电子发烧友论坛|
我设计的驱动传输线的电路使它难以使用发射使能引脚。我可以使用配置BITTO来关闭芯片内的模拟输出缓冲区吗?类似这样的事情:
ABFYCR0& ABFKCR0=ABF; 这些陈述将放在何处?我似乎找不到控制传输启用的代码。 以上来自于百度翻译 以下为原文 The circuit I have designed to drive the transmit line makes it difficult to use the transmit enable pin. Could I use the configuration bit to turn off the Analog output buffer inside the chip instead? Something like this: ABF_CR0 &= ~ABUF0EN; ABF_CR0 |= ABUF0EN; Where would these statements be placed? I can't seem to find the code that controls the transmit enable. |
2个回答
杰克
TX禁用引脚用于驱动外部TX放大器。当发射电路具有比接收电路低得多的阻抗时。如果放大器没有被禁用,芯片将不能接收来自电力线的任何信号。 即使你关掉缓冲器,它也不会关闭TX放大器。此外,控制TX禁用PIN的代码是PLT用户模块库的一部分,不能修改。 你能创建一个支持案例并附上你的示意图吗?如果我更了解你们的电路,帮助这些问题会容易得多。 如果你还需要什么,请告诉我。 你真的, 拉胡尔帕萨尼 应用工程师 以上来自于百度翻译 以下为原文 Jack, The TX Disable pin is used to drive the external TX Amplifier. When the transmit circuitry has a much lower impedance than the receive circuitry. If the Amplifier is not disabled, the chip will not be able to receive any signal from the powerline. Even if you switch off the buffer, it will not shut down the TX Amplifier. Also, the code that controls the TX Disable pin is a part of the PLT User Module library and cannot be modified. Could you create a support case and attach the your schematic to that? It will be much easier to help with these issues if I know your circuit better. Let me know if you need anything else. Yours truly, Rahul Parsani Applications Engineer - PLC |
你好,
我正在研究PLC CY8CPLC2028 PVXI。我正在尝试使用PLT数据表中的主C代码示例来传输数据。 但是发射机不能工作。当用示波器检查时,在IC的TX管脚上有一些FSK信号。但是TXI禁用引脚总是高的。在电力线耦合电路中,停用固定化阶段。所以完全传输没有发生。 为什么我检查示波器时TXX禁用总是高的? 谢谢和问候, 马卡兰 压缩编码 755字节 以上来自于百度翻译 以下为原文 Hello, I am working on PLC CY8CPLC20 28PVXI. I am trying to transmit data using main.c code example given in PLT datasheet. But transmitter is not working. There is some FSK signal at tx pin of IC, when I checked with oscilloscope. But tx_disable pin is always high. It is disabling ampification stage in power line coupling circuitary. So full transmission is not happening. Why tx_disable is always high when I checked on oscilloscope? thanks & regards, Makarand
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 10:26 , Processed in 0.535603 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
480
