我无法通过RS-232通过Hyperterminal连接我们的电源。
在按下电源上的I / O配置按钮后,我已经验证了超级终端中的设置:9600奇偶校验:无停止位:2(来自手动)手册中没有提及流量控制但是我试过了 所有的可能性。 当我输入“* IDN?”时 我无法得到电源的响应。 我已经确认我手册中有一条Null型号电缆。 任何援助将不胜感激。 以上来自于谷歌翻译 以下为原文 I am having trouble connecting to our power supply through Hyperterminal via RS-232. I have verified the settings in hyperterminal to that shown after pushing the I/O Config button on the power supply Baud: 9600 Parity: None Stop Bits: 2 (from manual) There is no mention of flow control in the manual but I have tried all of the possibilities. When I type "*IDN?" I am unable to get a response from the power supply. I have verified that I have a Null model cable as stated in the manual. Any assistance would be appreciated. |
2个回答
有人可以帮助我,检查他们的设备(不是PC)上的引脚4上是否有输出。
我注意到在我的电脑上这个引脚很高但是在电源上这个引脚没有电压。 如果两者都是数据终端设备,我想在电源上这个引脚也应该很高。 我没有另外的电源来测试这个理论。 以上来自于谷歌翻译 以下为原文 Can somebody help me out and check if there is an output on pin 4 on their device (not the PC). I noticed on my PC that this pin is high however on the power supply there is no voltage at this pin. If both are data terminal devices I amm thinking that on the power supply this pin should be high also. I do not have another power supply to test this theory. |
安捷伦网站上提供了安捷伦仪器和超级终端设置的程序。
http://www.home.agilent.com/upload/cmc_upload/All/HyperTerminal.pdf你可以尝试一下。 希望这有帮助 以上来自于谷歌翻译 以下为原文 There is a procedure on Agilent Instrument and HyperTerminal Setup provided in Agilent website. http://www.home.agilent.com/upload/cmc_upload/All/HyperTerminal.pdf You can try it. Hope this help |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1846 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1547 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
350浏览 0评论
1386浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
262浏览 0评论
2248浏览 0评论
1103浏览 0评论
GMT+8, 2024-3-29 15:55 , Processed in 2.032105 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
