发 帖
原厂入驻New
5962-88668012A
2020-9-4 08:25:35  26
分享
5962-88668012A代理  5962-88668012A价格 5962-88668012A 货期5962-88668012A 订货热线13632767652
普级二极管现货,JAN军级二极管现货,JANTX特军级二极管现货,JANTXV超特军级二极管现货,JANS航宇级二三极管现货13632767652
主要经营范围为宇航级,军品级,工业级,通讯用,较偏门、冷门之高科技元器件各类IC芯片
联系人:黄云艳
手机:13632767652
QQ:956145708
深圳地址:深圳市龙华区民治光浩国际中心一期22H
"5962-0051202Q2A
        Op Amp Single Low Power Amplifier R-R I/O ±3V/6V 20-Pin CLLCC Tube品牌ti详细资料Op Amps"
"5962-0051208QCA
        Op Amp Dual Low Power Amplifier R-R I/O ±3V/6V 14-Pin CDIP Tube品牌TI详细资料Op Amps"
"5962-0050901QEA
        Multiplexer 1-Element CMOS 3-ST 8-IN 16-Pin CDIP Tube品牌TI详细资料Multiplexers"
"5962-0050901Q2A
        Multiplexer 1-Element CMOS 3-ST 8-IN 20-Pin CLLCC Tube品牌TI详细资料Multiplexers"
"5962-7600801VFA
        Counter Single 4-Bit Sync Binary UP 16-Pin CFPAK Tube品牌TI详细资料Counter Shift Registers"
"5962-7601201VEA
        Latch Transparent 4-CH D-Type 16-Pin CDIP Tube品牌TI详细资料Latches"
"5962-7601201VFA
        Latch Transparent 4-CH D-Type 16-Pin CFPAK Tube品牌TI详细资料Latches"
"5962-7801102VRA
        Flip Flop D-Type Bus InteRFace Pos-Edge 3-ST 1-Element 20-Pin CDIP Tube品牌TI详细资料Flip Flops"
"5962-7603701VEA
        Multiplexer 1-Element Bipolar 3-ST 8-IN 16-Pin CDIP Tube品牌TI详细资料Multiplexers"
"5962-7704201VFA
        Register File Single-Element 4-CH Bipolar 16-Pin CFPAK Tube品牌TI详细资料Registers"
"5962-7801001VSA
        Flip Flop D-Type Bus Interface Pos-Edge 1-Element 20-Pin CFPAK Tube品牌TI详细资料Flip Flops"
"5962-8403801VDA
        NAND Gate 3-Element 3-IN CMOS 14-Pin CFPAK Tube品牌TI详细资料Gates"
"5962-8415001VEA
        Flip Flop JK# -Type Pos-Edge 2-Element 16-Pin CDIP Tube品牌TI详细资料Flip Flops"
"5962-8409201VEA
        Decoder/Demultiplexer Dual 2-to-4 16-Pin CDIP Tube品牌TI详细资料Decoders and Demuxes"
"5962-8403901VDA
        NAND Gate 2-Element 4-IN CMOS 14-Pin CFPAK Tube品牌TI详细资料Gates"
"5962-8002101VRA
        Bus XCVR Single 8-CH 3-ST 20-Pin CDIP Tube品牌TI详细资料Bus Transceiver"
"5962-8512801VSA
        Latch Transparent 3-ST 8-CH D-Type 20-Pin CFPAK Tube品牌TI详细资料Latches"
"5962-8404201VCA
        NOR Gate 3-Element 3-IN CMOS 14-Pin CDIP Tube品牌TI详细资料Gates"
"5962-8407301VEA
        Flip Flop D-Type Bus Interface Pos-Edge 1-Element 16-Pin CDIP Tube品牌TI详细资料Flip Flops"
"5962-8512501VEA
"5962-8407501VFA
"5962-8415301VSA
        Identity Comparator 8-Bit 20-Pin CFPAK Tube品牌TI详细资料Logic Comparators"
"5962-8404801VDA
"5962-8404201VDA
        NOR Gate 3-Element 3-IN CMOS 14-Pin CFPAK Tube品牌TI详细资料Gates"
"5962-7801201VRA
        Buffer/Line Driver 8-CH Inverting 3-ST Bipolar 20-Pin CDIP Tube品牌TI详细资料Buffers and Line Drivers"
"5962-8415301VRA
        Identity Comparator 8-Bit 20-Pin CDIP Tube品牌TI详细资料Logic Comparators"
"5962-7801102VSA
        Flip Flop D-Type Bus Interface Pos-Edge 3-ST 1-Element 20-Pin CFPAK Tube品牌TI详细资料Flip Flops"
"5962-8416101VSA
        Bus XCVR Single 8-CH 3-ST 20-Pin CFPAK Tube品牌TI详细资料Bus Transceiver"
"5962-8606101VFA
        Multiplexer 1-Element CMOS 8-IN 16-Pin CFPAK Tube品牌TI详细资料Multiplexers"
