您好,我刚收到我的新53220A,并且我安装了该软件包附带的更新版本16.1套件。
我以前在运行,版本15.1。 现在连接专家无法连接到我的任何LAN仪器(我可以用vr15.1连接到我的34410)。 我可以通过在IP浏览器中输入IP来连接仪器。 为什么Connection Expert无法看到我的局域网连接仪器?谢谢 以上来自于谷歌翻译 以下为原文 Hello, i just received my new 53220A, and i installed the updated version 16.1 suite that came with the package. I was previously running, version 15.1. Now the connection expert can not connect to any of my LAN instruments (i could connect to my 34410 with vr15.1). I can connect to the instruments by entering in the IP to web browser. Why can't Connection Expert see my LAN connected instruments? Thanks |
7个回答
IO Libraries Suite帮助文件中有一节标题为“查找LAN仪器”。
我把它作为PDF文件附在这里。 通过它,让我知道你是否遇到了问题。 以上来自于谷歌翻译 以下为原文 There is a section in the IO Libraries Suite help file titled "Finding LAN Instruments". I've attached it here as a PDF file. Run through that and let me know if you run into problems. 附件
谢谢回复。
是的,这是我一直遵循的程序。 经过多次尝试,连接专家“添加LAN上的仪器(TCPIP0)”找到了53220A。但是仍然没有找到34410A。可以通过输入IP地址直接通过浏览器访问34410A。 以上来自于谷歌翻译 以下为原文 Thanks for the reply. Yes that is the procedure that i have been following. After multiple attempts, the 53220A was found by the Connection Expert "Add Instrument on LAN (TCPIP0). The 34410A however is still not found. The 34410A can be accessed directly through the browser by typing in the IP address. |
您使用DHCP进行自动寻址,还是使用静态IP?DMM与您的PC处于相同的IP地址范围(子网)吗?
以上来自于谷歌翻译 以下为原文 Are you using DHCP for automatic addressing, or are you using static IP's? Is the DMM in the same IP address range (subnet) as your PC? |
您是连接到具有DHCP服务器的网络,还是使用自动IP范围(169.254。*。*)进行连接?
如果它使用Auto-Ip,我建议重新启动34410A(给它2-2.5分钟以稳定新连接)。 以上来自于谷歌翻译 以下为原文 Are you connected to a network that has a DHCP server, or is your connection using the Auto-IP range (169.254.*.*)? If its using Auto-Ip, I'd recommend rebooting the 34410A (give it like 2-2.5 minutes to stabilize the new connection). |
呸,我希望它是星期五!我已经发给你一些日志文件给你给我的电子邮件。
以上来自于谷歌翻译 以下为原文 Bah, i wish it was friday! I have sent you some log files to the e-mail you gave me. |
谢谢你的支持。
我很感激你花时间去研究这个。欢呼! 以上来自于谷歌翻译 以下为原文 Thank you for the support. I appreciate your time taken to look into this. Cheers! |
还有一个问题,一种关于主题的话题。当使用34410A内部网络主机时,我通过浏览器连接,我可以访问一个非常好的前面板界面来控制仪器并获取测量/输出数据。
现在,当我连接到53220A时,我有同样的期望,但我看到的唯一接口是发送命令和接收休止。 53220A固件是否会在未来通过网络主机(很像34410A)通过前面板接口/控制进行更新? 以上来自于谷歌翻译 以下为原文 One more question, kind of off the thread topic. When using the 34410A internal web host, i connect through the browser and i can get access to a very nice front panel interface to control the instrument and take measurements/output data. Now when i connect to the 53220A i had that same expectation, however the only interface i see is to send commands and receive repose. Will the 53220A firmware be updated with a front panel interface/control through the web host (much like the 34410A) in the future? |
只有小组成员才能发言,加入小组>>
2097 浏览 1 评论
1854 浏览 1 评论
1713 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2258浏览 0评论
GMT+8, 2024-4-25 01:54 , Processed in 0.917220 second(s), Total 49, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
