电子发烧友论坛|
我有一个86720A频率扩展单元。
我有一个工作的8672A合成器,并希望将两者结合在一起形成一个20 MHz到18 ghz的合成器。 然而,我一直在寻找一本手册或原理图来向我展示如何将两者结合在一起。 有一个圆形的多芯电缆将两个单元的背面连接在一起,但我没有电缆或如何制作一个电路板(即引脚输出)。 此外,也可能在背面制作一些同轴射频连接。是否有人有这些,或86720A的手册,显示他们如何连接?谢谢,富 以上来自于谷歌翻译 以下为原文 I have an 86720A frequency extension unit. I have a working 8672A synthesizer, and would like to marry the two together to form a 20 MHz to 18 ghz synthesizer. Yet, I have been looking for a manual or schematic to show me how to hook the two together. There is a round multipin cable to connect the backsides of the two units together, but I do not have the cable or a schematic on how to make one up (i.e. the pin outs). Also, there are probably some coaxial rf connections to be made on the backside also. Does anyone have one of these, or the manual for the 86720A that shows how they connect up? Thanks, Rich |
7个回答
Hi Rich-我们没有任何实体手册了但是如果你去:www.agilent.com-在搜索框中输入8672A(86720A无信息) - 在产品匹配下的下一个屏幕的顶部:8672A-点击
手册 - 点击特定手册,了解仪器的封面序列号.8672A / 86720A没有其他信息。我希望这有帮助 - 以上来自于谷歌翻译 以下为原文 Hi Rich - We do not have any physical manuals anymore but if you go to: www.agilent.com - in the search box enter 8672A (no information available on 86720A) - at top of next screen under Product Matches: 8672A - click on Manuals - click on particular manual the covers serial number of your instrument. No other information is available on 8672A/86720A. I hope this helps - |
8672A + 86720A的组合被称为8672S系统 - 所以这是你想要找到的手册。圆形电缆是p / n 8120-3720,但我有一个笔记,1251-5399也可以工作 - 它直接通过直通
,pin1至pin1,引脚2至引脚2等。足够,1251-5399仍可在http://www.parts.agilent.com使用。圆形电缆,以及从100MHz参考输出到输入的BNC电缆是 只需要两个后面板连接。 如果8672A具有选项034或038,则它将具有您需要的连接。 常规8672A没有圆形连接器 以上来自于谷歌翻译 以下为原文 the combination of 8672A + 86720A was called an 8672S system - so that is the manual you want to find. The round cable is p/n 8120-3720 but I have a penciled note that 1251-5399 will work also - it's wired straight thru, pin1 to pin1, pin 2 to pin 2, etc. Strangely enough, 1251-5399 is still available at http://www.parts.agilent.com The round cable, and a BNC cable from the 100MHz reference output to input are the only two rear panel connections you have to make. If the 8672A has option 034 or 038, then it will have the connections you need. Regular 8672A's do not have the round connector |
哇谢谢。
我不想只是尝试引脚输出和爆炸工作8672a的机会! 以上来自于谷歌翻译 以下为原文 wow thanks. I did not want to just experiment with pin outs and the chance of blowing up a working 8672a! |
嗯......好险!
那是86720a和8672a后面板上连接器的throkom pn。 我需要母配合部件来组成电缆。 我环顾四周,祝我好运。我在ebay上找到了你提到的部分,上面有一些很好的照片:http://cgi.ebay.com.sg/1251-5399-CONNEC ... 0405953473 以上来自于谷歌翻译 以下为原文 well...close! That is the throkom pn for the connector that is on the rear panel of the 86720a and 8672a I have. I need the female mating part to make up a cable. I am looking around, wish me luck. I found the part you mentioned on ebay with some good pictures of it: http://cgi.ebay.com.sg/1251-5399-CONNEC ... 0405953473 |
请看这里:http://cp.literature.agilent.com/litweb ... 3703EN.pdfon第3页了解其他一些可能有用的电缆
以上来自于谷歌翻译 以下为原文 Look here: http://cp.literature.agilent.com/litweb ... 3703EN.pdf on page 3 for some other cables that might be useful |
哇,你们都知道你的东西。
它看起来像pn 8120-2703衰减器电缆将与thorkom bulkead连接器匹配。 这些都可以在各地买到。 当它进来时,我会发布它是否适合。谢谢你 以上来自于谷歌翻译 以下为原文 Wow, you guys know your stuff. It looks like a pn 8120-2703 attenuator cable will mate to the thorkom bulkead connectors. These are available all over the place. When it comes in, I will post if it fits. thanks Rich |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 21:36 , Processed in 0.966480 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1070
