“Strutt,Michael”写道:> Shawn是正确的,如果你将你的home变量设置为> C:Program FilesAgilentVEE Pro 7.0>或者你的文件的版本和位置应该可以正常工作。>我不得不在这里不同意 - 用户数据
永远不应该放在应用程序安装目录中。 $ HOME是for_user_数据,不应该指向C:Program FilesAgilentVEE Pro 7.0VEE不使用$ HOME来查找ID - 它看起来是应用程序安装目录.Stan ------------- -------------------------------------------------- ----------- Stan Bischof安捷伦科技公司707-577-3994 以下为原文 "Strutt, Michael" wrote: > Shawn is right if you set your home variable to > C:Program FilesAgilentVEE Pro 7.0 > or whatever the version and location of your files it should work ok. > I have to disagree here-- user data should NEVER be placed in a application installation directory. $HOME is for _user_ data and should not point to C:Program FilesAgilentVEE Pro 7.0 VEE doesn't use $HOME to look for ID's anyhow- it looks in the application install directory. Stan |
3个回答
>我不得不在这里不同意 - 真的。
如果您阅读它(dox),您会发现HOME控制io配置文件的位置(如果适用 - 条件适用)。并且它与“用户数据”的想法相吻合。 我想也许这是一个没有注意到的人。 另请注意,虽然在解释HOME方面有7.03的修正,但它与打开InstrumentManager有关。-SHAWN ----您目前订阅vrf为:r***@soco.agilent.com要订阅发送空白 发送电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至 “vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 > I have to disagree here-- True. If you read it over (the dox that is), you find HOME controls the location of the io configuration file (if appropriate - conditions apply). And that jibes with the "user data" idea. I thought maybe this was a bug nobody had noticed. Note also though that there was a correction in 7.03 to the way HOME was interpreted but it had to do with opening the Instrument Manager. -SHAWN- --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
@page Section1 {size:612.0pt 792.0pt;
保证金:72.0pt 90.0pt 72.0pt 90.0pt; } M.MsoNormal {FONT-SIZE:12pt; 保证金:0cm 0cm 0pt; FONT-FAMILY:“Times New Roman”} LI.MsoNormal {FONT-SIZE:12pt; 保证金:0cm 0cm 0pt; FONT-FAMILY:“Times New Roman”} DIV.MsoNormal {FONT-SIZE:12pt; 保证金:0cm 0cm 0pt; FONT-FAMILY:“Times New Roman”} A:链接{COLOR:blue; TEXT-DECORATION:下划线} SPAN.MsoHyperlink {颜色:蓝色; 文字装饰:下划线} A:访问过{颜色:紫色; TEXT-DECORATION:下划线} SPAN.MsoHyperlinkFollowed {COLOR:purple; TEXT-DECORATION:下划线} SPAN.EmailStyle17 {COLOR:windowtext; FONT-FAMILY:Arial; mso-style-type:personal-compose} DIV.Section1 {page:Section1}如果你将你的home变量设置为C,则Shawn是正确的:Program FilesAgilentVEE Pro 7.0或者你的文件的版本和位置应该可以正常工作ok.to add home 右键单击mycomputer选择属性选择高级选择环境变量然后新建或编辑到VEE开发的主页MikeFrom:Amrik Sekhon [mailto:Amrik.Sekhon@GeePlus.biz]发送日期:2005年6月16日14:31转到:VRFS主题:[vrf] Runtme errorHi Folks当我运行我的程序时,它会出现以下错误:找不到文件'hp661xx.cid'错误700尝试加载ID文件我以为我理解了它的意思并检查了agilent下的ids文件夹。 该文件在那里,所以我感到困惑。开发程序工作正常.CheersAmrik ---您目前订阅vrf为:MStrutt@tycoelectronics.com订阅发送空白电子邮件至“join-vrf@it.lists.it。 agilent.com“。要取消订阅,请发送空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要向此邮件列表发送邮件,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 - 在此传出消息中找不到病毒。由AVG Anti-Virus.Version检查:7.0.323 /病毒数据库:267.7.3 / 15 - 发布日期:2005年6月14日---您目前订阅了vrf as :r***@soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent”。 com。“要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 @page Section1 {size: 612.0pt 792.0pt; margin: 72.0pt 90.0pt 72.0pt 90.0pt; }P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"}LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"}DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"}A:link { COLOR: blue; TEXT-DECORATION: underline}SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline}A:visited { COLOR: purple; TEXT-DECORATION: underline}SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline}SPAN.EmailStyle17 { COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: personal-compose}DIV.Section1 { page: Section1}Shawn is right if you set your home variable toC:Program FilesAgilentVEE Pro 