扫一扫,分享给好友
你好,我是ëzeyir。我使用STM32f4发现。我应该在simulink上阅读模拟值。我做了一个基本的申请。我的应用是我使用potansiyometre因为模拟值的变换。如果ADC高于500,则PD12和PD13将被激活。否则PD15和PD15数字输出将被激活。数字输出ara根据模拟值激活。但是不能用simulink或读取。 。我尝试了很多方法。
但是,在'analog_okuma / Host Serial Rx'中S-function'amg_u***converter_n_connect'报告的错误是''错误: 错误:等待Rx数据时发生超时。''我如何读取模拟值? https://community.st.com/tags/♯/?tags=readanalogvalue 空值 以上来自于谷歌翻译 以下为原文 Hello I am Ãœzeyir. I use stm32f4 discovery. I should read analog value on simulink. I made a basic application. My application is that i use potansiyometre because of channing of analog value. If ADC is upper 500 , PD12 and PD13 will activated. otherwise PD15 and PD15 digital outputs will be activated. Digital outputs ara activated according to analog value. But ı cannot not drawed on simulink or read. . I tried a lot ways. But ı taken a errors which is''Error reported by S-function 'amg_u***converter_n_connect' in 'analog_okuma/Host Serial Rx': Error: timeout occur while waiting for Rx data.'' How can i read analog value? https://community.st.com/tags/♯/?tags=readanalogvalue null |
5个回答
嗨,
Ãœzeyir 。 首先,你需要分开as和。目标是MCU,主机是Simulink监控。 您必须在片上外设中使用UART模块,并且如果要将数据发送到MCU p 租约将UART Rx更改为非阻塞传输模式,因为在阻塞模式下,MCU在等待Rx数据时不会做任何事情。 在(PC)中使用主机串口从MCU接收数据。 最好的祝福, 以上来自于谷歌翻译 以下为原文 Hi, Ãœzeyir . Firstly, you need to separate as and . Target is MCU and Host is Simulink monitoring. In the you must to use UART block in On-chip Peripherals and if you want to send data to MCU p lease change UART Rx to Non-blocking transfer mode because in blocking mode your MCU doesn't do not thing while waiting for Rx data. In the (PC) use Host Serial for receiving data from MCU. Best regards, |
我有这个错误。我该如何解决这个错误?
最好的祝福 2018-02-20 10:36 GMT + 03:00 Aimagin Co.,Ltd。< st-microelectronics@jiveon.com 计算值: 意法半导体社区 < HTTPS:?//community.st.com/等= watches.email.thread> Re:如何使用uart读取analog用于在serialPort上发送计算机? Aimagin Co.,Ltd。的回复 < HTTPS:?//community.st.com/people/panuwat.s等= watches.email.thread>在*模拟 和音频* - 查看完整的讨论 < HTTPS:?//community.st.com/message/186136-re-how-can-i-read-analog-to-send-computer-on-serialport-by-using-uart commentID = 186136&安培;等= watches.email.thread♯comment-186136> 以上来自于谷歌翻译 以下为原文 I have this error. How can i solve this error? Best Regards 2018-02-20 10:36 GMT+03:00 Aimagin Co., Ltd. STMicroelectronics Community Re: How can I read analog to send computer on serialPort by using uart? reply from Aimagin Co., Ltd. and Audio* - View the full discussion |
你能告诉我更多信息吗?
例如: - Simulink文件。 - 硬件设置 谢谢。 以上来自于谷歌翻译 以下为原文 Could you please give me more information? for example: - Simulink file. - Hardware setup Thank you. |
我使用stm32f407VG和u*** tll转换器
2018-02-20 14:11 GMT + 03:00 Aimagin Co.,Ltd。< st-microelectronics@jiveon.com 计算值: 意法半导体社区 < HTTPS:?//community.st.com/等= watches.email.thread> Re:如何使用uart读取analog用于在serialPort上发送计算机? Aimagin Co.,Ltd。的回复 < HTTPS:?//community.st.com/people/panuwat.s等= watches.email.thread>在*模拟 和音频* - 查看完整的讨论 < HTTPS:?//community.st.com/message/186143-re-how-can-i-read-analog-to-send-computer-on-serialport-by-using-uart commentID = 186143&安培;等= watches.email.thread&安培; sharpcomment-186143> 以上来自于谷歌翻译 以下为原文 I use stm32f407VG and u*** tll converter 2018-02-20 14:11 GMT+03:00 Aimagin Co., Ltd. STMicroelectronics Community Re: How can I read analog to send computer on serialPort by using uart? reply from Aimagin Co., Ltd. and Audio* - View the full discussion |
您的主机错误原因未从Target获取数据。
你检查一下吗? u***转换器连接引脚是否正确? 目标:USART3 Tx / Rx引脚D8 / D9 主持人:您使用哪个串口com?请在“设备管理器”中检查确认。 以上来自于谷歌翻译 以下为原文 Error cause from your Host didn't get data from Target. Have you check your u*** tll converter connecting pin is correctly?
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2695 浏览 1 评论
3228 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1801 浏览 1 评论
3636 浏览 6 评论
6017 浏览 21 评论
956浏览 4评论
1327浏览 4评论
1381浏览 3评论
200浏览 3评论
190浏览 3评论
GMT+8, 2024-12-12 02:49 , Processed in 1.082538 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
