扫一扫,分享给好友
我试图通过USB从PSoC 5第一触控启动器KITTO向计算机发送数据,问题是设备没有枚举。
我已经为PSoC 5:3-按钮鼠标,USB中断传输示例提供了示例项目。所有的工作都用于构建和编程PSoC,但是当完成时,没有提示从Windows中添加设备,处理USB连接的软件告诉我设备断开。 我还使用调试器来运行代码。下面的行是一个无限循环。 同时(false=U***fsIbGeDebug()) { *等待枚举*/ ; } 我在考虑PSoC在编程后需要复位,然后作为USB设备编程为…请给小费! 先谢谢你, 阿德里安娜 以上来自于百度翻译 以下为原文 I am trying to send data through u*** from the PSoC 5 First touch starter kit to the computer and the problem is the device does not enumerate. I have tried example projects provided for PSoC 5: 3-button mouse, USB Interrupt Transfer Example. Everything works for building and programming the psoc, but when finished, there is no prompt with the device being added from windows and the software that handles the USB connection tells me the device is disconnected. I also used the debugger to run the code. The following lines are an infinite loop. while(FALSE == USBFS_bGetConfiguration()) { /* Waiting for enumeration */ ; } I am thinking about wheather the psoc needs a reset after programming and before acting as the USB device it is programmed to be... please give oppinions! Thank you in advance, Adriana |
1个回答
嗨,Adriana,
这个问题已经讨论过,并且在一个话题之前提出了解决办法。你可以通过以下链接找到它: HTTP://www. CyPress?COM/?APP =论坛和ID ID=2233和;RID=45003 进入第二个问题,正如您所提到的,在第一个触摸工具箱上没有重置按钮。 因此,您需要手动插入并插入USB电缆(或电池)供电,以便在设备被编程后重置。 当做, DASG 以上来自于百度翻译 以下为原文 Hi Adriana, This issue was already discussed and workaround suggested in a topic before. You can find it by following this link: http://www.cypress.com/?app=forum&id=2233&rID=45003 Coming to the second question, as you have mentioned, there is no reset button present on the First Touch Kit. So, you need to manually plug out and plug in back the USB cable (or Battery) powering the kit in order to reset after the device has been programmed. Regards, dasg |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7568浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 15:45 , Processed in 1.032304 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2614