"5962-7602001VCA
        NAND Gate 4-Element 2-IN Bipolar 14-Pin CDIP Tube品牌TI详细资料Gates"
"5962-7704201VEA
        Register File Single-Element 4-CH Bipolar 16-Pin CDIP Tube品牌TI详细资料Registers"
"5962-8670407VXA
        Current Mode PWM Controller 1A 500kHz 20-Pin CLLCC Tube品牌TI详细资料Current Mode PWM Controllers"
"5962-8670405VXA
"5962-86827012A
        Shift Register Single 4-Bit Serial/Parallel to Parallel 20-Pin CLLCC Tube品牌TI详细资料Counter Shift Registers"
"5962-8686701VRA
        Latch Transparent 3-ST 8-CH D-Type 20-Pin CDIP Tube品牌TI详细资料Latches"
"5962-86717012A
        Shift Register Single 8-Bit Serial to Serial/Parallel 20-Pin CLLCC Tube品牌TI详细资料Counter Shift Registers"
"5962-86874012A
        Buffer/Line Driver 8-CH Non-Inverting 3-ST Bipolar 20-Pin CLLCC Tube品牌TI详细资料Buffers and Line Drivers"
"5962-8687401SA
        Buffer/Line Driver 8-CH Non-Inverting 3-ST Bipolar 20-Pin CFPAK Tube品牌TI详细资料Buffers and Line Drivers"
"5962-8751701FA
        Counter/Register Single 8-Bit Binary UP 16-Pin CFPAK Tube品牌TI详细资料Counter Shift Registers"
"5962-8755501VRA
"5962-8759501KA
        Bus XCVR Single 8-CH 3-ST 24-Pin CFPAK Tube品牌TI详细资料Bus Transceiver"
"5962-8755601VSA
"5962-87621012A
        Counter Single 8-Bit Binary UP 20-Pin CLLCC Tube品牌TI详细资料Counter Shift Registers"
"5962-87595013A
        Bus XCVR Single 8-CH 3-ST 28-Pin CLLCC Tube品牌TI详细资料Bus Transceiver"
"5962-8763101VRA
        Flip Flop D-Type Bus Interface Pos-Edge 3-ST 1-Element 20-Pin CDIP Tube品牌TI详细资料Flip Flops"
"5962-8769401VSA
"5962-8775801VRA
"5962-8769401VRA
"5962-87724012A
        Counter Single 4-Bit Binary UP/Down 20-Pin CLLCC Tube品牌TI详细资料Counter Shift Registers"
"5962-8779401SA
        NOR Gate 6-Element 2-IN Bipolar 20-Pin CFPAK Tube品牌TI详细资料Gates"
"5962-8779401RA
        NOR Gate 6-Element 2-IN Bipolar 20-Pin CDIP Tube品牌TI详细资料Gates"
"5962-87809012A
        Bus XCVR Single 8-CH 3-ST 20-Pin CLLCC Tube品牌TI详细资料Bus Transceiver"
"5962-8852001VCA
        Flip Flop D-Type Pos-Edge 2-Element 14-Pin CDIP Tube品牌TI详细资料Flip Flops"
"5962-88575013A
        Latch Transparent 3-ST 10-CH D-Type 28-Pin CLLCC Tube品牌TI详细资料Latches"
"5962-88625012A
        Multiplexer 1-Element Bipolar 8-IN 20-Pin CLLCC Tube品牌TI详细资料Multiplexers"
"5962-88621012A
        XOR Gate 4-Element 2-IN Bipolar 20-Pin CLLCC Tube品牌TI详细资料Gates"
"5962-8859602SA
"5962-8862501FA
        Multiplexer 1-Element Bipolar 8-IN 16-Pin CFPAK Tube品牌TI详细资料Multiplexers"
"5962-8862601FA
        Multiplexer 1-Element Bipolar 3-ST 8-IN 16-Pin CFPAK Tube品牌TI详细资料Multiplexers"
"5962-88626012A
        Multiplexer 1-Element Bipolar 3-ST 8-IN 20-Pin CLLCC Tube品牌TI详细资料Multiplexers"
"5962-8866801SA
"5962-88687013A
"5962-88668012A
        Flip Flop D-Type Bus Interface Pos-Edge 3-ST 1-Element 20-Pin CLLCC Tube品牌TI详细资料Flip Flops"
"5962-88700012A
        Latch Transparent 3-ST 8-CH D-Type 20-Pin CLLCC Tube品牌TI详细资料Latches"
2020-9-4 08:25:35   评论 分享淘帖
高级模式
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
发表新帖
关闭
站长推荐 上一条 /7 下一条
快速回复 返回顶部 返回列表
