在安装IO Libraries 16.2期间,我在尝试启动服务时收到错误。
*“Windows无法在本地计算机上启动Agilent IO Libraries Service服务。* *错误1053:服务未及时响应启动或控制请求。”*重新启动笔记本电脑或尝试从服务器启动服务 管理控制台不起作用。 返回相同的错误消息。 此安捷伦管理的笔记本电脑以前安装了几个其他版本的IO Libs,没有任何问题。 事实上16.1仍然会安装没有问题.....只是不是16.2。 我在安装过程中暂时禁用了SEP12,并确保没有其他任何正在运行的可能会干扰该过程。 我还浏览了这些以及其他一些技术论坛,尝试了尚未淘汰的不同“修复”。 任何建议将不胜感激。 以上来自于谷歌翻译 以下为原文 During the installation of IO Libraries 16.2 I receive an error at the point that it tries to start the service. *"Windows could not start the Agilent IO Libraries Service service on Local Computer.* *Error 1053: The service did not respond to the start or control request in a timely fashion."* Restarting the laptop or trying to start the service from the management console does not work. The same error message is returned. This Agilent managed laptop previously has had several other versions of IO Libs installed with no problem. In fact 16.1 will still install without a problem.....just not 16.2. I have temporarily disabled SEP12 during the installation as well as making sure that nothing else is running that may interfere with the process. I have also browsed these and some other technical forums trying different "fixes" that have not yet panned out. Any suggestions would be greatly appreciated. |
1个回答
更新运行系统文件后检查报告没有发现问题我安装了三个+可选+ .NET 4更新,之后IO Libs 16.2启动并正常工作。
以上来自于谷歌翻译 以下为原文 UPDATE After running a system file check that reported no problems were found I installed three +optional+ .NET 4 updates after which IO Libs 16.2 started and worked normally. |
只有小组成员才能发言,加入小组>>
1240 浏览 0 评论
2352 浏览 1 评论
2163 浏览 1 评论
2030 浏览 5 评论
2914 浏览 3 评论
983浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
713浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
813浏览 0评论
1240浏览 0评论
GMT+8, 2024-11-29 15:15 , Processed in 1.708472 second(s), Total 100, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
