电子发烧友论坛|
嗨,当我运行摩托车平台插件,进度条达到约25%,不再走了。尝试了几次,没有Luki猜测它试图打电话回家?我正在用Java MOD运行一个新安装的MPLABX 3.55,允许它在一个CalpAtter代理上运行。在IDE启动后,没有Java MOD指针运行MPLABX 3.55。艾伦,
以上来自于百度翻译 以下为原文 Hi, When i run the motorbench plugin the progess bar gets to about 25% and dosnt go any further. Tried a few times with no luck I'm guessing its trying to phone home? I'm running a fresh install of MPLABX 3.55 with java mod to allow it to run on a corperate proxy. Running MPLABX 3.55 without java mod hands just after startup of the ide. Alan, |
4个回答
嗨,艾伦,你是在安装插件的时候观察这个问题的吗?还是在安装和运行自调试过程之后呢?-斯里卡
以上来自于百度翻译 以下为原文 Hi Alan, Are you observing this issue while installing the plugin, or is this after installing and while running the Self-Commissioning process? - Srikar |
我已经成功地在插件菜单中安装了它,它旁边有一个绿色的嘀嗒声。当我运行这个插件时,它挂在那里,永远不会完全加载。飞溅屏幕上的进度条没有通过25%。我甚至在夜间没有改变。
以上来自于百度翻译 以下为原文 I've installed it sucessfully in the plugin menu and that has a green tick next to it. Its when I run the plugin it hangs there and never loads completely. The progress bar on the splash screen dosnt pass 25%. Ive even left it over night with no change |
为了更好地理解:您有MPLAB X 3.55,Java MOD允许在企业代理上运行:在飞溅屏幕的时候挂起(大约25%),而没有Java MOD允许在公司代理上运行,MIDAB X在IDE启动后IDE或摩托车平台挂起后挂起?还有,请分享你的系统信息。谢谢,Nidhi。
以上来自于百度翻译 以下为原文 To understand better: You have MPLAB X 3.55, with java mod to allow to run on corporate proxy : Hangs at the time of splash screen (around 25%) Without java mod to allow to run on corporate proxy, MPLAB X hangs after startup of the IDE or motorBench hangs after startup of IDE? Also, can you please share your system information. Thanks, Nidhi |
Win 7 Pro Service PACK 1TEXEL XYON 3.5GHZ16GB RAMSSD HARDRIVEMPLABX 3.55具有Java代理在公司代理上运行,因此它没有运行最新的JavaHtp://www. MigCHIP.COM/FUMMS/M902171.ASPX,而没有旧版本的Java,MPLABX冻结,就像在TraceX中讨论的一样。我不能启动马达插件,我是否应该开票?我是一个贸易程序员,你可以给我一些调试的东西,如果你想尝试。
以上来自于百度翻译 以下为原文 WIN 7 Pro Service Pack 1 Intel Xeon 3.5Ghz 16GB Ram SSD Hardrive MPLABX 3.55 has this java mod to run on the corporate proxy, so its not running the latest java http://www.microchip.com/forums/m902171.aspxWithout that old version of java, MPLABX freezes like discussed in the thrread. I cant start the motor plugin at all Should I file a ticket? I am a programmer by trade, you can give me some debug stuff to try if you want. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5794 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1125浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 17:35 , Processed in 0.640745 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1969
