亲爱的朋友们,
我想知道是否有人使用ST232驱动程序IC在STM8发现演示板上组装并测试了超高端应用示例。 我已经这样做但是超级终端不与STM8通信,反之亦然(两者之间没有发送消息)。 我认为原理图中可能存在错误(PDF 16898 UM0884第6/23页图1)。在我看来,DB9引脚数3不能与引脚7和8连接。 非常感谢你的任何信息。 斯特凡诺皮奥万 #hyperterminal 以上来自于谷歌翻译 以下为原文 Dear friends, I'd like to know whether someone has assembled and tested the hyperterminal application example on STM8 discovery demo board, using the ST232 driver IC. I've done that but the hyperterminal doesn't communicate with the STM8 and vice-versa (no messages are sent between them two). I think there could be a mistake in the schematics (PDF 16898 UM0884 page 6/23 Fig. 1). It seems to me that the DB9 pin numer 3 must not be connected with the pins 7 and 8. Thank you very much for any info on that. Stefano Piovan #hyperterminal |
8个回答
你好Stefano,
感谢您的相关反馈。你是对的,引脚3和引脚7和8之间没有连接。 我们会尽快修改此文档。 感谢您的帮助 问候 格罗姆 以上来自于谷歌翻译 以下为原文 Hello Stefano , Thanks for this relevant feedback . You're right , there is no connection beetween pin 3 and pin 7 and 8. We will modify this documentation ASAP. Thank you for your help Regards Grom |
亲爱的格罗姆,
感谢您的回复- 我尝试将引脚#3从7和8断开,但保持7和8连接在一起,不幸的是还没有通信。 你的意思是说#7和8引脚也必须相互断开吗? 在您的意见中,原理图中是否还有其他错误? 提前致谢 斯特凡诺 以上来自于谷歌翻译 以下为原文 Dear Grom, thanks for your reply- I've tried by disconnecting pin#3 from 7 and 8, but keeping 7 and 8 connected together and unfortunately no communication yet. Did you mean that pins# 7 and 8 have to be disconnected from each other too? Are there any other mistakes in the schematic, in your opinon? Thanks in advance Stefano |
我通过连接测试了应用程序
Pin2 - > ST232B引脚13(R1in) Pin3 - > ST232B引脚14(T1out) Pin5 - > GND 在许多应用案例中,其他连接不是强制性的。 希望它能解决你的问题 问候 格罗姆 以上来自于谷歌翻译 以下为原文 I've tested the application by just connecting Pin2 -> ST232B pin 13 (R1in) Pin3 -> ST232B pin 14 (T1out) Pin5 -> GND Other conections are not mandatory in many Application case . Hope it will solve your problem Regards Grom |
嗨格罗姆,
我已经测试了应用程序示例,它现在可以根据您的建议正常工作。 尽管微控制器UART实际配置为ODD奇偶校验,但超级终端必须配置为9600,N,8,1-无奇偶校验。如果我将ODD奇偶校验置于超级终端中,则通信无法显示错误的字符,或者超级终端客户端窗口仍然停留在光标处。 我还尝试在NO或ODD中更改微控制器Uart初始化参数。这对超级终端没有任何影响,超级终端只想要不进行奇偶校验。 谢谢 斯特凡诺 格罗姆 2010年5月13日星期四下午2:18 STM8发现 - 超级终端示例故障 我通过连接测试了应用程序 Pin2 - > ST232B引脚13(R1in) Pin3 - > ST232B引脚14(T1out) Pin5 - > GND 在许多应用案例中,其他连接不是强制性的。 希望它能解决你的问题 问候 格罗姆 以上来自于谷歌翻译 以下为原文 Hi Grom, I've tested the application example and it now works fine with the connection according to your suggestion. The hyperterminal must be configure as 9600, N, 8, 1 - NO parity, despite the microcontroller UART is actually configured as ODD parity. If I put ODD parity in the hyperterminal the communication fails displaying wrong characters or the hyperterminal client window remains stucked at the cursor. I've also tried to change the microcontroller Uart initialization params in NO or ODD. This has no still effects on hyperterminal, which wants NO parity only. Thanks Stefano Grom Thursday, May 13, 2010 2:18 PM STM8 Discovery - Hyperterminal example trouble I've tested the application by just connecting Pin2 -> ST232B pin 13 (R1in) Pin3 -> ST232B pin 14 (T1out) Pin5 -> GND Other conections are not mandatory in many Application case . Hope it will solve your problem Regards Grom |
