电子发烧友论坛|
运行“To File”对象时,定义控件输入文件名的对象可能尚未运行。
只需通过将其连接到“To File对象”顶部,强制它在“To File”对象之前运行。 你需要在大多数时候使用控制输入来做这个技巧.Le2008-06-19à10:56,Gallmayer,Jochenaécrit:我创建了一个“To File” - Object(I / O + To + File) )并为Filename和输入“A”fortext-data添加了一个控制输入。 然后在里面只有“WRITE TEXT A”。然后我有一个连接到“ToFile”的开始按钮现在问题是没有从对象使用文件名而没有写入数据。但是当我把“ToFile” 在UserFunction内部并传递文件名和dataas参数并调用UserFunction然后它就可以了。为什么?---您目前订阅了vrf:ming_meng@agilent.com要订阅,请发送电子邮件至:“vrf-request @ lists.it.agilent.com“在邮件正文中使用了subscribe这个词。 要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。 要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 在“http://www.vrfarchive.com/vrf_archive”上搜索“unofficial vrf archive”。 在“http://vee.engineering.agilent.com”上搜索Agilent vrf存档。 以上来自于谷歌翻译 以下为原文 When your "To File" object runs, the object that defines the filename for the control input may not have run yet. Just force it to run before the "To File" object by connecting it on top of the "To File object". You need to do this trick most of the time you use a control input. Le 2008-06-19 à 10:56, Gallmayer, Jochen a écrit : i created a "To File"-Object (I/O+To+File) and added a control-input for the Filename and an input "A" for text-data. Then inside only "WRITE TEXT A". Then i have start-button which is connected to the "ToFile" Now the problem is that the filename is not used from the object and no data is written. BUT when i put the "ToFile" inside of a UserFunction and pass the filename and data as parameters and call the UserFunction then it works. Why this? --- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com". |
2个回答
您好,我创建了一个“To File”-Object(I / O + To + File),并为Filename和输入“A”fortext-data添加了一个控件输入。
然后在里面只有“WRITE TEXT A”。然后我有一个连接到“ToFile”的开始按钮现在问题是没有从对象使用文件名而没有写入数据。但是当我把“ToFile” 在UserFunction内部并传递文件名和dataas参数并调用UserFunction,然后它就可以工作。为什么这样?frefreundlichenGrüßenJ。 Gallmayer-- Jochen GallmayerSoftware-EntwicklungLXinstruments GmbHHerrenberger Str。 130D-71034BöblingenTel。 +49(0)7031-410089 -13Fax。 +49(0)7031-410089 -18E-Mail:HYPERLINK“mailto:J.Gallmayer@LXinstruments.com”J.Gallmayer@LXinstruments.comInternet:HYPERLINK“outbind://5/www.lxinstruments.com”www.lxinstruments .comVERTRAULICHKEITS-INFORMATION:Diese E-Mail undalleanhängendenDokumente,enthältInformationender LXinstruments GmbH und istnurfürdieadressierte Person bestimmt。 Diesekönnenvertraulichund / odervonVeröffentlichungenausgenommensein。 Das Kopieren und die Weitergabe an nicht autorisierte Dritte ist verboten。 FürZuwiderhandlungenkönnenSiehaftbar gemacht werden。 Falls Sie nichtderEmpfängersind,benachrichtigen Sie den Absender bitte umgehend。 DankeCONFIDENTIALITY通知:此电子邮件及其随附的任何文档包含来自LXinstruments GmbH的信息,该信息仅供其所针对的个人或实体使用,并且可能包含特权,机密和/或信息。 或根据适用法律免于披露。 如果此消息的读者不是预期接收者,则禁止披露,传播,分发,复制或以其他方式使用本消息或其内容。 如果您错误地收到了此通信,请立即与我们联系。 谢谢你们注意:Cecourrierélectroniqueainsique les documentsajoutés,contiennent des informations delaSociétéLXinstrumentsGmbH etsontdestinésnaturementàlapersonneclocée。 Ce courrierpeutêtrerevenielet / ou exclu de toute publication ou divulgation quelconque。 La copie,la distribution ou lerenvoiàtoutetierce personnenonautoriséssontinterdit par la loi des communications etdeslibertés。 Si vous recevez ce courrier par erreur,veuilleznousprévenirimmédiatement。 Merci .---您目前订阅了vrf:ming_meng@agilent.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。 要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。 要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 在“http://www.vrfarchive.com/vrf_archive”上搜索“unofficial vrf archive”。 在“http://vee.engineering.agilent.com”上搜索Agilent vrf存档。 以上来自于谷歌翻译 以下为原文 Hello, i created a "To File"-Object (I/O+To+File) and added a control-input for the Filename and an input "A" for text-data. Then inside only "WRITE TEXT A". Then i have start-button which is connected to the "ToFile" Now the problem is that the filename is not used from the object and no data is written. BUT when i put the "ToFile" inside of a UserFunction and pass the filename and data as parameters and call the UserFunction then it works. Why this? mit freundlichen Grüßen J. Gallmayer -- Jochen Gallmayer Software-Entwicklung LXinstruments GmbH Herrenberger Str. 130 D-71034 Böblingen Tel. +49 (0)7031-410089 -13 Fax. +49 (0)7031-410089 -18 E-Mail: HYPERLINK "mailto:J.Gallmayer@LXinstruments.com"J.Gallmayer@LXinstruments.com Internet: HYPERLINK "outbind://5/www.lxinstruments.com"www.lxinstruments.com VERTRAULICHKEITS-INFORMATION: Diese E-Mail und alle anhängenden Dokumente, enthält Informationen der LXinstruments GmbH und ist nur für die adressierte Person bestimmt. Diese können vertraulich und/oder von Veröffentlichungen ausgenommen sein. Das Kopieren und die Weitergabe an nicht autorisierte Dritte ist verboten. Für Zuwiderhandlungen können Sie haftbar gemacht werden. Falls Sie nicht der Empfänger sind, benachrichtigen Sie den Absender bitte umgehend. Danke CONFIDENTIALITY NOTICE : This email and any documents which may accompany it, contains information from LXinstruments GmbH, which is intended only for the use of the individual or entity to which it is addressed, and which may contain information that is privileged, confidential, and/or otherwise exempt from disclosure under applicable law. If the reader of this message is not the intended recipient, any disclosure, dissemination, distribution, copying or other use of this communication or its substance is prohibited. If you have received this communication in error, please contact us immediately. Thank you NOTE DE CONFIDENTIALITE : Ce courrier électronique ainsi que les documents ajoutés, contiennent des informations de la Société LXinstruments GmbH et sont destinés uniquement à la personne concernée. Ce courrier peut être confidentiel et/ou exclu de toute publication ou divulgation quelconque. La copie, la distribution ou le renvoi à toute tierce personne non autorisée sont interdit par la loi des communications et des libertés. Si vous recevez ce courrier par erreur, veuillez nous prévenir immédiatement. Merci. --- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com". |
控制输入不正常(虚线)。
需要对它们所属的对象进行排序,以便在提供数据的对象之后触发。 IOW,将提供文件名的对象的序列连接到ToFile&的序列中。 它会像你期望的那样工作。它在UF中工作的事实表明,人们无法确定UF中的线程排序。-SHAWN- 以上来自于谷歌翻译 以下为原文 Control inputs are not normal (dashed line). The object to which they belong need to be sequenced to fire after the object that supplies data. IOW, connect sequence out of the object supplying the file name to sequence in of the ToFile & then it will work as you expect. The fact that it works in a UF shows that one cannot be sure of thread sequencing in a UF. -SHAWN- |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 09:36 , Processed in 0.705572 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6303
