你好,
我正在尝试为VC709板生成GTH收发器,但我遇到了复位序列的问题。 所以,我想我会挖掘可用的答案记录,看看是否有任何一个解决了我的问题。 根据AR#55009,我需要使用以下公式更改“tx_startup_fsm.vhd”中MAX_WAIT_BYPASS的值: 1024 * txpll_divsel *内部数据路径+ 1024 + 640 + 3200 但是,AR没有指定“txpll_divsel”和“内部数据路径”的值,我在收发器用户指南(UG476)或Coregen生成的代码中找不到对它们的任何引用。 有谁知道这些值应该是什么? 谢谢! http://www.xilinx.com/support/answers/55009.html 以上来自于谷歌翻译 以下为原文 Hello,I'm trying to generate a GTH transceiver for a VC709 board, but I'm having trouble with the reset sequence. So, I thought that I'd dig through the available answer records to see if any of them solve my problem.According to AR #55009, I need to change the value of MAX_WAIT_BYPASS in "tx_startup_fsm.vhd" using this formula:1024*txpll_divsel*internal Data Path + 1024+640+3200However, the AR doesn't specify the values for "txpll_divsel" and "Internal Data Path" and I can't find any references to them in the transceivers users guide (UG476) or in the code that Coregen generates.Does anyone know what these values should be?Thanks!http://www.xilinx.com/support/answers/55009.html |
5个回答
嗨,
我认为AR清楚地谈到了公式中属性的值是什么 024 * pll输出分频器*内部数据路径宽度+ 1024 + 640 + 3200 。 以下是声明。 “内部数据路径宽度等于16,20,32或40且pll输出分频器等于TXOUT_DIV属性,除非设计使用速率变化,在这种情况下它将等于TXRATE设置的分频器(见表3-25) UG476或UG482的表3-23)。“ 如果仍然存在混淆,请告诉我。 谢谢, 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, I think the AR clearly talks about what are the values of the attributes in the formula 024*pll output divider*internal data path width + 1024+640+3200. Below is the statement. "internal data path width is equal to 16,20,32 or 40 and pll output divider is equal to the TXOUT_DIV attribute unless the design uses rate changes in which case it will be equal to the divider set by TXRATE (see table 3-25 of UG476 or table 3-23 of UG482)." Let me know if still there is a confusion. Thanks, Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.View solution in original post |
嗨,
我认为AR清楚地谈到了公式中属性的值是什么 024 * pll输出分频器*内部数据路径宽度+ 1024 + 640 + 3200 。 以下是声明。 “内部数据路径宽度等于16,20,32或40且pll输出分频器等于TXOUT_DIV属性,除非设计使用速率变化,在这种情况下它将等于TXRATE设置的分频器(见表3-25) UG476或UG482的表3-23)。“ 如果仍然存在混淆,请告诉我。 谢谢, 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, I think the AR clearly talks about what are the values of the attributes in the formula 024*pll output divider*internal data path width + 1024+640+3200. Below is the statement. "internal data path width is equal to 16,20,32 or 40 and pll output divider is equal to the TXOUT_DIV attribute unless the design uses rate changes in which case it will be equal to the divider set by TXRATE (see table 3-25 of UG476 or table 3-23 of UG482)." Let me know if still there is a confusion. Thanks, Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
你还对此感到困惑吗?
谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Do you still have a confusion on this? Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
你好,
当我发布这个帖子时,AR没有包含那些语句。 感谢您添加它们。 以上来自于谷歌翻译 以下为原文 Hello,The AR did not contain those statements when I posted this thread. Thank for you adding them. |
很高兴听到它有用!!!
谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Nice to hear it was helpful!!! Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
只有小组成员才能发言,加入小组>>
2388 浏览 7 评论
2804 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2270 浏览 9 评论
3338 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2440 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
768浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
551浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
386浏览 1评论
1975浏览 0评论
692浏览 0评论
GMT+8, 2024-11-29 15:40 , Processed in 1.999518 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
