电子发烧友论坛|
大家好,
我正在使用ST NFC芯片:M24LR16E在我的产品中,我发现一些与市场上的智能手机不兼容(三星S4,S5,Nexus 4) 我做了一些研究,发现这些手机使用的Broadcom NFC芯片(BC20794)与产品中的某些NFC芯片不兼容。这取决于所使用的NFC标签的类型。 (大多数现有产品都有Mifare Classic 1k标签,它只与恩智浦芯片配备的手机兼容)。 事实上,M24LR16E具有ISO15693标准,与智能手机的NXP NFC芯片(PN544,PN65N ......)的标准相同。而Broadcom芯片中的ISO标准是ISO 18092,ISO14443(来自NFC论坛1-4类标签)...... 所以问题来自于这种不同类型的NFC标签技术(Mifare Classic 1k vs NFC Forum Type 1-4)?或者它来自应用程序? 有人有同样的问题吗?我们需要更换M24LR16E芯片吗? 谢谢您的回答 问候 #nfc #compatible #mifare#iso15693#m24lr16e#m24sr#m24lr #nfc 以上来自于谷歌翻译 以下为原文 Hi all, I am using a ST NFC chip : M24LR16E in my products and I noticed some incompatibility with Smartphones of the market (Samsung S4, S5, Nexus 4) I have made some research and I found that these phones were using a Broadcom NFC chip (BC20794) which is not compatible with some NFC chips in the product. It depends on the type of NFC tag used. (Most of existing products has Mifare Classic 1k tag and it is just compatible with NXP chip equiped phones). In fact the M24LR16E has ISO15693 standard, which is the same standard as in the NXP NFC chips of the Smartphones (PN544, PN65N...). Whereas the ISO standards in the Broadcom chips are ISO 18092, ISO14443 (from NFC Forum type 1-4 tags)... So the problems comes from this different type of NFC tags technology (Mifare Classic 1k vs NFC Forum Type 1-4)? Or is it coming from the application? Do someone has the same problems? Do we need to change the M24LR16E chips? Thank you for your answers Regards #nfc #compatible #mifare #iso15693 #m24lr16e #m24sr #m24lr #nfc |
2个回答
对不起,我正在尝试获取M24LR04E标签的温度。如何通过CR95HF DLL获取当前温度?
以上来自于谷歌翻译 以下为原文 Sorry,i am trying to get the temperature of M24LR04E tag. How can i get the current temperature via CR95HFDLL? |
嗨,
我想您正在使用M24LR-Discovery,并希望通过RF路径读取温度值(显示在LCD屏幕上)。遗憾的是,温度值未通过固件存储在M24LR04E中,因此无法通过RF读取。温度值由微控制器直接读取并显示在屏幕上。为了能够通过RF读取温度,您应该修改固件代码,以便通过微控制器读取温度,然后在M24LR04E中写入温度值。在此修改之后,温度值将通过RF提供。 这是M24LR-Discovery STM8L微控制器的源代码: http://www.st.com/web/en/catalog/tools/PF258104 要通过CR95HF读取M24LR04E,可以使用M24LR_Application_Software。 http://www.st.com/web/en/catalog/tools/PF257516 最好的祝福, NFC / RFID ST支持 以上来自于谷歌翻译 以下为原文 Hi, I suppose you are using M24LR-Discovery and want to read the temperature value (displayed on LCD screen) with RF path. Unfortunately, the temperature value is not stored in the M24LR04E by the firmware and so, cannot be read by RF. The temperature value is directly read and displayed at screen by the microcontroler. To be able to read temperature through RF, you should modify the firmware code in order to read the temperature via microcontroler , then write temperature value in the M24LR04E. After this modifications, the temperature value will be available via RF. This is source code of the M24LR-Discovery STM8L microcontroler: http://www.st.com/web/en/catalog/tools/PF258104 To read M24LR04E through CR95HF, you can use M24LR_Application_Software . http://www.st.com/web/en/catalog/tools/PF257516 Best regards, NFC/RFID ST support |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1465 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1518 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3664 浏览 1 评论
3856 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2475 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
746浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
679浏览 5评论
724浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
963浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
764浏览 5评论
/9
GMT+8, 2025-12-10 03:44 , Processed in 0.835440 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2221