7.0or whatever the version and location of your files it should work ok. to add home right click on mycomputer select properties select advanced select environment variables Then new or edit to the home for VEE development Regards MikeFrom: Amrik Sekhon [mailto:Amrik.Sekhon@GeePlus.biz] Sent: 16 June 2005 14:31To: VRFSubject: [vrf] Runtme errorHi Folks When I run my program it gives the following error : File ‘hp661xx.cid’ was not foundError 700Attempting to load ID file I thought I understood what it meant and checked the ids folder under agilent. The file was there so I am left confused. The development program works fine. Cheers Amrik---You are currently subscribed to vrf as: MStrutt@tycoelectronics.comTo subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". --No virus found in this outgoing message.Checked by AVG Anti-Virus.Version: 7.0.323 / Virus Database: 267.7.3/15 - Release Date: 14/06/2005---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
也许这有点简单。
如果你是在开发环境中运行,那么路径theIDs目录为C:计划FilesAgilentVEE临7.5IdsBut的运行时环境为-C:计划FilesAgilentVEE Pro运行7.0idsBut这是gotchaThe hp661xx.cid是在开发目录,但不是在 runtimeone。 如果你看看这两个目录的内容,那么开发环境就有很多* .cid文件,但是运行时只有8个!我认为它们的安装只会把一个cid文件的样本放在theruntime目录中作为应该存在的例子。 .Adam KohlerSouth昆斯DivisionAgilent TechnologiesScotland的telnet 313 5327e adam_kohler@agilent.com> -----原始消息----->自:肖恩费森登[的mailto:shawn@testech-ltd.com]>发送:星期四2005年6月15 :03> To:PDL-LISTS,VRF(A-Lists,unix1)>主题:RE:[vrf] Runtme错误> >>当我运行程序时出现以下错误:>>如果这是同样的问题你 十一月我恐怕不能真的想到任何原因,除了一个:是否有一个HOME环境变量>定义? 如果有它可能会搞乱运行时间。 呃,实际上>听起来有点弱> -SHAWN->>>> - >您目前订阅到VRF为:adam_kohler@agilent.com>订阅发送一个空白邮件到“join-vrf@it.lists .it.agilent.com“。>要取消订阅,请发送空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。>要向此邮件列表发送邮件,请发送电子邮件至”vrf@agilent.com“。 >如果您需要有关邮件列表的帮助,请发送邮件至“owner-> vrf@it.lists.it.agilent.com”.---您目前订阅了vrf:r***@soco.agilent.com订阅发送 一封空白的电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件 ,发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 Maybe this is a bit simpler. If you are running in the development environment then the path to the IDs directory is C:Program FilesAgilentVEE Pro 7.5Ids But the run time environment is C:Program FilesAgilentVEE Pro RunTime 7.0ids But this is the gotcha The hp661xx.cid is in the development directory but NOT in the runtime one. If you look at the contents of both these directories the development environment one has lots of *.cid files but the runtime one has only 8! I think they installation only puts a sample of the cid files in the runtime directory as an example of where there should be. Adam Kohler South Queensferry Division Agilent Technologies Scotland telnet 313 5327 e adam_kohler@agilent.com > -----Original Message----- > From: Shawn Fessenden [mailto:shawn@testech-ltd.com] > Sent: Thursday June 2005 15:03 > To: PDL-LISTS,VRF (A-Lists,unix1) > Subject: RE: [vrf] Runtme error > > > When I run my program it gives the following error : > > If this is the same problem you had in November I'm afraid I can't really > think of any cause except maybe one: is there a HOME environment variable > defined? If there is it might be messing runtime up. Er, that actually > sounds kinda weak! > -SHAWN- > > > > --- > You are currently subscribed to vrf as: adam_kohler@agilent.com > To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". > To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". > To send messages to this mailing list, email "vrf@agilent.com". > If you need help with the mailing list send a message to "owner- > vrf@it.lists.it.agilent.com". --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 16:36 , Processed in 1.118658 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2985
