators"
                    5962R1721801VXC
                Temp Sensor Digital Serial (2-Wire, SMbus) 10-Pin CFPAK Tube品牌TI详细资料Temperature and Humidity Sensors"
                    5962P8768105VYC
                Current Mode PWM Controller 100mA 1000kHz 16-Pin CFPAK Tube品牌TI详细资料Current Mode PWM Controllers"
                    5962-8753903LA(CYPRESS)
                5962-8753903LA(CYPRESS)品牌e2v详细资料Unclassified"
                    5962-8981501LA(CYPRESS)
                EPROM UV 16K-bit 2K x 8 35ns 24-Pin Windowed CDIP品牌e2v详细资料Unclassified"
                    5962-8960101M2A()
                Flip Flop D-Type Bus Interface Pos-Edge 3-ST 1-Element 20-Pin CLLCC品牌e2v详细资料Unclassified"
                    5962-8984003LA(LATTICE)
                SPLD 50MHz 5V 24-Pin CDIP品牌e2v详细资料Unclassified"
                    5962-9096503MTA(MSC)
                5962-9096503MTA(MSC)品牌Microsemi详细资料Unclassified"
                    5962-8973401DA(NSC)
                5962-8973401DA(NSC)品牌e2v详细资料Unclassified"
                    5962-8983909RA(CYPRESS)
                SPLD PAL Family 8 Macro Cells 62.5MHz 5V 20-Pin CDIP品牌e2v详细资料Unclassified"
                    5962-8996702M3A(CYPRESS)
                5962-8996702M3A(CYPRESS)品牌e2v详细资料Unclassified"
                    5962-8767401PA(NSC)
                Comparator Single ±6.5V 8-Pin CDIP品牌e2v详细资料Unclassified"
"5962-8986302YA
                FIFO Mem Async Single Uni-Dir 512 x 9 28-Pin CDIP品牌e2v详细资料FIFO"
"5962-89839022A
                SPLD 8 Macro Cells 41.6MHz 5V 20-Pin LCC品牌Lattice 详细资料SPLD"
"5962-8671101XA
                V-Ref Precision 1.22V 20mA 2-Pin TO-46 Tray品牌TI详细资料Voltage References"
"5962F7802301MFA
                Quad Transmitter RS-422 16-Pin CPAK品牌TI详细资料Bus Line Transceivers"
"5962F7802301MEA
                Quad Transmitter RS-422 16-Pin CDIP品牌TI详细资料Bus Line Transceivers"
"5962-9759901QZC
                CPLD 3.2K Gates 128 Macro Cells 5V 160-Pin CQFP品牌Cypress详细资料CPLD"
"5962-8867005KA
                SPLD AT22V10 Family 800 Gates 10 Macro Cells 33.3MHz CMOS  5V 24-Pin CFPAK品牌Cypress详细资料SPLD"
"5962-89728012A
                V-Ref Programmable ±5V/±10V 20-Pin CLLCC Tube品牌AD详细资料Voltage References"
"5962-8686103XA
                V-Ref Precision 2.5V 3-Pin TO-52 Tube品牌AD详细资料Voltage References"
"5962-9313101M2A
                Video Amp Single ±18V 20-Pin CLLCC Tube品牌AD详细资料Video Amplifier"
"5962-8773802PA
                Op Amp Single Ultra Low Offset Voltage Amplifier ±22V 8-Pin CDIP Tube品牌AD详细资料Op Amps"
"5962-8964401PA
                Op Amp Single High Speed Amplifier ±18V 8-Pin CDIP Tube品牌AD详细资料Op Amps"
"5962-8867004KA
"5962-8871902MXA
                DAC 4-CH R-2R 12-bit 28-Pin CDIP Tube品牌AD详细资料DAC"
"5962-87624012A
                Inverter Schmitt trigger 6-Element CMOS 20-Pin CLLCC Tube品牌TI详细资料Inverters and Schmitt Triggers"
"5962-8982402PA
