电子发烧友论坛|
现象是这样的:
一.我用的CCSV5.3 ,SYS/BIOS' v6.34.2.18, XDCtools 3.24.5.48,在此环境下建立的工程及代码编译正常 二.最近将工具升级到V5.4.0.00091 ,SYS/BIOS' 6.35.3.47,XDCtools 3.25.2.70,在此环境下将V5.3的工具拷贝至该环境下,此时,编译出现如下警告: 1.RTSC product 'SYS/BIOS' v6.34.2.18 (or equivalent) is not currently installed. A compatible version 6.35.3.47 will be used during build. Please install a product of equivalent version, or enable one of the supported versions of this product. 2.This project was created using a version of XDCtools that is not currently installed: 3.24.5.48. Please install the XDCtools of this version, or migrate the project to one of the supported versions. 3.warning #16002-D: build attribute vendor section TI missing in ":/CCSV5_4_Test/BaseProj/Flash28335_API_V210.lib compatibility cannot be determined 三.备注:工程都是一样的,只是CCS环境的不同,用到的都是F288335,才疏学浅,以上问题,急盼赐教!!! |
6 个讨论
小佳99 发表于 2020-7-19 09:07 这个没有关系的,它只是提示你这个API lib里的Flash28_Erase那个object文件是使用老版本的编译器进行编译的,但新版本(你现在是v6.1.3)的可以向下兼容,具体可参见: http://processors.wiki.ti.com/index.php/C28x_Compiler_Error_and_Warning_Messages#Warning:_build_attribute_vendor_section_TI_missing_in_.22.3Clibrary_or_object.3E_:_compatibility_cannot_be_determined 如果你不想看到那个警告,也可以按照它提示的方法suppress后就没有了。 If a post answers your question, please mark it with the "verify answer" button. |
小佳99 发表于 2020-7-19 09:07 你好,我使用ccs6.1.3,报错: This project was created using a version of compiler that is not currently installed: 4.0.0 [MSP430]. Please go to CCS App Center to install the compiler of this version, or migrate the project to one of the available compiler versions by adjusting project properties. 请问如何设置Compiler version为TI V6.1.3呢? |
testd012 发表于 2020-7-19 09:31 右键执行工程属性,在general菜单里可以更改不同的编译器版本。 当然前提是已经安装并且已经加入到了你使用的CCS版本下的编译器。如果没有加入,可以通过CCS的菜单window --> preferences在以下窗口里进入配置: If a post answers your question, please mark it with the "verify answer" button. |
只有小组成员才能发言,加入小组>>
553 浏览 0 评论
1616 浏览 0 评论
2049 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1516 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1343 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1759浏览 29评论
2787浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1726浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1637浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1647浏览 13评论
/9
GMT+8, 2025-12-3 07:39 , Processed in 0.851279 second(s), Total 61, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2986
