电子发烧友论坛|
嗨,
最近我参加了LSM9dS0, LSM9dS1和LM303D传感器。 现在,我有来自Accelerometer,Gyroscope& amp;的LSM9dS1原始数据。磁力。项目基于汽车驾驶安全系统。所以我想知道如何以Km / hr计算LSM9sS1的加速度。 后来,我想检测一些其他的东西,如事故检测,皮疹驾驶,汽车牵引,使用传感器融合应用的严酷制动。 请分享您的意见。 谢谢。 #lsm9ds1#sensor-fusion 以上来自于谷歌翻译 以下为原文 Hi, Recently I worked on LSM9dS0, LSM9dS1 and LM303D sensor. Now, I have LSM9dS1 raw data from Accelerometer, Gyroscope & Magnetometer. Project is based on car driving safety system. So I want to know how can I calculate the Acceleration from LSM9sS1 in terms of Km/hr. Later, I want to detect some other things also like Accident detection, Rash Driving, Car tow, Harsh braking using sensor fusion application. Please share your opinion. Thank you. #lsm9ds1 #sensor-fusion |
4个回答
加速度计测量加速度,以获得有关速度的信息,您必须对该值进行积分。
ST提供传感器融合库MotionFX https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software-expansion/x-cube-mems1.html 软件包。 以上来自于谷歌翻译 以下为原文 Accelerometer measures acceleration, so to get the information about the velocity you have to integrate the value. ST provides sensor fusion library MotionFX in https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software-expansion/x-cube-mems1.html software package. |
传感器融合库不依赖于特定的传感器。您可以创建自己的项目,从LSM9DS1读取加速计,陀螺仪和磁力计数据,然后将它们传递给传感器融合库,计算输出。
X-CUBE-MEMS1封装中不直接支持LSM9DS1,并且将来不会使用LSM9DS1,因为它是相当古老的传感器。但您可以将其用作示例或模板,并自行添加LSM9DS1。 为了获得最佳效果,我建议您使用现代传感器,如LSM6DSL + LIS2MDL。 以上来自于谷歌翻译 以下为原文 The sensor fusion library is not dependent on specific sensor. You can create your own project which will read accelerometer, gyroscope and magnetometer data from LSM9DS1 a pass them to the sensor fusion library which will calculate the outputs. LSM9DS1 is not directly supported in X-CUBE-MEMS1 package, and won't be in the future, because it is quite old sensor. But you can use it as example or template and add LSM9DS1 by yourself. For best results I would recommend you to use modern sensor like LSM6DSL + LIS2MDL. |
我最近检查了X-CUBE-MEMS1库,但似乎LSM9DS1不是支持的传感器之一。有没有简单的方法来增加对此传感器的支持?或者是否会在不久的将来正式添加支持?我是一名非常新的学生。
以上来自于谷歌翻译 以下为原文 I recently checked the X-CUBE-MEMS1 library, but it seems that LSM9DS1 is not one of the supported sensor. Is there an easy way to add support to this sensor? Or would the support be added officially in near future? I am a student very new in this aera. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 08:51 , Processed in 0.940945 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1690