                V-Ref Precision 5V 10mA 8-Pin CDIP Tube品牌AD详细资料Voltage References"
"5962-3812801M2A
                V-Ref Programmable 2.5V/5V/7.5V/10V 10mA 20-Pin CLCC品牌AD详细资料Voltage References"
"5962-8685001EA
                Shift Register Single 4-Bit Serial/Parallel to Parallel 16-Pin DIP品牌NXP s详细资料Counter Shift Registers"
"5962-9312901MPA
"5962-9206201MYC
                CPLD 192 Macro Cells 0.8um  5V 84-Pin Windowed PGA品牌Cypress详细资料CPLD"
"5962-9176402MXA
"5962-8850502RA
                1-Channel Single ADC SAR 8-bit Parallel 20-Pin SBCDIP Tube品牌AD详细资料ADC"
"5962-3812802M2A
"5962-9558101QJA
                Decoder/Demultiplexer Single 4-to-16 24-Pin CDIP Tube品牌TI详细资料Decoders and Demuxes"
"5962- 9314003HPC
                OptoCoupler 1-CH 8-Pin CDIP品牌Micropac Industries详细资料OptoCoupler"
"5962-9759802QXC
                CPLD FLASH370 Family 128 Macro Cells 5V品牌Cypress详细资料CPLD"
"5962-8770003EA
                DAC 1-CH Segment 8-bit 16-Pin CDIP Tube品牌AD详细资料DAC"
"5962-9952601QZC
                CPLD Ultra37000 Family 15K Gates 512 Macro Cells 66MHz 5V 208-Pin CQFP品牌Cypress详细资料CPLD"
"59629232404MYA
                NVRAM NVSRAM Parallel 64Kbit 5V 28-Pin CLLCC Tube品牌Cypress详细资料NVRAM"
"5962-0620801QXC
                DSP Fixed-Point 32bit 150MHz 150MIPS 172-Pin CFPAK Tray品牌TI详细资料DSP"
"5962-9457203MPA
                SP Amp Variable Gain Amp Single ±5.25V 8-Pin CDIP Tube品牌AD详细资料Special Purpose Amplifiers"
"5962-8953201XA
                UART 2-CH 5V 28-Pin CDIP品牌e2v详细资料UARTs"
"5962-9052201GA
                Pref DRVR Dual 4.5V to 15V 787mW 8-Pin CAN品牌e2v详细资料Peripheral Driver"
"5962-8506403MMA
                MCU 8-bit CISC ROMLess 3.3V/5V 44-Pin CLCC品牌e2v详细资料Microcontroller"
"5962-8866204NA
                SRAM Chip Async Single 5V 256K-bit 32K x 8 45ns 28-Pin CDIP品牌e2v详细资料SRAM Chip"
"5962-8606305XA
                EPROM UV 256K-bit 32K x 8 150ns 28-Pin CDIP品牌e2v详细资料EPROM"
"5962-9175204MXA
                EPROM UV 4M-bit 512K x 8 150ns 32-Pin CDIP品牌e2v详细资料EPROM"
"5962-8700301CA
                MICROCIRCUIT, linear, TONE DECODER/PHASE LOCKED LOOP, MONOLITHIC SILICON品牌NXP s详细资料Decoders and Demuxes"
"5962-9314801M2A
                Flip Flop D-Type Bus Interface Pos-Edge 1-Element 20-Pin LCC品牌NXP s详细资料Flip Flops"
"5962-9154504MYA
                CPLD ATv2500B Family 24 Macro Cells 58MHz 0.65um, CMOS  5V 44-Pin LCC品牌e2v详细资料CPLD"
"5962-8975504LA
                SPLD AT22V10 Family 10 Macro Cells 50MHz 5V 24-Pin CDIP品牌microchip 详细资料SPLD"
"5962-88724013A
                SPLD AT22V10 Family 10 Macro Cells 41.6MHz 5V 28-Pin CLLCC品牌Microchip 详细资料SPLD"
"5962-8751508LA
                EPROM UV 64K-bit 8K x 8 35ns 24-Pin CDIP品牌e2v详细资料EPROM"
"5962-88734023A
                EPROM UV 16K-bit 2K x 8 35ns 28-Pin CLLCC品牌Cypress详细资料EPROM"
"5962-9322001MRA
                Octal edge-triggered D-type flip-flop with three-state outputs品牌NXP s详细资料Flip Flops"
