电子发烧友论坛扫一扫,分享给好友
安装Gitlab
yum install -y curl policycoreutils-python openssh-serversystemctl enable sshdsystemctl start sshd
# 添加仓库curl https://packages.gitlab.com/install/repositories/gitlab/gitlab-ce/script.rpm.sh | sudo bash#安装Gitlab-ceEXTERNAL_URL="***" yum install -y gitlab-ce
gitlab_rails['ldap_enabled'] = true###! **remember to close this block with 'EOS' below**gitlab_rails['ldap_servers'] = YAML.load <<-'EOS' main: # 'main' is the GitLab 'provider ID' of this LDAP server label: 'LDAP' host: 'x.x.x.x' port: 389 uid: 'cn' bind_dn: 'cn=Manager,dc=example,dc=com' method: 'plain' # "tls" or "ssl" or "plain" password: '123456' active_directory: true allow_username_or_email_login: false lowercase_usernames: false block_auto_created_users: false base: 'ou=people,dc=example,dc=com' user_filter: ''EOSuid 默认sAMAccountName 这边配置为cn 如果要使用中文登录时就使用默认配置 bind_dn 域服务器的管理员账号,根据实际情况修改 active_directory 似乎是针对连接是否是ad域控的标示,因为这部分是域服务器的配置,故为true allow_username_or_email_login 用户登录是否用户名和邮箱都可以,方便用户故配置true base 用户列表所在的目录,因为新增的用户都在People下(试验了用户放在User时gitlab检测不到用户,故新建了一个目录People,并将新建的用户移入了该目录下),故这么配置,根据实际情况修改 修改完以上配置后需要重置gitlab参数: gitlab-ctl reconfiguregitlab-ctl restart# 查看日志gitlab-ctl log
gitlab_rails['smtp_enable'] = truegitlab_rails['smtp_address'] = "smtp.exmail.qq.com"gitlab_rails['smtp_port'] = 587gitlab_rails['smtp_user_name'] = "xxxx@xx.com"gitlab_rails['smtp_password'] = "password"gitlab_rails['smtp_authentication'] = "login"gitlab_rails['smtp_enable_starttls_auto'] = truegitlab_rails['smtp_tls'] = truegitlab_rails['gitlab_email_from'] = 'xxxx@xx.com'gitlab_rails['smtp_domain'] = "exmail.qq.com"
只有小组成员才能发言,加入小组>>
1642 浏览 0 评论
2410 浏览 0 评论
8469 浏览 0 评论
写了一个用DMA读取ADC数据的程序,记录下整个过程和一点心得
3626 浏览 0 评论
3884 浏览 0 评论
/9
GMT+8, 2025-12-2 10:05 , Processed in 0.690368 second(s), Total 73, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
