SFE_BMP180.cp
- 【Arduino】66种传感器模块系列实验(68)
- 实验六十八:BMP180 新款 BOSCH温度模块气压传感器(代替BMP085)
- SFE_BMP180.cp
- #include
- #include
- #include
- #include
- SFE_BMP180::SFE_BMP180()
- char SFE_BMP180::begin()
- double c3,c4,b1;
- Wire.begin();
- if (readInt(0xAA,AC1) &&
- readInt(0xAC,AC2) &&
- readInt(0xAE,AC3) &&
- readUInt(0xB0,AC4) &&
- readUInt(0xB2,AC5) &&
- readUInt(0xB4,AC6) &&
- readInt(0xB6,VB1) &&
- readInt(0xB8,VB2) &&
- readInt(0xBA,MB) &&
- readInt(0xBC,MC) &&
- readInt(0xBE,MD))
- AC6 = 23153;
- Calcs.pdf
- 25671; AC6 = 18974;
- c3 = 160.0 * pow(2,-15) * AC3;
- c4 = pow(10,-3) * pow(2,-15) * AC4;
- b1 = pow(160,2) * pow(2,-30) * VB1;
- c5 = (pow(2,-15) / 160) * AC5;
- c6 = AC6;
- mc = (pow(2,11) / pow(160,2)) * MC;
- md = MD / 160.0;
- x0 = AC1;
- x1 = 160.0 * pow(2,-13) * AC2;
- x2 = pow(160,2) * pow(2,-25) * VB2;
- y0 = c4 * pow(2,15);
- y1 = c4 * c3;
- y2 = c4 * b1;
- p0 = (3791.0 - 8.0) / 1600.0;
- p1 = 1.0 - 7357.0 * pow(2,-20);
- p2 = 3038.0 * 100.0 * pow(2,-36);
- return(1);
- else
- return(0);
- char SFE_BMP180::readInt(char address, int16_t &value)
- unsigned char data[2];
- data[0] = address;
- if (readBytes(data,2))
- value = (int16_t)((data[0]<<8)|data[1]);
- negative
- return(1);
- value = 0;
- return(0);
- char SFE_BMP180::readUInt(char address, uint16_t &value)
- value = (((uint16_t)data[0]<<8)|(uint16_t)data[1]);
- return(1);
- value = 0;
- return(0);
- char SFE_BMP180::readBytes(unsigned char *values, char length)
- char x;
- Wire.beginTransmission(BMP180_ADDR);
- Wire.write(values[0]);
- _error = Wire.endTransmission();
- if (_error == 0)
- Wire.requestFrom(BMP180_ADDR,length);
- while(Wire.available() != length) ;
- for(x=0;x
- values[x] = Wire.read();
- return(1);
- return(0);
- char SFE_BMP180::writeBytes(unsigned char *values, char length)
- char x;
- Wire.write(values,length);
- if (_error == 0)
- return(1);
- else
- return(0);
- char SFE_BMP180::startTemperature(void)
- unsigned char data[2], result;
- data[0] = BMP180_REG_CONTROL;
- data[1] = BMP180_COMMAND_TEMPERATURE;
- result = writeBytes(data, 2);
- if (result)
- return(5);
- else
- return(0);
- char SFE_BMP180::getTemperature(double &T)
- char result;
- double tu, a;
- data[0] = BMP180_REG_RESULT;
- result = readBytes(data, 2);
- if (result)
- tu = (data[0] * 256.0) + data[1];
- a = c5 * (tu - c6);
- T = a + (mc / (a + md));
- return(result);
- char SFE_BMP180::startPressure(char oversampling)
- unsigned char data[2], result, delay;
- switch (oversampling)
- case 0:
- data[1] = BMP180_COMMAND_PRESSURE0;
- delay = 5;
- break;
- case 1:
- data[1] = BMP180_COMMAND_PRESSURE1;
- delay = 8;
- break;
- case 2:
- data[1] = BMP180_COMMAND_PRESSURE2;
- delay = 14;
- break;
- case 3:
- data[1] = BMP180_COMMAND_PRESSURE3;
- delay = 26;
- break;
- default:
- delay = 5;
- break;
- if (result)
- return(delay);
- else
- return(0);
- char SFE_BMP180::getPressure(double &P, double &T)
- sealevel().
- unsigned char data[3];
- char result;
- double pu,s,x,y,z;
- result = readBytes(data, 3);
- if (result)
- pu = (data[0] * 256.0) + data[1] + (data[2]/256.0);
- s = T - 25.0;
- x = (x2 * pow(s,2)) + (x1 * s) + x0;
- y = (y2 * pow(s,2)) + (y1 * s) + y0;
- z = (pu - x) / y;
- P = (p2 * pow(z,2)) + (p1 * z) + p0;
- return(result);
- double SFE_BMP180::sealevel(double P, double A)
- return(P/pow(1-(A/44330.0),5.255));
- double SFE_BMP180::altitude(double P, double P0)
- return(44330.0*(1-pow(P/P0,1/5.255)));
- char SFE_BMP180::getError(void)
- return(_error);
复制代码
