嗨,我正在使用PIC32MM0064gpl036芯片配置有MCC,我正在尝试获得最大的性能(数据表显示性能DC为25MHZ)。使用简单的设置-我似乎不能调整SYSCLK(剩余在8Mhz)在寄存器中,用PLLMULT 3x或2x生成似乎没有区别Erron,StultCy配置性能(80000000);似乎是PLIB和PICMX或MZ变体。(我不能得到PLIB与这PIC32毫米工作)我如何得到索赔37 DMIPS性能?任何指针都会被欣赏。
以上来自于百度翻译 以下为原文 Hi, I am using the PIC32MM0064gpl036 The chip is configured with MCC, I am trying to get maximum performance , (The datasheet says performance DC to 25MHZ). Using the easy setup - I can't seem to adjust SYSCLK (Remains at 8Mhz) In the registers, Generating with PLLMULT 3x or 2x don't seem to make a difference, SYSTEMConfigPerformance(80000000); seems to be for PLIB and PICMX or MZ variants. (I cant get plib working with this PIC32MM) How to I get the claimed 37DMIPS performance? Any pointers will be much appreciated. Regards Lafras |
4个回答
你如何确定PLL的设置没有区别?如何设置PLL?
以上来自于百度翻译 以下为原文 How are you determining that setting the pll makes no difference? How are you setting the PLL ? |
37 DMIPS是微MIPS核心与频率相乘的标准基准结果。这主要是一个没有实际意义的营销数字。使用3xPLL(8x 3)内置振荡器可以获得的最大频率是24MHz。使用OSCTUN可以稍微增加频率,但是没有太大区别。如果PLL不工作,则设置不正确。
以上来自于百度翻译 以下为原文 37 DMIPS is a standard benchmark result for the MicroMIPS core multiplied by the frequency. This is mostly a marketing number which doesn't have any real life meaning. The maximum frequency you can get with internal oscillator is 24 MHz using 3xPLL (8 x 3). You may increase the frequency slightly with OSCTUN, but it won't make much difference. If PLL is not working, you're not setting it up correctly. |
生成的mcc.c文件集SPLLCON=0x10080;//PLLODIV 1:1;PLLMULT 3x;PLLICLK FRC;当我在ICD3中读回它时,它读取相同的值CLKSTAT=0x0;同样在OSCILLATOR_Initialize中设置,当我在ICD3中读回这个值时,我得到0,我希望SPLLRDY、SPDIVRDY、FRCRDY为1;mcc.c:void OSCILLATOR_Initialize(void){SYSTEM_RegUnlock();//CF无时钟故障;FRCDIV FRC/1;SLPEN设备在发出等待指令时将进入空闲模式;NOSC FRCDIV;SOSC禁用;CLKLOCK时钟和PLL选择没有被锁定并且可以修改;OSWEN Complete;OSCCON=0x0;//调谐中心频率;OSCTUN=0x0;//PLLODIV 1:1;PLLMULT 3x;PLLICLK FRC;SPLLCON=0x10080;//SWRST禁用;RSWRST=0x0;//WDTO禁用;GNMI禁用;CF禁用;WDTS禁用;NMNT 0;LVD禁用;SWNMI禁用;RNMICON=0x0;//SBOREN禁用;VREGS禁用;RETEN禁用;PWRCON=0x0;SYSTEM_RegLock();//WDTO禁用;EXTR禁用;POR禁用;睡眠禁用;BOR禁用;PORIO禁用;IDLE禁用;PORCORE禁用;BCFGERR禁用;CMR禁用;BCFGFAIL禁用;SWR禁用;RCON=0x0;//ON禁用;DIVSWEN禁用;RSLP禁用ROSEL SYSCLK;OE禁用;SIDL禁用;RODIV 0;REFO1CON=0x0;//ROTRIM 0;REFO1TRIM=0x0;//SPDIVRDY禁用;CLKSTAT=0x0;}
以上来自于百度翻译 以下为原文 The generated mcc.c file sets SPLLCON = 0x10080; // PLLODIV 1:1; PLLMULT 3x; PLLICLK FRC; When I read it back in ICD3 it reads this same value CLKSTAT = 0x0; also get set in OSCILLATOR_Initialize, When I read this back in ICD3 I get 0, I would expect SPLLRDY,SPDIVRDY,FRCRDY to be 1; mcc.c: void OSCILLATOR_Initialize(void) { SYSTEM_RegUnlock(); // CF No Clock Failure; FRCDIV FRC/1; SLPEN Device will enter Idle mode when a WAIT instruction is issued; NOSC FRCDIV; SOSCEN disabled; CLKLOCK Clock and PLL selections are not locked and may be modified; OSWEN Complete; OSCCON = 0x0; // TUN Center frequency; OSCTUN = 0x0; // PLLODIV 1:1; PLLMULT 3x; PLLICLK FRC; SPLLCON = 0x10080; // SWRST disabled; RSWRST = 0x0; // WDTO disabled; GNMI disabled; CF disabled; WDTS disabled; NMICNT 0; LVD disabled; SWNMI disabled; RNMICON = 0x0; // SBOREN disabled; VREGS disabled; RETEN disabled; PWRCON = 0x0; SYSTEM_RegLock(); // WDTO disabled; EXTR disabled; POR disabled; SLEEP disabled; BOR disabled; PORIO disabled; IDLE disabled; PORCORE disabled; BCFGERR disabled; CMR disabled; BCFGFAIL disabled; SWR disabled; RCON = 0x0; // ON disabled; DIVSWEN disabled; RSLP disabled; ROSEL SYSCLK; OE disabled; SIDL disabled; RODIV 0; REFO1CON = 0x0; // ROTRIM 0; REFO1TRIM = 0x0; // SPDIVRDY disabled; CLKSTAT = 0x0; } |
好的,我发现表59-2inhttp://ww1.micro..com/...eviceDoc/60001329b.pdf非常有用,正确设置配置位使得PLL.pragma config FNOSC=1pragma config POSCMOD=2HOWEVER,MCC没有意识到这一点,因此在MCC配置中,我必须补偿波特率,并且进行交互。铂速率。所以我确信这不是在MCC做这件事的正确方法。还是MCC仍然是WIP?
以上来自于百度翻译 以下为原文 OK, I found Table 59-2 in http://ww1.microchip.com/...eviceDoc/60001329b.pdf very useful, setting the config bits correctly enables the PLL. #pragma config FNOSC = 1 #pragma config POSCMOD = 2 HOWEVER, MCC does not apear to be aware of this, so in MCC config I have to compensate the baud rate, and interrupt rate. So I am sure this is not the right way to do this in MCC. Or is MCC still WIP? |
只有小组成员才能发言,加入小组>>
5189 浏览 9 评论
2009 浏览 8 评论
1933 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3181 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2232 浏览 5 评论
746浏览 1评论
632浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
517浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
644浏览 0评论
544浏览 0评论
GMT+8, 2024-11-30 18:03 , Processed in 1.258807 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
