亲爱的先生/女士,请建议我使用Xilinx FPGA完全替代smartfusion2 FPGA。
我们希望在我们的新设计中用Xilinx等效FPGA取代smartfusion(M2S005-400VF)FPGA,不需要与脚印兼容,问候,Raja 以上来自于谷歌翻译 以下为原文 Dear Sir/Madam, Please suggest me the exact replacement for smartfusion2 FPGA with Xilinx FPGA. We want to replace smartfusion (M2S005-400VF) FPGA with Xilinx equivalent FPGA in our new design, need not to be footprint compatible, Regards, Raja |
3个回答
嗨@ raja89,
不确定是否真的有一个完全等效的FPGA。 您可能希望与授权分销商讨论您的需求,以找到最适合您的需求。 它可能是Zynq-7000 问候, FlorentProduct应用工程师 - Xilinx技术支持EMEA ------------------------------------------ -------------------------------------------------- ----------------------------不要忘记回复,kudo,并接受作为解决方案。 以上来自于谷歌翻译 以下为原文 Hi @raja89, Not sure if there is really a fully equivalent FPGA. You might want to discuss your need with an Authorized Distributor to find the right fit for you. It might be a Zynq-7000 Regards, Florent Product Application Engineer - Xilinx Technical Support EMEA ------------------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. |
没有直接替代品。
Xilinx FPGA缺少的关键特性是闪存; 所有Xilinx芯片除了Spartan 3AN(现在变得非常古老)都需要一个外部闪存芯片来存储它们的配置数据。 Xilinx与Cortex-M3处理器没有任何关系。 它们具有带有Cortex-A9的Zynq,或者带有Cortex-A53的Zynq UltraScale +(两者都比Cortex-M3强大得多),但使用其中任何一个都将涉及重要的代码重写。 以上来自于谷歌翻译 以下为原文 There is no direct replacement. The key feature lacking in Xilinx FPGAs is flash; all Xilinx chips except the Spartan 3AN (which is getting pretty ancient now) require an external flash memory chip to store their configuration data. Xilinx also has nothing with a Cortex-M3 processor. They have the Zynq with the Cortex-A9, or the Zynq UltraScale+ with the Cortex-A53 (both of which are vastly more powerful than the Cortex-M3), but using either will involve a significant code rewrite. |
感谢您的回复,smartfusion fpga和zynq fpga的逻辑单元(LUT)比较怎么样?
以上来自于谷歌翻译 以下为原文 Thanks for your reply, What about logic cells (LUT's) comparison of smartfusion fpga and zynq fpga? |
只有小组成员才能发言,加入小组>>
2321 浏览 7 评论
2733 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2368 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
653浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
462浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
222浏览 1评论
668浏览 0评论
1860浏览 0评论
GMT+8, 2024-9-29 19:57 , Processed in 1.229195 second(s), Total 81, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
