电子发烧友论坛|
从我上次使用我的电路板开始,这是一个非常好的事情。
今天,在连接电源并打开电路板后,我看到它的2个LED指示灯闪烁POWER LD8和INIT(V13)LD11。 http://www.youtube.com/watch?v=Kbn6K7teG7U 我还注意到连接附近的表面区域非常热。 我遇到了什么问题? 我可以以某种方式重置电源吗? 以上来自于谷歌翻译 以下为原文 It has been a quite from the last time I used my board. Today, after I connect the power and turn the board on, I see its 2 leds blinking POWER LD8, and the INIT(V13) LD11. http://www.youtube.com/watch?v=Kbn6K7teG7U I also notice that the surface area near the connection is very hot. What problem I am encountering? Can I somehow reset the power? |
8个回答
>有没有任何解决方案可以重置电路板,或者我必须更换一个(或几个)IC?
电源电路中没有任何东西可以复位。 看起来可能已经发生了一些损坏,但是已经损坏的是未知的,您需要调试电路板上的电源以确定这一点。 交流/直流电源出现问题的可能性很小。 应检查这一点以确保它仍然产生5V并且可以提供额定的总电流。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 >Is there any solution for reset the board or I have to replace one (or a few) of the ICs? There isn't anything in the power supply circuits to be reset. It appears that some damage may have occurred, but what has been damaged is unknown and you will need to debug the power supply on the board to determine this. There is a small chance that the problem is with your AC/DC power supply. This should be checked to ensure that it is still generating 5V and can supply the total current that is rated for. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.comView solution in original post |
这两个都是电路板电源故障的指标。
造成这种情况的最常见原因是使用错误的交流/直流适配器和电源,并使电源过度导致故障。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Both of these are indicators of a power supply failure with the board. The most common cause of this is using a wrong AC/DC adapter with power and over voltaging the power supplie leading to failure.------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
是否有任何解决方案可以重置电路板,或者我必须更换一个(或几个)IC?
以上来自于谷歌翻译 以下为原文 Is there any solution for reset the board or I have to replace one (or a few) of the ICs? |
电源电路中没有任何东西可以复位。 看起来可能已经发生了一些损坏,但是已经损坏的是未知的,您需要调试电路板上的电源以确定这一点。 交流/直流电源出现问题的可能性很小。 应检查这一点以确保它仍然产生5V并且可以提供额定的总电流。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 >Is there any solution for reset the board or I have to replace one (or a few) of the ICs? There isn't anything in the power supply circuits to be reset. It appears that some damage may have occurred, but what has been damaged is unknown and you will need to debug the power supply on the board to determine this. There is a small chance that the problem is with your AC/DC power supply. This should be checked to ensure that it is still generating 5V and can supply the total current that is rated for. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
我刚刚买了一块新板并扔掉了旧板:smileysad:无论如何,谢谢你
以上来自于谷歌翻译 以下为原文 I just bought a new board and threw away the old one:smileysad: anyway thank u |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 15:35 , Processed in 0.972127 second(s), Total 91, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3969