大家好。
第一次来这里。 我刚刚开始工作了。 除了2 RX,3TX&之外,我没有连接任何引脚。 5Gnd。 PINS 2&如果你没有使用NULL调制解调器电缆(有一个扭曲),我们大多数人都不会,需要反转3。 在我能找到的任何地方都没有提到它。 文档将TX发送到TX,RX发送到RX。 至于奇数奇偶校验,我也有这个问题。 当您在Hyperterminal pdf的底部配置Hyperterminal时,它表示使用7位和奇校验。不是8位而是没有。 它还显示了一些其他差异,例如ASCII输入力7。 当你做这一切时,它的工作原理。 干杯 关口 以上来自于谷歌翻译 以下为原文 Hi all. First time on here. I just got it working. I didnt connect any pins other than 2 RX, 3TX & 5Gnd. The PINS 2 & 3 need to be reversed if you are not using a NULL modem cable (with a twist in it) as most of us would not. No mention of that anywhere I could find. The documentation puts TX to TX and RX to RX. As for the odd parity, I had this problem too. When you configure Hyperterminal as it says .. down the bottom of the Hyperterminal pdf , it says to use 7 bits and odd parity. Not 8 bits and none. It also shows a few other differences such as ASCII input force 7. When you do all this it works. Cheers Col |
06/29/2010
我刚检查了um0884文档(RS232 Comms)是否有任何变化。 仍然不正确 只是想知道如何阅读这份文件。 干杯 关口 以上来自于谷歌翻译 以下为原文 06/29/2010 I just checked the um0884 document (RS232 Comms) for any changes. Still incorrect Just wondering how everone reading this document is getting on. Cheers Col |
嗨格罗姆,
刚检查了UM0884 Doc。仍然不正确。 只是想知道这个UM0884文件什么时候会被纠正,因为它会导致很多压力。 干杯 关口 以上来自于谷歌翻译 以下为原文 Hi Grom, Just checked the UM0884 Doc. Still incorrect. Just wondering when this UM0884 Document will be corrected as it would be causing a lot of stress out there. Cheers Col |
如果指定了任何奇偶校验,则字节将在UART发送时进行修改。您可以通过配置超级终端(或minicom)来指定7个数据位来解决这个问题,因为这会掩盖奇偶校验位。我发现这是一个问题,当我创建一个与Windows的SLIP连接,因为我找不到指定7个数据位(或以其他方式屏蔽奇偶校验位),因此Windows从未正确接收确认字符串,因为一些字符有额外的位,并且与预期的解释不同。我修复它的方法是在main.c:68指定NO奇偶校验:UART2_Init((u32)9600,...,UART2_PARITY_NO,......);这是非常常见的(例如9600 8N1)。这允许在不改变的情况下传输字符,并且能够建立SLIP连接。
以上来自于谷歌翻译 以下为原文 If any parity is specified, the bytes will be modified as they are transmitted by the UART. You can get around this by configuring hyperterminal (or minicom) to specify 7 data bits, since that will mask off the parity bit. I found this to be a problem when I created a SLIP connection with Windows, since I could find no way to specify 7 data bits (or otherwise mask off the parity bit), and so Windows never correctly received the acknowledgment string, because some of the characters had extra bits and were interpreted differently than intended. The way I fixed this was to specify NO parity, at main.c:68:UART2_Init((u32)9600, ..., UART2_PARITY_NO, ...);, which is very common (e.g. 9600 8N1). This allowed the characters to be transmitted with no alteration, and the SLIP connection was able to be established. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2699 浏览 1 评论
3229 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1801 浏览 1 评论
3639 浏览 6 评论
6019 浏览 21 评论
1327浏览 4评论
1382浏览 3评论
201浏览 3评论
191浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
338浏览 2评论
GMT+8, 2024-12-13 10:21 , Processed in 1.774584 second(s), Total 92, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