"5962-9157602MMA
                MCU 8-bit 80C51 CISC 8KB EPROM 5V 44-Pin CLCC品牌NXP s详细资料Microcontroller"
"5962-9154502MQA
                CPLD ATV2500H Family 24 Macro Cells 1.25um  5V 40-Pin CDIP品牌e2v详细资料CPLD"
"5962-8973601CA
                OR Gate 4-Element 2-IN CMOS 14-Pin CDIP品牌e2v详细资料Gates"
"5962-9154507MQA
                CPLD ATV2500BQL Family 24 Macro Cells 24MHz 0.65um, CMOS  5V 40-Pin CDIP品牌e2v详细资料CPLD"
"5962-8672101EA
                Dual Transmitter RS-422/RS-423 16-Pin CDIP品牌e2v详细资料Bus Line Transceivers"
"5962-8866203UA
                SRAM Chip Async Single 5V 256K-bit 32K x 8 55ns 28-Pin LCC品牌e2v详细资料SRAM Chip"
"5962-89755013A
"5962-8985701EA
                Buffer/Line Driver 6-CH Non-Inverting 3-ST Bipolar 16-Pin CDIP品牌NXP s详细资料Buffers and Line Drivers"
"5962-8982501PA
                V-Ref Precision 10V 10mA 8-Pin CDIP Tube品牌AD详细资料Voltage References"
"5962-8972301EA
                Latch Addressable 8-CH D-Type 16-Pin CDIP品牌NXP s详细资料Latches"
"5962-9211701MPA
                Op Amp Dual High Speed Amplifier ±18V 8-Pin CDIP Tube品牌AD详细资料Op Amps"
"5962-9952001QYA
                CPLD Ultra37000 Family 2K Gates 64 Macro Cells 100MHz 5V 44-Pin CLCC品牌Cypress详细资料CPLD"
"5962-9052604MUA
        DSP Floating-Point 32bit 40MHz 20MIPS 196-Pin CFPAK Tray品牌TI详细资料DSP"
"5962-9201301MEA
        Sample and Hold 4-CH 1us 16-Pin CDIP Tube品牌AD详细资料Sample and Hold"
"5962-9952201QYA
        CPLD Ultra37000 Family 3.8K Gates 128 Macro Cells 83MHz 5V 84-Pin CLCC品牌Cypress详细资料CPLD"
"5962-9321401MEA
        V-Ref Programmable ±10V 10mA 16-Pin CDIP Tube品牌AD详细资料Voltage References"
"5962-8953202UA
        UART 2-CH 5V 44-Pin LLCC品牌NXP s详细资料UARTs"
"5962-8776202VX
        1-Channel Single ADC SAR 8-bit Parallel 18-Pin CDIP Tube品牌AD详细资料ADC"
"5962-9098001MPA
        Op Amp Single wideband Amplifier ±18V 8-Pin CDIP Tube品牌AD详细资料Op Amps"
"5962-88670053A
        SPLD AT22V10 Family 800 Gates 10 Macro Cells 33.3MHz CMOS  5V 28-Pin CLLCC品牌Cypress详细资料SPLD"
"5962-8964501PA
        Op Amp Single Precision Amplifier ±18V 8-Pin CDIP Tube品牌AD详细资料Op Amps"
"5962-8552603LA
        PROM Parallel 16K-bit 5V 24-Pin DIP品牌AMD详细资料PROM"
"5962-8959821MMA
        SRAM Chip Async Single 5V 1M-bit 128K x 8 20ns 32-Pin CLCC品牌Cypress详细资料SRAM Chip"
"5962-89710013X
        analog Multiplexer Single 16:1 28-Pin CLLCC Tube品牌AD详细资料Analog Switch Multiplexers"
"5962-87630012A(IDT)
        Buffer/Line Driver 8-CH Non-Inverting 3-ST CMOS 20-Pin CLLCC Rail品牌e2v详细资料Buffers and Line Drivers"
"5962-87515053A
        EPROM UV 64K-bit 8K x 8 45ns 28-Pin CLLCC品牌e2v详细资料EPROM"
"5962-8606305YA
        EPROM OTP 256K-bit 32K x 8 150ns 32-Pin LCC品牌e2v详细资料EPROM"
"5962-8983902RA
        SPLD GAL Family 8 Macro Cells 41.6MHz 5V 20-Pin CDIP品牌e2v详细资料SPLD"
2020-9-4 10:29:41   评论 分享淘帖
高级模式
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
发表新帖
关闭
站长推荐 上一条 /8 下一条
快速回复 返回顶部 返回列表
